    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 10-09-2014, 11:48 PM   #10891
ColbyRichards's Avatar
Another view
Retired
ColbyRichards is offline   Reply With Quote
Old 10-10-2014, 12:13 PM   #10892
RC Juice's Avatar
Trader Rating: 140 (100%+)
So I just picked up an RB6 from a member here and am confused on something.
The front hinge pin brace (aluminum aftermarket) is worn real thin from rubbing on the ground and I want to replace it. It came with a spare aluminum one (factory Kyosho) but it isn't wide enough. The car has an aftermarket front mounting block, but in all the research I've done I cannot find any setup that is for any reason wider than the stock setup. The only one with different widths are for the rears. The one I have on the car is considerably wider than the replacement one, any ideas as to what may be on the car?
RC Juice is offline   Reply With Quote
Old 10-10-2014, 12:20 PM   #10893
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
That shorter one is for the RB5. It uses a narrower pivot and longer arms.
K_King is offline   Reply With Quote
Old 10-10-2014, 12:34 PM   #10894
RC Juice's Avatar
So there is only one option for the RB6 as far as width?
Old 10-10-2014, 02:38 PM   #10895
RC Juice's Avatar
Just did a little more digging, and it appears that the plate I have is in fact the RB6 one. Here is an Ebay link to the exact same one I have.
http://www.ebay.com/itm/Kyosho-rb6-f...item3387d83dc3
So now I'm still confused as to what I have on my RB6.
Old 10-10-2014, 02:57 PM   #10896
KalEl63's Avatar
Anyone used/using the carbon composite parts and what are they like for durability?
Team Associated RC10 B6D
Team Associated RC10 B64D
Team Associated RC10 T5M
1.21 GIGAWATTS!!!
KalEl63 is offline   Reply With Quote
Old 10-10-2014, 09:48 PM   #10897
I am using all carbon composite parts in my mid motor RB6 that I have only for carpet...they parts are really tough I must admit! Lighter, less flex and as strong as the plastic items
nitroargi is offline   Reply With Quote
Old 10-11-2014, 12:38 AM   #10898
Who sells the best carbon towers for the 6? Want a set for my MM car.
Schuurspeed / Aero-model / Gear One / LG1
www.OHRCR.com
Gitsum is offline   Reply With Quote
Old 10-11-2014, 05:54 AM   #10899
Potoczak's Avatar
Trader Rating: 111 (100%+)
The exotek ones are nice.
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 10-13-2014, 06:26 AM   #10900
gelshocker's Avatar
Hi guys, would you have the new part number for the UM700 main chassis with revised battery mount holes? I'm trying to get my supplier to order it but the UM700 comes up as the old original chassis. Thanks,
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 10-13-2014, 07:18 AM   #10901
Trader Rating: 21 (100%+)
Anybody know an alterative to a Xgear yellow front?
Kyosho Rb6.6
Kyosho ZX6.6
Kyosho Rt6
kerby is offline   Reply With Quote
Old 10-13-2014, 07:19 AM   #10902
http://www.diggitydesigns.com/products_Kyosho_RB6.html
Kyosho Rb6.6
Kyosho ZX6.6
Kyosho Rt6
Old 10-13-2014, 08:58 AM   #10903
Going to do some 1/10 indoor soon.
What parts would be good to have in my toolbox?
Sworkz
T-PRO
Sanwa
Nosram
mwrccars.at
Magnus F is offline   Reply With Quote
Old 10-13-2014, 06:41 PM   #10904
ThePanda's Avatar
Trader Rating: 64 (100%+)
I would keep a few arms in your box, as well as steering parts and rear hangers, if yours aren't aluminum. Having a few outer suspension parts like hubs, and caster blocks would be good too. always good to have a few extra bearings too (not that bearing fail, but just in case)
ThePanda is offline   Reply With Quote
Old 10-13-2014, 06:54 PM   #10905
+1 on rear hangers, aluminum, even better. Additionally, an extra servo horn and although you will not need it right away, an extra front bumper is handy to have. The kit comes with extra ball cups which is nice.
Naxn is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
sho yoshida
