    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree15Likes
Old 10-27-2014, 05:15 PM   #10966
KalEl63's Avatar
Originally Posted by potatobed409 View Post
+1
Also, has anyone played around with moving the front c-hub up and down and what the benefits are? I moved them up and down this past Sunday and it seemed the higher I went the more turn in it had. I'm not sure if that's the case because the traction was coming up as the sun went down.
It adjusts the roll centre this is how I understand it but could be wrong.
LOWER ROLL-CENTER - More shims at the top - Recommended for rough track to gain stability.
HIGHER ROLL-CENTER - More shims at the bottom - Recommended for smooth track to gain more steering.
Team Associated RC10 B6D
Team Associated RC10 B64D
Team Associated RC10 T5M
1.21 GIGAWATTS!!!
KalEl63 is offline   Reply With Quote
Old 10-27-2014, 05:33 PM   #10967
rchogfan's Avatar
Originally Posted by KalEl63 View Post
One of our stock racers at our club says the MIP Puck system is worth the investment as he runs it in his 22 so I figure it must be good as this guy is a no gobbledygook guy.
So I’m looking at putting it in my RB6 and don’t know much about it so after some input/advice. (didn’t see any info on the front page but could have easily missed it)
I am also looking at putting the 97030 Kyosho 3/32" Tungsten Carbide Differential Ball (Since the MIP system only comes with Chrome Steel Ball) or can anyone recommend other 3/32” balls for the diff?
Plus I’ll put the AVID 2.6x6x3mm Kyosho Differential Thrust Bearing (Tungsten Carbide)
Do u race mod or stock? They make one for 17.5 that is lighter but would break under a mod motor. A buddy of mine just ordered one. He spoke very highly of it. It Makes the car smoother as it eliminates all slop from drive shaft.
**CALVIN BRUCE**
MUGEN SEIKI MBX7 ECO - TEKIN GEN 2 RX8 1900T8 | MUGEN SEIKI MBX7 - ALPHA LUTZ WORLDS | B5M CE - TEKIN RSX - 9.5 | 2015 XB4 - R10 PRO - 6.5 |
rchogfan is offline   Reply With Quote
Old 10-27-2014, 05:41 PM   #10968
3srcracing's Avatar
Trader Rating: 25 (100%+)
What insert do you use in the front casterblock?
3srcracing is offline   Reply With Quote
Old 10-27-2014, 06:17 PM   #10969
rchogfan's Avatar
caster block position is iN. (wide/standard). I've never adjusted it.
**CALVIN BRUCE**
Old 10-27-2014, 06:21 PM   #10970
Trader Rating: 22 (100%+)
Originally Posted by 3srcracing View Post
What steering rack is the best to get/cheapest.
The best to me is the schelle racing. The cheapest would be exotek.
littleZEN is offline   Reply With Quote
Old 10-27-2014, 07:27 PM   #10971
KalEl63's Avatar
Yeah I will be racing stock 17.5T.
That's the same thing said to me from our club member
1.21 GIGAWATTS!!!
Old 10-27-2014, 08:03 PM   #10972
Has anyone tried to run the RB6 MM on on medium hard pack but with some loose loam? Just bought a B5 but don't really like the look of it. Did also think about the TLR22. Having a hard time picking between the 2!
On-Road - Xray T4'17 / Serpent 4-X / Tamiya Exo6 / Roche P12 & F1 / Schumacher Mi6Evo / Awesomatix A800 / Xpress XQ1
4WD - Kyosho ZX6 / Yokomo YZ4 *** eBuggy - Tekno EB48SL
2WD - AE B5M (XFactory Chassis) / Kyosho RB6 / TLR 22 2.0 / Yokomo YZ2
SCT - Tekno SCT410 / Losi 22SCT 2.0
WagwanBumba is offline   Reply With Quote
Old 10-27-2014, 08:55 PM   #10973
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
+1
For me if I put the shims on top I feel like it doesn't dump over as much on entry.
"Moving the Steering Spindle Up and Down changes two things:
It changes the Total down travel your front end has. More Down travel in the front will give you more predictable landing off of jumps. It will also give you less steering as you exit the corner on power. Less Down Travel in the front will make your car less predictable landing off of jumps, such as sticking into the dirt like a lawn dart if you land extremely nose down. The advantage of less down travel is increased corner exiting steering when you are on power. I like to use this adjustment to quickly see if increasing or decreasing the downtravel in my shocks will provide the corner handling that I desire.
