    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 10-28-2014, 03:42 AM   #10981
Originally Posted by gelshocker View Post
Not as much as I would like. I was meant to say hello (your car is the red/black fade one right?) but I caught myself in a really shitty mood. The track at Lali is 1/8 scale one needs more traction than steering. Service everywhere in HK is like that, take it as the local culture! Cheers,
Ahhh! I saw an RB a few weeks ago. Can't remember the colour though :S Yes agree with more traction than steering. Crazy camber link configuration on the rear of my VBC Firebolt. Do say hi next time bro! Red/Black fade is my practice shell on the Firebolt.
On-Road - Xray T4'17 / Serpent 4-X / Tamiya Exo6 / Roche P10 & P12 & F1
4WD - Kyosho ZX6 / Yokomo YZ4 *** eBuggy - Tekno EB48SL
2WD - AE B5M (XFactory Chassis) / Kyosho RB6 / TLR 22 2.0 / Yokomo YZ2
SCT - Tekno SCT410 / Losi 22SCT 2.0
ST - Losi 22T 2.0
WagwanBumba is offline   Reply With Quote
Old 10-28-2014, 05:52 AM   #10982
Originally Posted by K_King View Post
For me if I put the shims on top I feel like it doesn't dump over as much on entry.
"Moving the Steering Spindle Up and Down changes two things:
It changes the Total down travel your front end has. More Down travel in the front will give you more predictable landing off of jumps. It will also give you less steering as you exit the corner on power. Less Down Travel in the front will make your car less predictable landing off of jumps, such as sticking into the dirt like a lawn dart if you land extremely nose down. The advantage of less down travel is increased corner exiting steering when you are on power. I like to use this adjustment to quickly see if increasing or decreasing the downtravel in my shocks will provide the corner handling that I desire.
The spindle height will also change the amount of bump steer your car has. Lowering the spindle will give the front end more Bump-In. Raising the spindle will give the front end more Bump-Out. This is if you do not add or take out any washers under the steering ball end. Bump-In will give you more steering entering and through the corner. It will also make your car feel more aggressive to initial steering inputs. Bump-Out will give you less steering entering the corner but more through and exiting the corner. So in high speed sweepers Bump-Out will give you a more consistent steering “Feel”. Bump-Out will also dull some of the initial steering inputs. I personally like to use Zero bump in or out. So if I change the height of the spindle I have to add or subtract shims from under the ball end to keep the Bump at Zero."
Thanks for the reply Kevin. So if I change spindle height then readjust bump and droop as before then there should be no difference in how the car behaves?
potatobed409 is offline   Reply With Quote
Old 10-28-2014, 06:49 AM   #10983
Originally Posted by WagwanBumba View Post
As for the B5Ms you say that were still on the ball when the track went, do you know what setups they were using?
Im not sure if hes using a specific set up from a team driver. Hes not sponsored by AE but I know hes pretty close with some of the sponsored drivers. As for the 22 in RM, my sons 22 used to be awesome in RM, we were both set on trying MM and I just couldn't get his 22 to work in MM, tried JP Richards set up, Dakotahs set up. This was all before Maifield came over, not sure if his set ups would have worked but I know hes doing things no one else did.
CaseyD is offline   Reply With Quote
Old 10-28-2014, 07:39 AM   #10984
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
No, there will be. Remember it will be like changing the droop on your shocks, and you will have to adjust your ride height each time.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 10-28-2014, 08:25 AM   #10985
3srcracing's Avatar
Trader Rating: 25 (100%+)
I had the same issue back in RB5 days. The idea is to hold and 'lock down' the nut with an allen key, with the key itself held across the outdrive (slip it into the outdrive grooves). With your remaining 3 fingers grasp the entire diff.
With a _long_ flat head screwdriver, screw the diff screw into the nut. I bought a long flat head screwdriver for this one purpose only. Try to keep the screw straight.
The plastic nut piece can only be removed without breaking the ears off by inserting an allen key through the opposite side of the outdrive and pushing it (slowly) out. Get the Exotek diff nut.
