    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree16Likes
Old 10-05-2012, 12:55 PM   #1096
carcrusher46's Avatar
Trader Rating: 17 (100%+)
has anyone found metal shims to replace ALL of the factory plastics, preferably red?
Kyosho makes aluminum washers/spacers in 1, 2 and 3mm thicknesses, in a couple colors:
W0145 - 3x7x1 Blue
W0144 - 3x7x2 Blue
W0143 - 3x7x3 Blue
For each of those numbers, tack on a "R" for red, or "GM" for Gunmetal. Example: W0145GM is a 3x7x1 Gunmetal. I'm not able to find the 3mm in red, but I don't think any 3mm collars are used on the RB6 at all.
I prefer to stick with the plastic washers for the suspension components because they're slipperier and less prone to binding, but the aluminum washers for ball stud adjustments since they are stronger and don't vary, and since they're not rotating parts they won't wear the plastic parts that they are touching.
Matt Stoltz
Thank you to my sponsors:
Team Associated - Reedy - JConcepts - Life Fast RC Paintworks
carcrusher46 is offline   Reply With Quote
Old 10-05-2012, 12:59 PM   #1097
transplantlife's Avatar
Trader Rating: 43 (98%+)
Originally Posted by Cpt.America View Post
I run all light blue aluminum washers on my cars... you can get them on ebay. I use 3racing and ofna. There are all kinds of colors.
man what beauty
IM A SURVIOR OF A DOUBLE ORGAN TRANSPLANT KIDNEY/PANCREAS...PLEASE BE A ORGAN DONOR TO GIVE LIFE TO OTHERS!!
transplantlife is offline   Reply With Quote
Old 10-05-2012, 01:27 PM   #1098
Trader Rating: 1069 (100%+)
As you tighten the nut, it will compress and expand the bushing inside the shock cap. Make sure they aren't so tight they bind the shock, and make sure they are equal left and right.
Well I read this before I got my kit and just put the shocks on. A: the manual says the shock bushings are 5.8mm, but all the ones in the kit are 4.8mm. B: If you tighten down the plastic nut all it will do is strip. Anyone actually measure the shock bushings and or get the correct ones? Surely if you use metal nuts you could compress them so there is less slop but I'd prefer to have the correct ones
Less warning labels... more Darwin!
EZ Customs Paint / Xtreme RC
ON ROAD: XRAY T4 '15 USVTA/USGT X1 F1 , OFF ROAD RB6
and for those that don't know me.. I'm a sarcastic A DBL S
Dave Cates Founder of www.GO-RCing.org
bigwavedave33 is offline   Reply With Quote
Old 10-05-2012, 01:31 PM   #1099
whitrzac's Avatar
Trader Rating: 95 (100%+)
Is there a compatibility list for the rb6/rb5?
whitrzac is offline   Reply With Quote
Old 10-05-2012, 01:43 PM   #1100
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Not that iv seen, but there isn't much!
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 10-05-2012, 01:46 PM   #1101
steam's Avatar
Default Alum nuts
Yeah I could not get it to work with the plastic nuts. I had to use alum nuts to get it to compress correctly.
Yokomo YZ-2, Kyosho Ultima SC-R, RT5, Airtronics M12
steam is offline   Reply With Quote
Old 10-05-2012, 01:55 PM   #1102
steam's Avatar
thats one thing i liked about the Durango, it had additional touches that oozed sexiness.
KYOW0145R - 1mm RED
KYOW0144R - 2mm RED
KYO97041-05R - 0.5 mm RED
KYO97042-15R - 1.5 mm RED
If you can find them
Old 10-05-2012, 01:58 PM   #1103
Super Moderator
You have the correct bushings... you just need to use a nut that expands the bushing, instead of stripping.
- RCSpecialties -
Old 10-05-2012, 01:58 PM   #1104
BSC
BSC's Avatar
Trader Rating: 51 (100%+)
Did anyone have trouble with the ball diff adjuster bolt being slightly to short ?
Kyosho
Team Associated
Hobbywing /SMC/LFR/AKA
www.coast2coastrc.com.au
Logan Offroad - The Brickyard
BSC is offline   Reply With Quote
Old 10-05-2012, 02:09 PM   #1105
savageboy69's Avatar
Trader Rating: 88 (100%+)
yea, if i have a chance ill find it and post it
Xray|Rc America|Hudy|FX engines|Tekin|SOR graphics|LFR|Ogio|SRT servos|
XB8 2016
XB8-E 2016
XB4 2017
savageboy69 is offline   Reply With Quote
Old 10-05-2012, 02:09 PM   #1106
Then either the manual is wrong or the correct nuts are not in the kit. Either way its incorrect. I'll switch nuts for now, but would really want the correct size bushing.
Old 10-05-2012, 02:16 PM   #1107
Rfury's Avatar
Send a message via AIM to Rfury Send a message via Yahoo to Rfury
Based on what I am seeing in the manual and the exploded diagram, the bushing is the same as the one that goes in the shock ends also goes in the shock caps as well.
Kyosho RB6
Kyosho ZX6
Kyosho MP9e TKI
Rfury is offline   Reply With Quote
Old 10-05-2012, 02:19 PM   #1108
not yet, but:
Complete transmission
Complete shocks
Rear hinge pin carriers for rear motor config
servo mounts, but not horns
screws
shims
bearings
rear arms if you like
rear carriers
turnbuckles
ball cups
ball studs
need to measure front arms, but I'm sure you could probably put the sp2 or WC front end on it
front bumper
rear wing mount
wings
CVDs
wheel hexes
hinge pins I'm pretty sure front and rear
front axles if you prefer
I know some guys are running the RB5 SP2 rear arms like tebo.
That's all I can think of off the top of my head
Old 10-05-2012, 03:44 PM   #1109
AZRC4Me's Avatar
Technically you'll need to use metal locknuts to get the shock bushing to expand. It's supposed to be loose on the shock cap, and I thought it was wrong too during initial assembly, but it's the way it should be. Just use some M3 locknuts and put an extra 1mm plastic spacer on to evenly compress the shock cap bushing. Just don't over-tighten the M3 nut, the shock should twist freely.
Sean Gaffney
...where some sponsors used to be...
AZRC4Me is offline   Reply With Quote
Old 10-05-2012, 04:52 PM   #1110
I guess you guys missed the point. A. its not correct in the manual either the part is supposed to be 5.8mm or there should be explanation in the manual to use a metal nut which is not in the kit(and I do read english and japanese), so how could you complete the car without the nuts. IMHO, there should be 5.8mm shock bushings not what others have used as a work around by compressing 4.8mm. Sure it works, but is it right for a $450 kit??? ahhhh no.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22970 10-17-2017 05:10 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
