    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 11-09-2014, 05:52 PM   #11071
Potoczak's Avatar
Trader Rating: 112 (100%+)
I have seen on alot of the setups guys are running the flat rear arms. What is the advantage of running them? Also have seen there are 3 different part numbers for the arms. Which ones are best??
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 11-09-2014, 08:49 PM   #11072
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
Originally Posted by iMarky View Post
My new electronic set up. . Mr clean status
Before
After
Want to do mine after you do Travis'?
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 11-09-2014, 11:03 PM   #11073
Sure.. I have other buggies lined up lol
iMarky is offline   Reply With Quote
Old 11-10-2014, 03:51 PM   #11074
question, ive noticed on tebo's set ups that the steering drag link is turned so the arrow is facing to the rear and has moved his caster blocks back 1 mm wouldn't it be the same as having the arrow facing forward and having his caster blocks forward?
thnx Mike
Mike Richardson
At the track having fun with my friends
blingy is offline   Reply With Quote
Old 11-10-2014, 04:20 PM   #11075
K_King's Avatar
Not really. It's changing the weight distribution relative to the tires. It's shortening the wheelbase but makes it more aggressive as well.
Old 11-10-2014, 08:42 PM   #11076
3srcracing's Avatar
Trader Rating: 25 (100%+)
So does anyone have a pic of the 3rd hole drilled on the RB6 arm?
Just want to make sure I'm doing it right.
3srcracing is online now   Reply With Quote
Old 11-10-2014, 09:12 PM   #11077
thank you MR King
Mike Richardson
Old 11-10-2014, 09:18 PM   #11078
K_King's Avatar
Old 11-10-2014, 11:35 PM   #11079
Trident69's Avatar
thank you so so much..this is so much clearer..cheers for the effort!!
"Power is nothing without Control"
Yokomo - Yz-2/Yz-2 DT/ Yz-4 / Bmax2MR/Bmax 4/3
Xray - XB4'16
Awesomatix - Evo 2
Trident69 is offline   Reply With Quote
Old 11-11-2014, 10:51 AM   #11080
For those of u that are usung the MIP pucks system, do you also need the avid HD axles to run AKA/Proline/etc wheels ?
phillypete is offline   Reply With Quote
Old 11-11-2014, 11:17 AM   #11081
Potoczak's Avatar
No, the mip axles are long enough for aka wheels.
Pete Potoczak
Old 11-11-2014, 10:15 PM   #11082
rpboggs1's Avatar
Trader Rating: 19 (100%+)
What bodies are guys running? I was looking at the Sweep Muzzle and Proline Phantom... Not overly concerned with the looks... But more performance stability.
Kyosho RB6 * Kyosho ZX6 * Kyosho RT6
TLR 22SCT * TLR SCTE 2.0
Tekno NB48.3 * Tekno EB48.4 * Tekno EB48.3 * Tekno ET48.3
rpboggs1 is offline   Reply With Quote
Old 11-11-2014, 11:39 PM   #11083
MrHistory's Avatar
I searched the thread and could not find anything on this:
After assembling the transmission there is some end play in the top shaft. I just installed the new Schelle top shaft and same result. It about .5-1mm of play. Is this normal and should I try to shim anywhere to reduce this? Once I install the gear and slipper it's still there.
Irwin RC 1/8th Pan Car Specialists - www.irwinrc.com
SPM Competition, WRC Racing, MIP, Novarossi
MrHistory is offline   Reply With Quote
Old 11-11-2014, 11:58 PM   #11084
phantom
glenng is offline   Reply With Quote
Old 11-12-2014, 01:23 AM   #11085
You can certainly shim it out, but it shouldn't need more than .02mm at most, if it's really .5mm to 1mm then it sounds like something is wrong, perhaps a bearing out of place or missing. Which bearings are you using?
Jason Dias
http://www.facebook.com/jasondiasrc
Team Kyosho - AKA - KO PROPO - Hobbywing - Schuur Speed - Schelle Racing - OCRC Raceway - Tuning Haus
Jason.Dias is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22984 Today 10:14 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15026 11-02-2017 04:19 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
