    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 11-16-2014, 06:55 AM   #11116
Potoczak's Avatar
Trader Rating: 111 (100%+)
Originally Posted by dpcardoza View Post
Makes me wonder if the exotec aluminum diff nut will work?
It probably would since I just used all the stock stuff out of my stock kyosho diff to build the mip diff. The exotek diff nut is supposed to replace the stock nut.
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 11-16-2014, 09:11 AM   #11117
3srcracing's Avatar
Trader Rating: 25 (100%+)
Maybe this is just me being a idiot and wanting to try things. On my home track (damp/wet) you need a really firm insert. I currently have the AKA foams in which are firm, but wondering if a even firmer insert would work better?
What would happen if I cut down a open cell foam and slid it under the AKA foam? Would that work, or would it just act ridiculous?
3srcracing is offline   Reply With Quote
Old 11-16-2014, 09:16 AM   #11118
Potoczak's Avatar
The new dirt tech inserts by jconcepts are firmer then the aka inserts.
Pete Potoczak
Old 11-16-2014, 08:37 PM   #11119
Trader Rating: 81 (100%+)
This is a random question but my kids stripped my 25t servo horn today. I only use the 25t and have the remainder of the 23 and 24t horns. Antibody interested in swapping? Think I have 2 of each.
dpcardoza is offline   Reply With Quote
Old 11-16-2014, 09:21 PM   #11120
Originally Posted by KalEl63 View Post
Thanks for the info/confirmation I will just grab the little T thing from a spare diff I have since that's all I need from that part.
I tried taking mine out and it self-destructed. So had to order a new one for the puck ball diff and got a couple exoteks for the original and a backup for the pucker
glenng is offline   Reply With Quote
Old 11-16-2014, 10:23 PM   #11121
joecool's Avatar
Trader Rating: 19 (100%+)
Default Servo horns
I'd swap for your 23t horns. I can mail out the 25t to you. Just pm me your address and I'll reply with address.
Joe Cool
Kyosho America, Team Orion, Ko Propo
joecool is offline   Reply With Quote
Old 11-17-2014, 12:32 PM   #11122
Anybody else. I've got 2 24t servo horns for you hitec guys.
Old 11-19-2014, 06:48 AM   #11123
3srcracing's Avatar
Looking for a setup to lead me in the right direction..
Usually the track I run on is medium to high. But with how my car feels I would say low haha.
The car just doesn't traction, and you can't drive it. It's weird because at the opposite track it's on rails. Doesn't really want to carry connor speed, just hard to drive, and hard to drive hard at all.
Yesterday I ran the Zach Rogers setup, and it was way better, but still feel it lacked traction all the way around and was hard to drive. (just cause I know what it's capable of).
What setup would you suggest running?
low-Medium (inconsisent)bite/medium size/damp-wet
Usually most run panther slicks, running panther rears/slicked proline fronts
Old 11-19-2014, 07:39 AM   #11124
MikeXray's Avatar
Trader Rating: 73 (100%+)
Sounds like your tire compound, or prep are not in the right ballpark.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 11-19-2014, 08:48 AM   #11125
3srcracing's Avatar
I thought the same thing, but the same tires on my B5M is pretty good. And that is using the same sauce also.
Old 11-19-2014, 03:32 PM   #11126
Holmberg418's Avatar
Try different diff tightness. It changes a lot how the car drives in and out of the corner.
Kyosho America, Lunsford, Stickit1racing, Jconcepts, JTP
Full Throttle R/C Raceway www.ftrcr.com
510 Raceway
Holmberg418 is offline   Reply With Quote
Old 11-19-2014, 03:35 PM   #11127
hairymuffin's Avatar
Trader Rating: 93 (100%+)
Default setup
[QUOTE=3srcracing;13667723]Looking for a setup to lead me in the right direction..
take all the bottom screws out..also ad more toe if you have the adjustable rear hangers..i always ran d-in/d in be cause most were running it..i now run c in c in..or even b in..most will say thats way too much toe? who cares,as long as it works..mycar still has tons of steering..but screws out the bottom motor cage and side guards..also hubs all the way forward.. i run kings setup from the 2014 rroc plus zachs 17.8 mod and.. in my mod buggy i added weight,in stock no weight added
hairymuffin is offline   Reply With Quote
Old 11-20-2014, 05:06 AM   #11128
MODELTECH22's Avatar
Trader Rating: 20 (100%+)
Hey guys just picked up a used RB6, looks to be completly box stock except frt aluminium bulk head (hinge pin holder) what do i need or change? I run on indoor medium bite clay track.
22 3.0 Hobbywing
22 2.0 W/exotek chassis TEKIN
22T 2.0 Lrp Flow
SCT 22 2.0 Hobbywing
MODELTECH22 is offline   Reply With Quote
Old 11-20-2014, 05:32 AM   #11129
tonyv2382's Avatar
Trader Rating: 64 (100%+)
Send a message via Yahoo to tonyv2382
Ran this car for the first time a few days ago and I must say, this thing is so consistent and fast and so much traction and steering. This thing is amazing my lap times are posted below, in btwn laps I was adjusting my radio as this was literally the first time I put the car down on the track, maiden voyage if you will. Fast laps are high 14s low 15s. I run on carpet and all I can say is I wanted this car for a long time and tried another brand for a while and was struggling to do a 15s lap consistently. The results speak for themselves and Im happy with the RB6. Drove the RB5 WC and loved it. Dont even know why I strayed from The big K.
tonyv2382 is offline   Reply With Quote
Old 11-20-2014, 05:41 AM   #11130
Gayosaka's Avatar
If you use the same insert front to rear, you don't change toe-in, it stays at 3 per side. You only change overall width and roll center (wider means less roll).
C in/C in is 3 degrees, as D in/D in or B out/B out.
D in front/C in rear is 3.5 degrees
C in front/D in rear is 2.5 degrees
Etc.
RedWorkShop RZ6R / Kyosho RB6.6 / Kyosho ZX6.6 / Nosram power / Some MiniZ
www.rustidesign.com - Awesome custom stickers and cool stuff
Gayosaka is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
