Kyosho Ultima RB6 & RB6.6 Car Thread
Get the shelle steering rack that has the extra outer hole. It has bearings and works nice.
And use the outside hole as well
Anyone every try more droop up front? I'm curious what it would do....
I'm using tlr 30wt front 27.5wt rear with losi 56 pistons. The other common setup is same wt oil with 1.6 pistons. Gold rear pink from springs. Most of the drivers at my track have drilled an extra hole on the rear a arm to make the rear shocks set up a little more. Check Zack Rogers setup on petitrc. I can't post links yet lol.
What is needed to put regular hexes in the front. What parts are needed??
I've softened the front pistons and oils (never the springs which makes me want to revisit this again) to try and get the best of both worlds but so far, i have always ended up going back to 20 or 20.5 with the medium eyelets. I just make sure I land a little nose higher than normal. I race on a tight track so sharp and consistent steering is the only way to be on pace.
I ran more front droop for a while. It gave the car more overall steering especially as you get on the throttle on exit, almost too twitchy in some cases. It def landed jumps better and was more stable on the brakes. I basically ran the same shock length in the front but put on TLR 22 eyelets and spring cups. This was on my other rb6 with the stick chassis. My current car has the light weight chassis and I have not tried it with this chassis.
I went to the inside hole on the arm and med shock ends. It gave more over all steering but it didn't have the initial steering like outside on the arm. But you can change the front link to get some back.
Amazon has the roller for $330. Isn't that a pretty decent deal since everywhere i see them going for over 4?
With prime you can have it thursday.
That's a great deal actually.
Definitely new. Sold direct by Amazon. Part numbers match.
http://www.amazon.com/Kyosho-ULTIMA-...rds=kyosho+rb6
