    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree15Likes
Old 09-28-2014, 10:43 PM   #10861
MikaR's Avatar
Separately. I believe SC6 has it stock, but not RB6.
http://modelcartuning.simplesite.com/
MikaR is offline   Reply With Quote
Old 09-28-2014, 11:01 PM   #10862
Teufel Racing's Avatar
Trader Rating: 28 (100%+)
Originally Posted by MikaR View Post
Tried Zack's setup indoors on turf yesterday and it was my first time indoors. It was great. I tried many different used tires left from the summer. Holeshots and handlebars rear seemed fine, rebar front. I also used the soft sway bar. Anyone noticed it's a bit too long? I cut it on both ends a bit. Mistake? Well anyways the car felt really nice. Had only stock springs so I gonna do that change yet. I had a new Tekin gen 2 8.5 conbo as well but had terrible cog issues. Tried everything, no relief. The motor worked well with my Orion r10 pro (own two rb6 cars). I guess I need to send it back to Amain for a change. Radio is a new MT-4S.
By chance, did you get any of the wires on the motor soldered backwards with the Tekin? I know someone that had a similar issue, and that's what the culprit was. Guy swore he soldered everything up right, and had two of the wires backwards causing the cogging. Just a thought.
That is correct, the Sc6 has it, but not the RB6. Pretty cool they did that, just wish they would have done they on the buggy as well. Maybe that'll be something they'll do with future kits.
J.Mikoliczyk
RB6 - MBX7R Eco
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is offline   Reply With Quote
Old 09-28-2014, 11:21 PM   #10863
MikaR's Avatar
I wish I were, but checked it like 10 times and it was supposed to be correct, thanks. When I changed to Orion ESC it worked properly instantly. I did the connections again for the Tekin ESC, re-checked A, B, C wires, and it cogged. Tough. I tried changin wires it didn't work at all. Also setting the timing from the ESC got the motor behaving a bit weird on full throttle.
Could it be a bad / cold solder ? All wires seem to be attached fine though.
Old 09-29-2014, 12:15 AM   #10864
you are re-calibrating the esc's when you swap back and forth yea?
glenng is offline   Reply With Quote
Old 09-29-2014, 12:34 AM   #10865
If all the wires checkout, A to A, B to B, and C to C on the Tekin and it's still cogging badly, maybe get it hooked up on the Hotwire to the computer and check that you have the ESC in the right motor mode. That would be the only other thing I could think of trying. They guys I know that run the Tekin stuff are either running the motor/ESC in Dual mode or the standard sensored motor mode. Don't remember exactly what Tekin calls the standard motor mode on the computer.
Of course, doing what the above post suggests could always help as well.
Last but not least, you can always contact Tekin and see what they have to say. Their pretty good at taking care of their customers and know that stuff inside and out.
J.Mikoliczyk
RB6 - MBX7R Eco
Old 09-29-2014, 12:41 AM   #10866
MikaR's Avatar
Thanks, I don't have the hotwire. Motor type set to bl forward/brake (setting 1 if remember correctly).
Yes, I did the recalibration in between and many times actually. Tried setting the width and adjusting the throttle midpoint from the radio, no luck.
Could it be the sensor port on the ESC ? To me it looks like that. Motor is fine. I'm consulting A-main from where I bought it a week ago if I can send it back for a change/inspection. But I will recheck the wires and soldering once I get home from work today.
Thanks folks for all the support, even this the RB6 thread. Like I said in the beginning I liked Zack's "3-hole" setup indoors
Old 09-29-2014, 12:51 AM   #10867
I think the setting of 1 should be the default correct setting. I know if the right mode setting isn't right, then it can be the cause for a lot of weird issues. Without a hotwire/computer to look at, you might be somewhat dead in the water. As for the sensor port? That could always be a possibility of being the cause or partial cause. If Amain doesn't get ya fixed up, get in touch with the folks over at Tekin and I'm willing to bet they'll get ya fixed up.
J.Mikoliczyk
RB6 - MBX7R Eco
Old 09-29-2014, 12:55 AM   #10868
Glad you liked it,
I've been running the 3rd hold mod for a while now and while not 100% exact to what Zack and Kevin King are running for setup (ESC./RX/battery and some small rear end differences), it's been a very good setup for me as well. For sure made my car better than it had been.
J.Mikoliczyk
RB6 - MBX7R Eco
Old 09-29-2014, 09:58 PM   #10869
MikaR's Avatar
Yeah, nice.
Was busy last night and hadn't time to investigate more the Tekin ESC but I got a reply from Amain that all issues are handled with Tekin directly which I will do today.
Old 09-30-2014, 07:19 AM   #10870
Is anyone running the shorty against the motor? I see most people running the shorty forward with the ESC between the battery and motor and thought running the shorty all the way back would help with rear grip. Also, is there a brass RF hinge pin housing for adding weight similar to the 22 brass weight?
potatobed409 is offline   Reply With Quote
Old 09-30-2014, 10:52 AM   #10871
LIVipers's Avatar
Trader Rating: 38 (100%+)
I'm sure it's been covered but I haven't been able to find the answer. Does anyone know the pros and cons to running a lightweight car in a 17.5 class?
LIVipers is offline   Reply With Quote
Old 09-30-2014, 11:30 AM   #10872
MikeXray's Avatar
Trader Rating: 73 (100%+)
People will argue that shorty back is more weight, but I weighed my electronics setup vs the space difference where the shorty back vs short against the ESC, and its within a few gms of each other.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 09-30-2014, 05:12 PM   #10873
ThePanda's Avatar
Trader Rating: 64 (100%+)
A lighter car will tend to have better acceleration and a little bit more on the top end in terms of speed. It will also be a better transitioning car, and you will have better in air control. There aren't many cons. The only large one being that car can be a little less stable over rough track.
Think like making your car into a lotus Elise. Not very powerful at all, but that is compensated in the less weight it has to push around, so it is still able to be quite spritely.
ThePanda is offline   Reply With Quote
Old 10-01-2014, 12:18 PM   #10874
cnelson3's Avatar
Trader Rating: 65 (100%+)
I found the same thing. Also, i was able to drop about 20 grams in "wire weight" by putting the speedo in front of the motor. Handling and jumping did change regadless of the numbers being similar.
cnelson3 is offline   Reply With Quote
Old 10-01-2014, 12:53 PM   #10875
MikaR's Avatar
Yeah, nice.
Ok this is getting clearer. Tekin support sent me a link to a youtube video how the sensor readings can be checked. My old tekin gen2 7.5 gives readings where as the new one doesn't. It blinks only once after ESC put on. The old motor works fine without cogging on the car, too. Hope to receive a new sensor board to the motor to get this up and running.
Have my shorty batt next to the motor with long wires.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22968 Today 04:05 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
05PSD
