    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree16Likes
Old 10-05-2012, 08:19 AM   #1066
t8rtot's Avatar
Trader Rating: 14 (94%+)
as a tuning option, can anyone tell me what the two spacers will actually change?
http://www.speedtechhobbies.com/inde...roduct_id=1847
Sfida
t8rtot is offline   Reply With Quote
Old 10-05-2012, 08:36 AM   #1067
Originally Posted by STOCKMANRacing View Post
Ya they are aftermarket. There are many different colors, just ask your local hobby shop or you can find them online. You will also need all different bolts as they will not use the OEM bolts.
Looks great! I'm gonna take a wild guess and say that you've had or currently have a Durango DEX210...
GuiltyByAssoc is offline   Reply With Quote
Old 10-05-2012, 08:36 AM   #1068
Moderator
Posvar's Avatar
Trader Rating: 462 (100%+)
Originally Posted by t8rtot View Post
as mentioned on several pages before.. they are upgraded and beefier than the previous design. still plastic
Are you sure about that??? I recall that some one said that the new plastic is softer and that's why several people are already having issues. The rb5 parts drop right in and seem to be a stronger composite material.
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Old 10-05-2012, 08:41 AM   #1069
t8rtot's Avatar
re-read the post.. i said they are designed larger in size on the 6.. never said they were better.
i haven't too many state they have issues with the holders.. just steering components mostly, but i already have the aluminum parts so not an issue for me.
Sfida
Old 10-05-2012, 08:54 AM   #1070
Moderator
Posvar's Avatar
Aaaaah, yes you are correct. Sorry, iPhone reading fail. Where are the racks actually in stock? I have looked at a few places. I am going to run the rb5 hangers until they fail and go from there.
Old 10-05-2012, 08:55 AM   #1071
About to order a RB6, Could someone give me as list of hop up parts needed or is the kit good out of the box. A local that has a RB6 put the um521-1 arms on it instead of the kit arms. Didn't get to ask him why.
Lou Colmo/Tekno EB48.3, SL & SCT410.3/ Tekno R/C,Tekin / Reedy Batteries / Savox /AKA / Futaba 4PKs
Blaze R/C,St.Louis DirtBurners,SMAC Trac
X God is offline   Reply With Quote
Old 10-05-2012, 09:02 AM   #1072
t8rtot's Avatar
i would get all the typical 2wd parts.. front hubs, spindles, axles, bearings, shims etc.. apparently some are finding issues with the steering rack.. i haven't seen any in stock anywhere.. i'm talking to a machinist locally to see about a batch of 50 made..
for upgrades.. the aluminum hangers, rear hubs, and steering when they're available.
i look forward to running mine this wknd
Sfida
Old 10-05-2012, 09:05 AM   #1073
Moderator
Posvar's Avatar
Thanks man. Put me down for an aluminum rack.
Old 10-05-2012, 09:24 AM   #1074
gelshocker's Avatar
Hey guys I've managed to finish a side project and starting the rb6 build Great to see so many cool sixes out there. So I'm having a problem with the front sus mount block: the little nub inside the front arms that carries the set screw at the back is causing serious binding with the sus mount.
Should I shave it off? I don't recall others having the same issue? It's illustrated by the red arrow. The hole at that end is seriously tight when trying to push the hinge pin through too. Thanks for the help.
http://flic.kr/p/dgXXqJ
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 10-05-2012, 09:43 AM   #1075
fullsyzz's Avatar
Trader Rating: 103 (100%+)
I had a similar issue when I had that screw tightened down. I backed that screw out a hair and it all free'd up.
fullsyzz is offline   Reply With Quote
Old 10-05-2012, 09:47 AM   #1076
STLNLST's Avatar
Trader Rating: 21 (100%+)
Originally Posted by SAGISI View Post
Haven't painted the body yet, I have a few more customers bodies to paint first. Maybe if NorCal has a body in stock so i can do a quickie. Im sure I will find a way to drive this beast on Saturday. Ill have my b4.1 fitted with a 17.5 to battle you in the mean time. The RB6 will stay a mod only car. Drove it on the street and this car is sooo smoothhhhhh.
The battle won't be the same though :-(
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 10-05-2012, 09:48 AM   #1077
t8rtot's Avatar
i ran into the same issue, once you wiggle it through, its smooth as butter. just takes some lining up.
Sfida
Old 10-05-2012, 09:51 AM   #1078
Kimbrough shows a 48p slipper gear and a spur gear what's the difference?
OCT 8th RB6 arrives.
"Lions and tigers and Rb6s' Oh my!"
ems
Eric Summers is offline   Reply With Quote
Old 10-05-2012, 09:54 AM   #1079
Trader Rating: 9 (91%+)
goin2drt you will need 3mm washers. here is a link to where you can get them
http://www.racers-edge.com/3mm_Alumi.../rce10200r.htm
STOCKMANRacing is offline   Reply With Quote
Old 10-05-2012, 10:15 AM   #1080
gelshocker's Avatar
I'm not getting the smooth as butter... set screw in arm and in sus mount now even in yet..
http://flic.kr/p/dgYFKd
Kyosho RT5 | RB6
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22970 10-17-2017 05:10 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
