    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 09-23-2014, 02:10 PM   #10831
vr6cj's Avatar
Trader Rating: 124 (100%+)
Originally Posted by Kraig View Post
Same here and using those nuts never had a problem.
I agree but when I try my older losi wheels even with the smaller serrated locks it wont work. Had to get the Avid axles. I also have a zx5 and the losi wheels wont fit. all the others do though with those nuts.
vr6cj is offline   Reply With Quote
Old 09-23-2014, 02:54 PM   #10832
Ostach24's Avatar
Trader Rating: 85 (100%+)
I had to make a battery strap, b44.2 ones werent long enough, maybe a shorty strap would work. I am going to send mine over to a friend to have it cut out of carbon fiber. Also need to get another back battery brace because previous owner hacked it up with a Dremel pretty good. I'll post pictures later on.
Cobra Graphics
For all your graphic design needs.
CobraGraphics.net
Ostach24 is offline   Reply With Quote
Old 09-23-2014, 06:26 PM   #10833
gelshocker's Avatar
Are you guys running longer axles, serrated nuts and aka/other rims, simply because you can't buy Kyosho's at your lhs? Or performance related? Thanks,
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 09-23-2014, 07:41 PM   #10834
hairymuffin's Avatar
Trader Rating: 93 (100%+)
the avids are longer which are better for some rims..they are much stronger too,and guaranteed not to break..you wont break the kyoshos often but they may break
hairymuffin is offline   Reply With Quote
Old 09-23-2014, 08:10 PM   #10835
Ostach24's Avatar
Picture of the battery strap wiring and pt in there. It really does have a ton of rear bite. I will have to check it at the track to know exactly how it feels.
Cobra Graphics
CobraGraphics.net
Old 09-24-2014, 05:39 PM   #10836
Originally Posted by hairymuffin View Post
does anyone know if the mip bones will fit the stock kyosho/avid bones? i want to run the aluminum bones
If the aluminum bones are anything like the pucks setup on the cup side that attaches to axle, then prolly not cuz mip uses US fractional size setscrews and such. Prolly need the whole alloy driveshaft kit if my assumptions are correct and use the mip axles. If they are
Like the puck axles, then they are good bc mip added a few extra threads on the axle. Just look up the exploded view and parts list of the alloy driveset in mip's online site to see what misc hardware they are
Using.
glenng is offline   Reply With Quote
Old 09-25-2014, 01:18 PM   #10837
will the avid top shaft fit stock trans without modification?
Old 09-25-2014, 09:07 PM   #10838
Trader Rating: 75 (100%+)
Anyone have a working link for the allaroundsetup for rear motor from petitrc? The one listed on first page doesn't load.
gixxer420 is offline   Reply With Quote
Old 09-27-2014, 03:47 PM   #10839
Try this rear motor setup, best I ran before going mid
http://www.petitrc.com/setup/kyosho/...ace2013012427/
Tom87 is offline   Reply With Quote
Old 09-27-2014, 03:48 PM   #10840
Old 09-27-2014, 06:53 PM   #10841
vr6cj's Avatar
So really loved the lookof the b5m finisher body. So much better then the rb6 finisher.
so I got one and gave it a go.
Old 09-27-2014, 07:35 PM   #10842
That looks sweet. B5m Finnisher? It looks like it fits perfect? Did you have to "make it" fit any where or is it pretty close to right on? I love how it covers all the way to the shock tower
CaseyD is offline   Reply With Quote
Old 09-27-2014, 07:55 PM   #10843
vr6cj's Avatar
Its not perfect but close to work. Just be careful to trim around spur snd front.
yeah, idk why none the rb6 bodys go to back but i like thid one, still holds with velco on front and back sides. Mid body is too wide for velcro. I used a spot of velcro on top tranny too.
Old 09-27-2014, 08:02 PM   #10844
vr6cj's Avatar
Heres underside pic i just took. U can see how wide it is but still looks awesome. U can see where the velcro holds are here to.
Old 09-27-2014, 08:24 PM   #10845
It looks like a small enough gap to deal with but I wonder if it will effect the flight while jumping?
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
