    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 11-12-2014, 12:42 AM   #11086
MrHistory's Avatar
Originally Posted by Jason.Dias View Post
You can certainly shim it out, but it shouldn't need more than .02mm at most, if it's really .5mm to 1mm then it sounds like something is wrong, perhaps a bearing out of place or missing. Which bearings are you using?
Thanks Jason. I realized that after I tightly mounted all screws to motor plate the slop was gone. My oversight. Thanks
On a related issue, I bought an aftermarket Yaiba motor plate for the rb6. It's 3mm thick rather than the stock 2mm plate. Two issues:
1. To run this plate where do I add a 1mm shim? My guess would be outside the brass collar on the top shaft?
2. The Yaiba motor plate has recessed motor mount holes for the motor screws which are cut on the side for rear motor assembly. When flipping it over for MM this recess is on the wrong side. I guess I could put a shim in the recess for the motor screws but wonder if this is just too funky to work properly. What a shame because it's damn pretty.
Irwin RC 1/8th Pan Car Specialists - www.irwinrc.com
SPM Competition, WRC Racing, MIP, Novarossi
MrHistory is offline   Reply With Quote
Old 11-12-2014, 12:46 AM   #11087
the jconcepts mount is 3mm and i dont shim anywhere. its a dope mount too. hella stiff.
glenng is offline   Reply With Quote
Old 11-12-2014, 01:19 AM   #11088
Trader Rating: 81 (100%+)
Originally Posted by glenng View Post
phantom
X2 for the Phantom. Little funky looking but it grows on you. Highly functional as well.
dpcardoza is offline   Reply With Quote
Old 11-12-2014, 07:04 PM   #11089
M03Racer's Avatar
Trader Rating: 33 (100%+)
Can any of you guys tell me where I can get low profile battery connectors. Not the ones connecting the battery to the ESC but the ones going into the battery itself. I have a couple of short packs and I need some low profile connectors for the application I'm doing on my buggy. The ones that come with the battery go straight up I need some that go to the side kinda like L shape not I shape.
M03Racer is offline   Reply With Quote
Old 11-12-2014, 07:18 PM   #11090
Johnn27's Avatar
Trader Rating: 71 (100%+)
I use these:
http://www.amain.com/TQ-Wire-4mm-Low...14mm-2/p238356
Johnn27 is offline   Reply With Quote
Old 11-12-2014, 07:24 PM   #11091
M03Racer's Avatar
Originally Posted by Johnn27 View Post
Thanks. That is exactly what I was looking for.
Old 11-13-2014, 05:58 AM   #11092
Originally Posted by rpboggs1 View Post
What bodies are guys running? I was looking at the Sweep Muzzle and Proline Phantom... Not overly concerned with the looks... But more performance stability.
Bulldog Gen3
potatobed409 is offline   Reply With Quote
Old 11-13-2014, 12:47 PM   #11093
tobamiester's Avatar
Trader Rating: 277 (100%+)
Send a message via AIM to tobamiester Send a message via Yahoo to tobamiester
Guys, looking at Zack Rogers's Setup, I'm trying to figure out which pills I need in RF (UMW705) and RR (UMW707) hangers - Mid Motor. Can anyone give it to me in english ? I thought I was a pretty smart person but the reference chart that comes with the hangars is blowing my mind
from a post i read earlier, I'm going with b-out on RF and RR, which i think is stock...
tobamiester is offline   Reply With Quote
Old 11-13-2014, 01:50 PM   #11094
I'm running D in/D in. I think most are too.
Old 11-13-2014, 01:56 PM   #11095
yeah i think both are 3degree of toe, but different track width, right ?
Old 11-13-2014, 03:31 PM   #11096
Trader Rating: 49 (100%+)
Yeah Toby, it changes the track width
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 11-13-2014, 03:37 PM   #11097
3srcracing's Avatar
Trader Rating: 25 (100%+)
What spring rates are they running on that setup?
Dont want to spend $40 on springs!
3srcracing is offline   Reply With Quote
Old 11-13-2014, 05:59 PM   #11098
Potoczak's Avatar
Trader Rating: 111 (100%+)
Toby I'm also running d-in and d-in at critters and my car has been working pretty good.
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 11-13-2014, 06:43 PM   #11099
8RC
8RC's Avatar
Default battery straps?
What're the best after market straps for mm cars for shorty packs and saddles? Have two cars running both setups
8RC is offline   Reply With Quote
Old 11-13-2014, 06:45 PM   #11100
8RC
8RC's Avatar
Default Rogers setup...
Running D-in D-in as well
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22957 Yesterday 12:16 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
GasGod
