    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree17Likes
Old 09-21-2014, 02:54 PM   #10816
Potoczak's Avatar
Trader Rating: 112 (100%+)
Which body is that? Proline or j concepts??
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 09-21-2014, 06:10 PM   #10817
Ostach24's Avatar
Trader Rating: 85 (100%+)
Tell me about it, cuts off way up by the motor plate. I think I'm going to get the rb6 specific silencer and get it on there.
It's the jc silencer.
Cobra Graphics
For all your graphic design needs.
CobraGraphics.net
Ostach24 is offline   Reply With Quote
Old 09-21-2014, 06:11 PM   #10818
cnelson3's Avatar
Trader Rating: 65 (100%+)
Originally Posted by Ostach24 View Post
rb6 with a nice new shell... yes it is a b5m body, I am aware. I wanted to try to set up the batteries a little different than I have seen, just need to figure out what battery straps will work.
I ran my saddles like this for a while. you definitely get more rear grip but almost too much. i was running the newer 17.8 hole which could have been my problem and the back end was a little too soft and wouldn't put enough weight on the front end to steer. The wheelies were a little frustrating as well.
Kyosho America
Peak Racing
Trackside Hobbies & Raceway - Milwaukee, WI
cnelson3 is offline   Reply With Quote
Old 09-21-2014, 06:15 PM   #10819
Ostach24's Avatar
What did you use for a battery strap? I was thinking of trying the b44.2 straps.... Just haven't had a chance to check.
Cobra Graphics
CobraGraphics.net
Old 09-21-2014, 06:47 PM   #10820
hairymuffin's Avatar
Trader Rating: 93 (100%+)
i have seen some guys use industrial strength velcro...surprisingly it works well
hairymuffin is offline   Reply With Quote
Old 09-21-2014, 06:55 PM   #10821
cnelson3's Avatar
Strong double sided adhesive tape.
Old 09-21-2014, 08:50 PM   #10822
jt409's Avatar
I'm running a rear motor set up and looking for more steering over all expecialy off power or entry to mid part of the corner any suggestions. Thanks.
Mackinaker
jt409 is offline   Reply With Quote
Old 09-22-2014, 10:08 AM   #10823
eper's Avatar
Trader Rating: 14 (100%+)
Remove some front droop
Move some weight forward.
Drag brake
Lower front ride height
Anything that let's the car to transfer weight to front sooner
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 09-22-2014, 12:53 PM   #10824
tef
I tried that too, it drives like a rear motor car on throttle but swings around off power. If its loose ITS REAL LOOSE. If its locked in it doesnt turn.
Here is what I did to hold the battery down.
Thanks to my sponsors Kyosho America*O.S. Engines*TrakPower*Pro-Line Racing*Futaba*O'Donnell fuel*Team Scream Racing
tef is offline   Reply With Quote
Old 09-23-2014, 06:34 AM   #10825
Potoczak's Avatar
Has anyone tried to use a different brand rear axle?? Looking for longer ones. I know avid sells the extended ones but they wil be on back order for another 4 to 5 weeks. Looking for something to hold me over till then.
Pete Potoczak
Old 09-23-2014, 08:10 AM   #10826
Teufel Racing's Avatar
Trader Rating: 28 (100%+)
My first question would be why?
Use these guys:
http://www.kyoshoamerica.com/product.asp?itemid=416
And you shouldn't need a longer axle stub. I use those nuts with the stock stubs and any rear wheel and haven't had an issue yet.
J.Mikoliczyk
RB6 - MBX7R Eco
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is offline   Reply With Quote
Old 09-23-2014, 10:21 AM   #10827
Potoczak's Avatar
Use these guys:
I mainly run aka wheels and only get like 2 or 3 threads to lock on.
Pete Potoczak
Old 09-23-2014, 10:51 AM   #10828
yea the avids are perfect for the aka wheels...those style of nuts are good,better than the nylon nuts
Old 09-23-2014, 11:27 AM   #10829
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Same here and using those nuts never had a problem.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 09-23-2014, 12:15 PM   #10830
does anyone know if the mip bones will fit the stock kyosho/avid bones? i want to run the aluminum bones
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22970 10-17-2017 05:10 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
