    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 08-24-2014, 04:57 AM   #10726
eper's Avatar
Trader Rating: 14 (100%+)
Sorry double post
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 08-24-2014, 12:48 PM   #10727
Has anyone tried the new brass bulk head??
I've got one on order to try out on my MM Rb6, hoping it'll give a bit more slow speed steering
Headling is offline   Reply With Quote
Old 08-25-2014, 12:14 PM   #10728
I see a lot of people mention the "Japan" setup for RM, what are they referring to? Is it still the go-to for RM/17.5?
Naxn is offline   Reply With Quote
Old 08-25-2014, 02:22 PM   #10729
Enigma R/C's Avatar
Hey guys here is a video/setup sheet of what I found to be a pretty good setup on Med/High grip clay tracks....
A lot of the team guys and customers have switched to it and they all seem to love it, and better yet all have said the same thing feedback wise on what it actually does to the car...
Hope the video might help some people with their Kyosho car!
https://www.youtube.com/watch?v=9Siu...OfMhZSjsZh5Tnw
Looking to buy/sell USED rc gear? www.rcshed.com
Enigma R/C is offline   Reply With Quote
Old 08-25-2014, 03:21 PM   #10730
helocat's Avatar
Link not working. Any help on setting up the car for the first time is much appreciated.
Metal-tech 4x4 - www.metaltech4x4.com Building full size off road parts for Toyota 4x4's since 2000.
Ironman 4x4 America - www.ironman4x4america.com North America Distributor for Ironman 4x4 - Australian designed and proven off road and camping gear.
helocat is offline   Reply With Quote
Old 08-25-2014, 03:24 PM   #10731
Enigma R/C's Avatar
Sorry about that, hopefully this one works!
Old 08-25-2014, 03:28 PM   #10732
can you please tell us exactly where you drilled the hole on the rear arms
esoteradactyl is offline   Reply With Quote
Old 08-25-2014, 03:45 PM   #10733
Enigma R/C's Avatar
I used the side that already has two holes on them, and measured the distance between those two and made the 3rd hole, however you can do it on the other side as well, but it will actually be half a hole in more than the setup I am running.
Hope that helps.
Old 08-25-2014, 03:45 PM   #10734
Potoczak's Avatar
Trader Rating: 111 (100%+)
Do you have a link to the setup sheet??
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 08-25-2014, 03:50 PM   #10735
Enigma R/C's Avatar
Its is linked in the description of the video on youtube...however I know you have to go through a website to get it.
Its also on petitrc but the site is down at the moment? So as soon as they are back going I will post the link!
Old 08-25-2014, 03:54 PM   #10736
Potoczak's Avatar
Sounds great thank you. What did drilling the arms do?? How did it affect the car??
Pete Potoczak
Old 08-25-2014, 04:42 PM   #10737
Enigma R/C's Avatar
Im not sure how your car feels without them drilled, but mine always felt stiff/bindy in the rear end, which on the track lead to my car never being able to carry corner speed without getting loose and my car always seemed to pull one way on power(never had just wheelie type grip.) This hole makes the car have a lot more roll, which you would think would make the car loose in corners, however it actually makes the car feel more like a slot car, or a car driving on a rail in sweepers....also the forward bite doesn't even come close to comparing the old shock positions...standing them up like I have allows the car to be a lot softer and work with its own pivot points a lot better...also I have had people question the way the car will transfer weight with this new setup, and all I can say is drive it and be blown away, yes the weight transfer is a lot great in all directions, but its funny how now the car actually has more steering than before, yet still has more side to side traction even though the car is being thrown into the corner faster.
Side note that if you are to do this setup PLEASE PLEASE PLEASE do not half A$$ the setup by not making sure your droop and ride height is also the same as my setup sheet for a base start, as I have noticed those 2 things are much more crucial with this setup than the previous setup.
Thanks,
Zack Rogers
Old 08-25-2014, 05:02 PM   #10738
Potoczak's Avatar
Thanks,
Zack Rogers
Thanks for explanation Zach. What tires were you running in the video?? The car does really look hooked up!!
Pete Potoczak
Old 08-25-2014, 05:15 PM   #10739
Enigma R/C's Avatar
Thanks man!
I am running gold barcodes all the way around, dirt tech inserts, liquid wrench tire sauce.
Old 08-25-2014, 10:59 PM   #10740
Your freakin set up better work Zack, I just spent the entire evening rewiring my electronics back to how they used to be so I can put your set up on my car. If it doesn't don't expect me to move when youre lapping me for the 5th time.
CaseyD is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
