    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 09-06-2014, 11:33 AM   #10786
SKIMAN's Avatar
Trader Rating: 17 (95%+)
Default Toe help please
Ok, so I have read all i can read about the rear toe inserts and how they adjust toe. I have a aluminum front/rear hanger and a plastic rear/rear hanger. There are 2 plastic rear/rear hangers and one is wider then the other. Im trying to figure out how much toe I have and can have using the aluminum rear/front hanger and the plastic rear/rear hanger? I have checked the petitrc site and there instructions are for aluminum/aluminum only..
Thanks for any help on this!!
john
We didn't lose the game; we just ran out of time.
Vince Lombardi
SKIMAN is offline   Reply With Quote
Old 09-06-2014, 02:59 PM   #10787
I just ordered a RT6 and I can't find any info, can someone point me in the right direction?
Eagl97 is offline   Reply With Quote
Old 09-06-2014, 04:22 PM   #10788
Potoczak's Avatar
Trader Rating: 111 (100%+)
Here you go
Introducing the Kyosho RT6!
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 09-06-2014, 04:27 PM   #10789
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
john
Ok so there are 3 aluminum hangers.
UMW511/2 are the narrow aluminum holders and are C-in/C-in
UMW514/5 are the wider aluminum holders and are Out-C/Out-C
The RB6 kit comes with UM508C RF2/RR2, which are molded plastic and are Out-B/Out-B.
If you have a plastic holder you will see a label on it to tell you which part you have.
If you have UMW511 (the narrow inner aluminum holder) and an RF2 rear you will be at C-in/B-out which is 4.5 deg of toe. Way too much angle there.
There are no differences between like holders in aluminum or plastic. It's just durability.
So when it all comes down to it, Kyosho makes 3 different types of SET holders and 1 set of adjustable holders.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 09-06-2014, 07:00 PM   #10790
SKIMAN's Avatar
Default thx
thanks king..perfect
Vince Lombardi
Old 09-07-2014, 04:34 PM   #10791
MikeXray's Avatar
Trader Rating: 73 (100%+)
can you use the 17.8mm measurement on the rb5 arms as well? or are you only drilling the rb6 arms
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 09-08-2014, 02:05 PM   #10792
Trader Rating: 22 (100%+)
Originally Posted by Jason Snyder View Post
I made a front battery stop that uses the wide holes in the front of the chassis.....let me know if you want one.
TAKE MY MONEY!!
How can i get one? Pretty please???
I'm assuming this uses the narrower rb6 battery strap and not the wider rb5 strap correct?
littleZEN is offline   Reply With Quote
Old 09-08-2014, 02:36 PM   #10793
Yea the one that you would normally use works. I sent Jason a few pics after I put mine on, maybe he'll post one later.
CaseyD is offline   Reply With Quote
Old 09-08-2014, 03:20 PM   #10794
I'll put a link up for you guys.....just upgraded my 3d printer yesterday!
I can now make em out of ABS not just PLA
Jason Snyder
Check out my "YouTube" channel
www.youtube.com/shortcourseworld
Jason Snyder is offline   Reply With Quote
Old 09-08-2014, 06:46 PM   #10795
helocat's Avatar
I see the set up sheets with reverse indicated for the steering rack. Does this mean pointing the arrow the other way? What is the advantage of going reverse?
Metal-tech 4x4 - www.metaltech4x4.com Building full size off road parts for Toyota 4x4's since 2000.
Ironman 4x4 America - www.ironman4x4america.com North America Distributor for Ironman 4x4 - Australian designed and proven off road and camping gear.
helocat is offline   Reply With Quote
Old 09-08-2014, 09:37 PM   #10796
It moves the ball stud 1mm towards the rear of the car. This allows you to run stock Ackerman position when you move the caster block back.
You can also achieve the same effect of the reverse steering rack if you use kyosho low mount ball studs (1mm lower ball stud).
Tom87 is offline   Reply With Quote
Old 09-08-2014, 09:57 PM   #10797
Yes you can... Drill another hole inside the 'loop' on the flat arms... A lot of people here in the UK have been doing this pretty soon after the RB6 came out.. Just make sure you use a spacer inside the 'loop' to add strength as you mount the shock out the back..
njc11 is offline   Reply With Quote
Old 09-10-2014, 07:57 AM   #10798
Pulse_'s Avatar
sorry to wake this thread up but there are good chances I will be purchasing an used RB6
do you have any recommendations about what I should look for on this car, any special option parts needed or mods or...?
maybe some parts which wear faster than others idk..
with which buggies does the RB6 share its wheels?
thanks in advance & hopefully I'll be able to find some tips here considering I've never raced a 2wd buggy on clay before
https://www.youtube.com/channel/UC1CAwFfuz1K3chBSVpIlSew
Pulse_ is offline   Reply With Quote
Old 09-10-2014, 08:35 AM   #10799
The RB6 uses standard Hex Wheel fitting.
Not much needs changing for option. Just run it out the Box and Enjoy.
Neil Skull is offline   Reply With Quote
Old 09-10-2014, 09:55 AM   #10800
Trader Rating: 75 (100%+)
+1 just picked up a used one as well. Never drove a 1/10 buggy.
Also whats the prefered esc/motor? Do you need a low profile servo?
gixxer420 is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22937 Today 06:57 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
