    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 10-05-2012, 10:26 AM   #1081
t8rtot's Avatar
Trader Rating: 14 (94%+)
look down into the hole on the otherside and get them lined up.. its just high tolerance fit.
it took me like 15mins of playing, then it went in snugly. put the screw in and boom-- butter.
Sfida
t8rtot is offline   Reply With Quote
Old 10-05-2012, 10:28 AM   #1082
t8rtot's Avatar
another thing that may help is to put your 1.5mm driver into the other side, all the way thru (w/ the pin out) then wiggle it in a circular motion to line it up. then put the pin thru, pushing the driver out. that is how i did it exactly.
Sfida
Old 10-05-2012, 10:36 AM   #1083
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
edit.. wait.. what's the issue? Why do you have the 2.5mm cap screw in before the hingpin? You put the hing pin in through the arm first, the long end sticking out the front of the car... then make sure the flat spot lines up with the set screw in the middle... and THEN you cap off the other end with the 2.5 so the pin cant come out.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 10-05-2012, 10:51 AM   #1084
gelshocker's Avatar
Guys thanks for the responses. So I put the cap screw in first - and a wrong 3x6 screw! So I am guessing the cap screw hole and nub at the end bulged out excessively, causing the hole that will carry the hinge pin to narrow.
Had a quick look at the rb5 to confirm, out came the xacto, took off the protruding plastics and nub, reamed the arm holes smooth, including the sus holder (chewy type plastic, took a while). Sanded the face of the holes smooth. Slop was the last thing on my mind it was binding so bad!
Much better now. Almost 2am I should build when awake! Thanks all
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 10-05-2012, 10:54 AM   #1085
savageboy69's Avatar
Trader Rating: 88 (100%+)
Originally Posted by Gitsum View Post
Did you not punch a hole in your rear tires one looks to be ballooned pretty good.
i dont punch holes in my tires normally, unless its a really dusty track, it looks like that becase the camber is way off on that side and i just got done driving it like that lol, i get impatient
Xray|Rc America|Hudy|FX engines|Tekin|SOR graphics|LFR|Ogio|SRT servos|
XB8 2016
XB8-E 2016
XB4 2017
savageboy69 is offline   Reply With Quote
Old 10-05-2012, 10:59 AM   #1086
Super Moderator
Yeah, you got that one all KINDS of wrong. Hing pin first, then set screw, then tiny 2.5mm screw to cap off the end so the pin can't come back out. You forced a 3mm by 6mm screw into the 2.5mm hole?
- RCSpecialties -
Old 10-05-2012, 11:06 AM   #1087
gelshocker's Avatar
Yeah it's hard to notice and feel when you're half asleep This six is so cool the adrenaline is keeping me up. Cheers! zzzzz
Kyosho RT5 | RB6
Old 10-05-2012, 11:06 AM   #1088
hoping for round 2 at the track tommorow(if work permits, damn railroad) im gonna bring a shorty pack to try also and see how it compares vs the saddle packs, im assuming the saddle packs would have less body roll than the shorty because they weight is distributed over a wider area, but i could be wrong. ill let everyone know my findings
XB8 2016
XB8-E 2016
XB4 2017
Old 10-05-2012, 11:09 AM   #1089
Super Moderator
Oh no, I know exactly what it's like! I took 3 benedril right before I started my build yesterday (extreme allergy attack). Took me 8 hours to get through just the front end, before you start the diff. At one point I realized it took me almost 30 minutes just to turn the page after I was done with the last step of the previous page.
- RCSpecialties -
Old 10-05-2012, 11:11 AM   #1090
t8rtot's Avatar
ha good catch.
i made a rule to myself, no building after 1030. that way i'm not tired and i can coherently recall what/why i was doing things the way i did the next day.
unless i have a race coming up the next day.. thats a whole other story
Sfida
Old 10-05-2012, 11:45 AM   #1091
gelshocker's Avatar
Originally Posted by t8rtot View Post
ha good catch.
You know those metal pillars that go through the steering rack? So here I am frantically trying to mount it to the chassis, going over the 6(?) holes in the front plate. Won't fit no matter what I try. Go back to the manual, and it's suppose to fit right through FLUSH to the bulkhead! I mean when you're not awake even your common sense goes out the window.
Mistakes not only happen they compound over each other. But I won't go into that. Sorry, back to the rb6 topic.
Kyosho RT5 | RB6
Old 10-05-2012, 11:51 AM   #1092
Super Moderator
Quick, somebody take the RB6 away from gelshocker before he does more damage! Go get some sleep man
- RCSpecialties -
Old 10-05-2012, 12:03 PM   #1093
t8rtot's Avatar
has anyone found metal shims to replace ALL of the factory plastics, preferably red?
thats one thing i liked about the Durango, it had additional touches that oozed sexiness.
Sfida
Old 10-05-2012, 12:53 PM   #1094
Super Moderator
I run all light blue aluminum washers on my cars... you can get them on ebay. I use 3racing and ofna.. there are all kinds of colors.
- RCSpecialties -
Old 10-05-2012, 12:54 PM   #1095
Super Moderator
I run all light blue aluminum washers on my cars... you can get them on ebay. I use 3racing and ofna. There are all kinds of colors.
- RCSpecialties -
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