Hope this works out for you. Never had a problem since. Cheers,
Ill have to try that out next time. Unfortunately when I was pulling the nut piece out it did break. Is there an alternative to that piece (different brand or something). Or should I just order the Kyosho one and wait?
3srcracing is offline   Reply With Quote
Old 10-28-2014, 08:27 AM   #10986
AlanHall's Avatar
Trader Rating: 43 (100%+)
Send a message via AIM to AlanHall Send a message via Yahoo to AlanHall
Originally Posted by CaseyD View Post
Our track is sometimes unpredictable, some days the traction is sic, some days we cant seem to get the moisture just right and it gets super dry and dusty. In this order is where the cars fall off;
Pre-Maifield setups 22's in MM were the first cars to start getting loose,
Next were our RB6s in MM
And last, some how the B5Ms would still be hooking up.
Not sure where the Maifield set ups are going to fall in, no one at our track uses his setups, that I know of. The 4th hole mod and adding 50+ grams is very interesting.
All this talk about the new hole on the RB6 arm started for our track when Zack was trying to find the traction the AE had when the track went away.
Everyone at my track runs Rear setups. I'm 1 of 3 people with kyosho and the b5s are always way more hooked up then our cars. Probably the fastest guy there has a rb6 but he's struggling for traction ad is winning mostly cause his skill level is higher. But he's doesn't seem to exciting with it .
I'm dieing for more traction and have a few things to try I discussed on the Kyosho FB page . Where was the discussion of adding the 50 grams ?
Alan Hall
AlanHall is offline   Reply With Quote
Old 10-28-2014, 08:49 AM   #10987
Hmmm ... all this talk of the B5 being more hooked ... maybe I'll get some more bits for the B5 and spend some more time setting it up
ST - Losi 22T 2.0
Old 10-28-2014, 10:25 AM   #10988
gelshocker's Avatar
http://www.exotekracing.com/rb6-alloy-diff-nut/
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 10-28-2014, 11:08 AM   #10989
I was referring to Maifields set ups. He's running both side pod weights, the brass front rear suspension holder and weights next to his battery. That has to weigh 1750+ grams
Old 10-28-2014, 11:46 AM   #10990
Originally Posted by blingy View Post
Does anyone know where i can buy a bulk amout (25-50) metal 1mm spacers like for our ball studs? Thnx
Does anyone have an idea ?
Mike Richardson
At the track having fun with my friends
blingy is offline   Reply With Quote
Old 10-28-2014, 12:51 PM   #10991
AlanHall's Avatar
Hmm maybe that will help with my traction issues
Alan Hall
Old 10-28-2014, 03:28 PM   #10992
3srcracing's Avatar
What pistons are most running for medium bite track?
It seems like most are running either
1.4x3/1.6
1.4x3/1.4x3
55x2/55x2
or 1.6/1.5
What would you recommend?
Also 32.5/27.5 or 32.5/30?
Old 10-30-2014, 03:36 AM   #10993
1.4x3/1.6
1.4x3/1.4x3
55x2/55x2
or 1.6/1.5
Front 3x1.4 TLR 32.5
Rear 2x1.6 TLR 27.5
Old 10-30-2014, 03:44 AM   #10994
I came from the 22 2.0 and the cars feel similar on rear traction. The RB6 has more steering, which I have tamed down with the Schelle rack running outside hole. The Maifield setup on the 22 with all the extra weight really helped the car with traction and was by far the best setup I used on the 22. I'm running a shorty in the RB6 with the battery against the motor then added weight to the backside of the battery to equal a saddle pack but with the extra weight towards the motor. I really want to add the weight with a RF hanger made from brass like there using on the 22. That placement made the most difference on the 22.
Old 10-30-2014, 06:29 PM   #10995
Trader Rating: 81 (100%+)
Not necessarily rb6 related but anybody have an opinion on the D4 Maxzilla 17.5 vs the Fantom Ion w/12.5 mm high Torque rotor? I've read good things about the apex but it appears they are no longer available. Will be running 17.5 blinky.
dpcardoza is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
