    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 11-06-2014, 08:54 PM   #11056
Trader Rating: 81 (100%+)
Done. 737 pages down.
dpcardoza is offline   Reply With Quote
Old 11-06-2014, 09:55 PM   #11057
3srcracing's Avatar
Trader Rating: 25 (100%+)
Edit.
Nevermind I figured it out.
3srcracing is offline   Reply With Quote
Old 11-08-2014, 11:47 AM   #11058
tonyv2382's Avatar
Trader Rating: 64 (100%+)
Send a message via Yahoo to tonyv2382
Whats up guys. Will be running this car on carpet. Just assembled a gear diff and it seems to be sweating a bit. Ive read thebdiff has a few leak issues. Hows the ball diff holding up on carpet I know the K Ball diffs are pretty awesome and never had a problen on dirt. I do have ceramic and carbide balls to play with.
tonyv2382 is offline   Reply With Quote
Old 11-08-2014, 12:17 PM   #11059
Can't speak to much for the ball diff but so far it's been flawless for a couple weeks. I tried the gear diff and found it leaked like crazy. Lasted about a race then leaked everywhere and made a huge mess. Threw it in the part box and never looked back.
Old 11-08-2014, 01:27 PM   #11060
tonyv2382's Avatar
Ok cool. This is on carpet?
Old 11-08-2014, 05:01 PM   #11061
No, high bite indoor clay. Not saying the gear diff won't work for ya. I just could never get it to seal properly. It lasted 1 6min run and was nearly empty by the end. Took it apart and changed gaskets, same result.
Old 11-08-2014, 06:22 PM   #11062
tonyv2382's Avatar
Yup. All I did was assemble it and it isnt sealing. Noticed it starting to sweat around where the two halves meet. Hopefully kyosho fixes this issue in the near future.
Old 11-08-2014, 06:33 PM   #11063
Potoczak's Avatar
Trader Rating: 111 (100%+)
Ok... So just looking for a general answer/opinion. If I'm looking for more foward bite coming out of turns what would I be looking at to change first and so on. Running in rear motor 17.5.
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 11-08-2014, 06:40 PM   #11064
Trader Rating: 37 (100%+)
More rear toe
chrisjohns is offline   Reply With Quote
Old 11-09-2014, 01:04 AM   #11065
I've been running a gear diff (7k oil) at OCRC with great success.
To prevent leaking I used these gaskets http://www.kyoshoamerica.com/Diff-Ca...-S_p_4659.html and I put green slim on them to help seal the diff. Also put some green slim in the screw holes, and be sure not to over tighten the diff screws, I tightened them a little at a time in a cross pattern. If you over tighten the screws it will distort the plastic and diff will leak.
Also don't forget these o rings, http://www.kyoshoamerica.com/Silicon...15_p_4307.html for the outdrives.
The last thing is do not use too much diff fluid. I fill mine just below the cross shafts, basically put a few drops in each corner, work it in, and the level should be just at or below the cross shafts.
Hope this helps.
Jason Dias
http://www.facebook.com/jasondiasrc
Team Kyosho - AKA - KO PROPO - Hobbywing - Schuur Speed - Schelle Racing - OCRC Raceway - Tuning Haus
Jason.Dias is offline   Reply With Quote
Old 11-09-2014, 01:32 AM   #11066
tonyv2382's Avatar
Hope this helps.
Will gove it a go. Thank you!
Old 11-09-2014, 04:10 AM   #11067
+1 what Jason said
the biggest think is not to over fill the diff, I filled just over half way, use the cross pin as a guide. Been running 5k on carpet for 3 months no leaks but I have stripped a plastic idler gear.
Tom87 is offline   Reply With Quote
Old 11-09-2014, 05:35 AM   #11068
I used gasket sealant either side of the paper gasket and no leaking what so ever
Headling is offline   Reply With Quote
Old 11-09-2014, 11:48 AM   #11069
tonyv2382's Avatar
Tried this. I think overfilling is definitely the issue. Seems leak free as of now time will tell. I guess the proper oil level would be just above the bevel gear under the cross pins. On my TRF diffs which are pretty much bomb proof and leak proof, the trick was sanding each half of the diff case. I did that so that it is a more rough surface where thet meet instead of a "finished" slippery surface which I believe may help contain more oil.
Old 11-09-2014, 03:41 PM   #11070
My new electronic set up. . Mr clean status
Before
After
iMarky is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
