    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 11-04-2014, 09:04 AM   #11041
Originally Posted by CoryD View Post
Have you tried MIP pucks? Gord Tessmann suggested I try them as the RB6 has a lot of dog-bone plunge which he thinks causes extra friction and fights the suspension compression on-power. I switched over to the MIPs and it was a lot better; the car actually squatted.
Give it a try.
Regards,
I will probably in the future but trying to stay close to stock right now. I have a SC6 that is nearly stock and runs very well. It has the kit setup.
Vincent_Diesel is offline   Reply With Quote
Old 11-04-2014, 12:57 PM   #11042
So how will the MIP pucks system eliminate dog bone plunge?
potatobed409 is offline   Reply With Quote
Old 11-04-2014, 03:32 PM   #11043
Trader Rating: 81 (100%+)
Can someone advise me on bang for your buck weight savings. I'm running stock 17.5 and need to trim some weight. It's pretty obvious that I could easily spend 2-300 dollars in lighter parts so what is the top 3 or so.
dpcardoza is offline   Reply With Quote
Old 11-04-2014, 05:21 PM   #11044
Potoczak's Avatar
Trader Rating: 111 (100%+)
Light weight chassis, mip pucks system, titanium screw set.
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 11-04-2014, 05:31 PM   #11045
rpboggs1's Avatar
Trader Rating: 19 (100%+)
Doesn't eliminate plunge just the friction. The plastic pucks slide nicely on the outdrives. Noticeable difference in performance. Probably the best investment one could make to a 17.5 buggy.
rpboggs1 is offline   Reply With Quote
Old 11-04-2014, 05:44 PM   #11046
Trader Rating: 16 (100%+)
Originally Posted by Vincent_Diesel View Post
Ran last weekend with a shorty battery all the way forward with ESC between motor and shorty pack. I was struggling for traction in MM -- B5Ms seemed to be doing well on same conditions. I do not want to go RM because I feel it doesn't fit my driving style -- besides at our track MM is the rage right now.
I am running the latest Kevin King MM setup with new drilled shock location.
I run the shorty and esc motor config myself and my buggy wheelies out the corner at times. Recently went back to mid and added a shim for anti squat (under the front hing pin holder), along with the brass weight on the rear of the bulk head.
Larry Bromell
Mugen/REDS/AKA/MKS/Orion/Flashpoint
jaron_cc is offline   Reply With Quote
Old 11-04-2014, 10:15 PM   #11047
3srcracing's Avatar
Trader Rating: 25 (100%+)
What setup would you guys suggest running for a damp-wet track, low-medium bite.
Stock setup feel... egh okay, but hard to drive, and feels like you have drive it fragile. My friend said his car sucks up here, but at the other track it's on rails...
Would you go Zach Rogers setup?
I just put the RB5 arms on and it helped a little, but still not the locked in feeling I'm looking for.
3srcracing is offline   Reply With Quote
Old 11-05-2014, 12:33 AM   #11048
Does the Lunsford Punnisher Ti Turnbuckle kit offer much weight savings? Can't find any information on it but seems like it should.
Old 11-05-2014, 03:40 AM   #11049
Potoczak's Avatar
Yes the Lunsford kit would be another good weight saver.
https://www.lunsfordracing.com/mm5/m...e=CARS-KYULRB6
Pete Potoczak
Old 11-05-2014, 05:44 AM   #11050
Thanks. I can't seem to find how much weight it saves but it seems like it should be significant. The punnisher w/o the ball cups is only about $27 at amain. My stock build with shorty lipo is running about 1630g and I'd like to shave off enough weight to hit the mid 1500's to provide some flexibility to run saddle packs if I want. Also not trying to break the bank. If I had about $300 to spend it would be easy but trying to do it for around a hundred is much more difficult. Is 14g wire okay to use on a 17.5 esc/motor? That might be a cheap way to drop some weight as well.
Old 11-05-2014, 02:31 PM   #11051
3srcracing's Avatar
Also to try to run the Zach Rogers setup, if I wanted to run cheaper springs..
What spring rate are the:
Kyosho Gold rears
and
Kyosho pink fronts
Old 11-05-2014, 04:05 PM   #11052
Trader Rating: 14 (100%+)
Kyosho Gold rears
and
Kyosho pink fronts
http://www.petitrc.com/setup/kyosho/...Bore/Chart.pdf
Here's a chart for ya bud.
RBraswell is offline   Reply With Quote
Old 11-05-2014, 04:45 PM   #11053
What effect of any does motor size have on a setup? I mostly run stock 17.5 on sticky indoor clay and most setups, even ones with similar track characteristics use 7.5t motors. Just curious if those should get me closer still.
Old 11-05-2014, 10:04 PM   #11054
E73
E73's Avatar
I run 17.5 but have the same setup as the mod guys: oil, springs, ballast etc. A good setup should serve well in both classes in my limited experience.
E73 is offline   Reply With Quote
Old 11-06-2014, 05:58 AM   #11055
rpboggs1's Avatar
From what I understand, serious mod guys will typically start off with a 13.5 at a new track to make it easier to dial in their setups before switching to the more aggressive motor... so it shouldn't make much of a difference.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22940 Today 03:24 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
tel