The spindle height will also change the amount of bump steer your car has. Lowering the spindle will give the front end more Bump-In. Raising the spindle will give the front end more Bump-Out. This is if you do not add or take out any washers under the steering ball end. Bump-In will give you more steering entering and through the corner. It will also make your car feel more aggressive to initial steering inputs. Bump-Out will give you less steering entering the corner but more through and exiting the corner. So in high speed sweepers Bump-Out will give you a more consistent steering “Feel”. Bump-Out will also dull some of the initial steering inputs. I personally like to use Zero bump in or out. So if I change the height of the spindle I have to add or subtract shims from under the ball end to keep the Bump at Zero."
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 10-27-2014, 09:33 PM   #10974
Our track is sometimes unpredictable, some days the traction is sic, some days we cant seem to get the moisture just right and it gets super dry and dusty. In this order is where the cars fall off;
Pre-Maifield setups 22's in MM were the first cars to start getting loose,
Next were our RB6s in MM
And last, some how the B5Ms would still be hooking up.
Not sure where the Maifield set ups are going to fall in, no one at our track uses his setups, that I know of. The 4th hole mod and adding 50+ grams is very interesting.
All this talk about the new hole on the RB6 arm started for our track when Zack was trying to find the traction the AE had when the track went away.
CaseyD is offline   Reply With Quote
Old 10-27-2014, 09:37 PM   #10975
3srcracing's Avatar
Built the car, with the most part no problems. Messed up the steering, need to go back and take a look at it.
And I couldn't build the diff so save my life. For some reason no matter what I did I couldn't get the bolt to thread on the nut (in the insert). Originally thought it was the wrong nut, so I took it apart to see nope threads right on. What might I be doing wrong? Double triple checked to make sure everything is assembled correctly. (never had diff issues before this)
Thanks in advance.
Pulled apart and compressed the spring some more. Still the same thing. Couldn't get the tnut piece out and broke the stupid thing. And still stuck in the outdrive. Hope tomorrow I can get it out without ruining the outdrives. About to give up on this car already.
Old 10-27-2014, 11:50 PM   #10976
This is really interesting. Well at the track I'm at, I've got my MM Firebolt pretty hooked up. Could do with some more steering. But its the RM guys that are dominating the races so really want to try the TLR22/RB6 in RM configuration. The B5 I have is RM.
As for the B5Ms you say that were still on the ball when the track went, do you know what setups they were using?
Old 10-28-2014, 01:22 AM   #10977
gelshocker's Avatar
Thanks in advance.
I had the same issue back in RB5 days. The idea is to hold and 'lock down' the nut with an allen key, with the key itself held across the outdrive (slip it into the outdrive grooves). With your remaining 3 fingers grasp the entire diff.
With a _long_ flat head screwdriver, screw the diff screw into the nut. I bought a long flat head screwdriver for this one purpose only. Try to keep the screw straight.
The plastic nut piece can only be removed without breaking the ears off by inserting an allen key through the opposite side of the outdrive and pushing it (slowly) out. Get the Exotek diff nut.
Hope this works out for you. Never had a problem since. Cheers,
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 10-28-2014, 01:29 AM   #10978
gelshocker's Avatar
Plenty of folks run the 22 at Lali you can get setups from them. Cheers,
Kyosho RT5 | RB6
Old 10-28-2014, 01:43 AM   #10979
Hey gelshocker. Are you at Lali sometimes? Don't want to pick a car and swipe a setup from someone. I'm trying to learn how to setup a car to my own liking so it doesn't matter too much if guys there are running them or not. The downer for the TLR22 is that service from Jet Hobbies is real bad!
Old 10-28-2014, 03:07 AM   #10980
gelshocker's Avatar
Not as much as I would like. I was meant to say hello (your car is the red/black fade one right?) but I caught myself in a really shitty mood. The track at Lali is 1/8 scale one needs more traction than steering. Service everywhere in HK is like that, take it as the local culture! Cheers,
Kyosho RT5 | RB6
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22967 Yesterday 06:47 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
