    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 08-27-2014, 07:50 AM   #10756
Enigma R/C's Avatar
BTW,
Thanks ARNO for posting that setup!
Looking to buy/sell USED rc gear? www.rcshed.com
Enigma R/C is offline   Reply With Quote
Old 08-28-2014, 12:38 AM   #10757
Teufel Racing's Avatar
Trader Rating: 28 (100%+)
So after reading/hearing about the new shock mount location I decided to give it a go,
I left my setup pretty much the same as I had it with the only change being the new location for the rear shocks. I'm a believer for sure. Night and day difference. Let a couple other guys wheel it and they both liked it. I had a 17.5 in there and they both ran faster than I did with my own car and one had never run a 17.5 before. I liked it so much that I picked up a couple pairs of new rear arms to drill out just in case I snap one. You guys won't be disappointed with the change. I can't explain why it does what it does, but it sure made the car a lot easier to push harder with out getting into trouble.
Track:
Indoor clay. Mostly smooth with a couple rougher sections. Med. to Med. high traction depending on how wet or dry the surface is.
Tires used:
MC Electrons F/R, MC Electron R/Transistor F, AKA C Typos F/R
Base setup:
Mostly Tebo's MM setup for out door. 1.3/4hole tapered front, 1.6/2hole tapered rear. 35 front oil, 30 rear oil (I think 27.5 in the rear would have been even better). Pink F/Gold R springs. Elec.'s: servo (half sized), transponder flat on the chassis in the gap, batt, ESC, Rx and ESC cap on the left and right sides at the rear of the side guards. 0 camber/0 toe front/2.5 rear toe (2 on the arms, .5 at the hubs, 2mm shim on the rear outer camber link, 0 inside. 22mm ride height F/R (meant to set it at 23mm, but didn't pay attention). Rear hubs all the way forward on the rear arm.
It's the best I've had the car feel yet, and I didn't follow the recommended setups for the new location to a "T", but do plan on doing so, minus the elec. layout change. So far it's pretty good, even when the track was a bit drier than normal.
Thanks to the guys that posted up about the new shock location. Was well worth the few minutes it took to make the change
J.Mikoliczyk
RB6 - MBX7R Eco
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is offline   Reply With Quote
Old 08-28-2014, 02:12 AM   #10758
jelly's Avatar
which chassis is being used with the new hole?
jelly is offline   Reply With Quote
Old 08-28-2014, 06:38 AM   #10759
cnelson3's Avatar
Trader Rating: 65 (100%+)
Which ever one you prefer. I'm running the original one and the new arm hole location with really good success.
Kyosho America
Peak Racing
Trackside Hobbies & Raceway - Milwaukee, WI
cnelson3 is offline   Reply With Quote
Old 08-28-2014, 07:43 AM   #10760
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
I run the standard updated chassis. It's the same stiffness as the stock chassis, but it has the extra mounting holes the lightweight chassis has.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 08-28-2014, 07:54 AM   #10761
Potoczak's Avatar
Trader Rating: 111 (100%+)
Anyone have a good rear motor 17.5 setup they want to share for indoor clay??
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 08-28-2014, 08:20 AM   #10762
Try the one posted above...
Schuurspeed / Aero-model / Gear One / LG1
www.OHRCR.com
Gitsum is offline   Reply With Quote
Old 08-28-2014, 08:55 AM   #10763
Enigma R/C's Avatar
Hey guys, glad the buzz about the new shock position is a positive one....for anyone still running Tebos electronic package, if it works for you that is great, however, when I have ran it(along with others) I feel that the car pushes(under steers) a lot more in corners....and I know that sounds backwards considering the battery is much farther forward than my setup shows....however it feels like the front end is a sled going into corners and the weight never transfers properly. When the battery is pushed further back not only do I feel like I generate more rear traction, the car has a boat load more steering due to the weight being transferred to the front when letting off the gas and/or braking. Obviously everyone has their own driving styles and what feels good to them...but if you are questioning your steering and grip...id say before even doing the new suspension changes try the battery position.
P.S. I am also running the same chassis as Kevin mentioned above; standard chassis update, with holes that match that of the LW chassis.
Hope all these adjustments are helping you guys gain more confidence in your cars!
Old 08-28-2014, 11:22 AM   #10764
Zack,
I hear what your saying. It's a bit funny as I had all of my elec. stuff up front when I first set the car up (minus the batt being as far back as it gets run now) and it did feel like the steering was more. I only went to the rear esc position as my Orion (with fan) has a little more weight to it and I wanted to put it further back. My car can push for sure, but with the current setup (even prior to the new shock location) the amount of front end push can depend on which front tires being run at the time. Which I like. I do think that running 2.5 rear toe helps keep the rear end from pushing through the front end and possibly making the front end push that may already be there even worse. At least that is my thinking. Still you and Kevin have found a way to make the car even better than it was and that is a good thing.
J.Mikoliczyk
RB6 - MBX7R Eco
Old 08-31-2014, 09:33 PM   #10765
rchogfan's Avatar
I've searched through probably 30-40 pages and haven't found anyone specifically stating how to gain forward traction. I'm running mid motor and a low traction indoor track. I've added an ounce of weight to the back and still really loose and no forward traction. I've tried numerous tires of several compounds so I do not think that's the issue. I'm running saddles side by side pushed all the way to the back strapped in. Any help is very very greatly appreciated. (Not wanting to go to rear motor). Thank you.
**CALVIN BRUCE**
MUGEN SEIKI MBX7 ECO - TEKIN GEN 2 RX8 1900T8 | MUGEN SEIKI MBX7 - ALPHA LUTZ WORLDS | B5M CE - TEKIN RSX - 9.5 | 2015 XB4 - R10 PRO - 6.5 |
rchogfan is offline   Reply With Quote
Old 08-31-2014, 09:47 PM   #10766
MikaR's Avatar
Just fyi. I started out yesterday with mid motor on low traction track and it was terrible. I took the time and changed it rear motor and it was a blast. However I left the shorty batt in front position an I felt it jumped almost the same as mid. I didn't feel I should move the batt so I kept it that way.
MikaR is offline   Reply With Quote
Old 08-31-2014, 09:55 PM   #10767
K_King's Avatar
Ditch the weight. Go to a shorty. Where are you needing traction? Coming out of a turn? What's your setup and tires?
Old 09-01-2014, 07:08 AM   #10768
rchogfan's Avatar
That's kind of what I don't wanna do but may have to. When I got it I bought all the exotek mm stuff. So I'll loose some bling as well.
**CALVIN BRUCE**
Old 09-01-2014, 07:10 AM   #10769
rchogfan's Avatar
Yes, coming out. I can barely touch the throttle. Then have to slowly accelerate to clear a jump to hofefully make it when others can get over fine. I'm running narrow rear hangers, 32.5 front oil/30 rear (AE oil). -2 camber... Currently handbars rear, typos front.
**CALVIN BRUCE**
Old 09-01-2014, 07:46 AM   #10770
Try Zacks set up. The track he runs on isn't always med/ high traction. Our normal club nights are medium traction at best. This set up experiment was to try and get on par with the traction the B5m had when our track was less than ideal for the Kyosho. I didn't have Zacks entire set up on my car and he was making a triple triple section with way more ease than I was, his forward bite was very good. And you'll be able to keep your bling.
CaseyD is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22957 Today 12:16 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 8 (2 members and 6 guests)
Michael#81, sgtlt
