    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree16Likes
Old 08-15-2014, 03:15 AM   #10711
Zylux's Avatar
A couple of weeks ago I mentioned I was going to try and make some 7075 T6 Aluminium hinge-pins for my RB6. Well, I did make some for the front hubs and spindles and ran them all day today. Hit a few things and actually ran into someones foot at full speed (essentially a wall) with absolutely no bending of the hinges.
Looks like I will continue running these into the future. That's about 3 grams of unsprung mass saved! Also made some titanium inner hinges as these will have to handle more stress. Happy days.
Kyosho RB6, Kyosho ZX6, Mugen MBX7E
Zylux is offline   Reply With Quote
Old 08-15-2014, 07:11 AM   #10712
Originally Posted by Zylux View Post
Yep. Battery back will give you more rear weight. Also, if you want more rear weight, make sure you remove the rear battery holder, add some stops in front of the motor and slide the battery in under the waterfall brace. If you are trying to increase rear weight bias, you can also move the front and rear hubs all the way forward and remove as much weight as you can from the front of the car (shorty servo, alu axles, Ti Turnbuckles, ball-studs, hinge pins etc).
I managed to get my RB6 MM weight bias to 35.6% front / 64.4% rear whilst still hitting minimum weight.
At what point do you/ would you lose the benefit of MM? When I originally went MM I had the battery all the way back with ESC/ RX infront. At the Surf City I went with Tebos set up + a couple of changes. The set up had the electronics servo/batt/esc. The car felt way better to me than batt all the way back. Granted it was OCRC with ridiculous grip. What is the weight bias of a RM car? Would a person still see a benefit if for example his MM car 35 F 65 R compared to a RM car that was 35 F 65 R. All else being the same, track conditions, tires, motor etc..
CaseyD is offline   Reply With Quote
Old 08-15-2014, 07:14 AM   #10713
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
Well the main difference is that you will never have the major weight at the very rear most part of the car swinging around. So a MM would never feel like that, it should always corner better and slide out less when getting loose.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 08-15-2014, 06:17 PM   #10714
Zylux's Avatar
I hear what you are saying. But as also stated by K_King, my theory is that if I can get the weight bias closer to a Rear Motor car but with the mass much more centralized it should be more responsive and shouldn't have the overshoot / pendulum effect that a rear motor car would have (lower moment of inertia) but still have the forward traction of a rear motor car.
I run on a medium grip dirt/clay off road track where rear traction is sometimes hard to come by.
My Mid Motor RB6 was about 38.5-39% front when I first built it (with shorty as far back in standard battery holder locations). It is now 35-36% . This has improved the forward traction and I haven't lost too much steering. I have lost a little mid-corner rear traction however (more over-steer).
For comparison, a standard rear motor B5 has a weight split of about 33.7-34.1 front (according to Ray Munday on the "Ask Ray Munday" thread on this forum and the B5M about 36.5-37% (out of the box) and down to 34.2% front after all of Rays modifications.
So I guess if you run on a low-mid grip track I think that more rear weight bias is a good thing as you still have the added bonus of a lower moment of inertia. Car still jumps better, is easier to catch when it loses traction and responds quicker to changes of direction.
Old 08-15-2014, 06:36 PM   #10715
aloksatoor's Avatar
Trader Rating: 42 (100%+)
I tried tuning with weight in my cougar cars it always ended up being like a rear motor in fact for low bite clay. Since then, tuning with flex and springs/shocks yields better results for me. The LW chassis almost has same grip in MM as the stock in RM actually.
I just personally prefer putting weight as ahead as possible for it to jump flat while still having a lot of give in the rear spring oil combo. Still the rb6 does not handle as well in air as the yok so trying to tune that.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 08-16-2014, 12:16 PM   #10716
Default J concepts honeycomb motor mount
is a total sleeper upgrade. i was using the lightweight milled kyosho upgradea, but at 2mm thick, i felt like it flexed a lot. plus when my motor was hot, the plate was barely warm. i noticed the jconcepts was 3mm, so i got it on my last amain order. does not flex everytime i tighten pinion or motor so winning. but why its totally rad is because that honeycomb design does a kick ass job at dissipating heat. my temps have been 10 degrees cooler and i can feel the motor plate is almost hot (compard to warm), doing a nice job with the heat. the only thing i didnt do was weigh the piece to compare to the kyosho one. but i doesnt matter. 20 bucks well spent!
glenng is offline   Reply With Quote
Old 08-20-2014, 03:36 PM   #10717
Just for Bling
QIMB528 is offline   Reply With Quote
Old 08-20-2014, 05:17 PM   #10718
Potoczak's Avatar
Trader Rating: 111 (100%+)
Originally Posted by QIMB528 View Post
Just for Bling
Who,what,where, and how much???
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 08-21-2014, 11:24 PM   #10719
Made it myself, bonded with Hysol 9340.
It wasn't popular a few months back. But if there are enough demand, I will make more.
Old 08-22-2014, 08:55 AM   #10720
Well I had a question or two but never thought it was a bad idea. It looks great, very nicely done. Are the side gussets keyed as well as bonded?
kineteks is offline   Reply With Quote
Old 08-22-2014, 05:43 PM   #10721
helocat's Avatar
Just ordered the kit today. Setting up for stock. I am a totally new to racing and just built a SC6. Local track seems to only run buggies so good excuse to build an RB6.
Should I just build it to the instructions or any sugested set ups to follow. I will be using it mainly indoors on a hi bite clay track.
Metal-tech 4x4 - www.metaltech4x4.com Building full size off road parts for Toyota 4x4's since 2000.
Ironman 4x4 America - www.ironman4x4america.com North America Distributor for Ironman 4x4 - Australian designed and proven off road and camping gear.
helocat is offline   Reply With Quote
Old 08-22-2014, 08:23 PM   #10722
Jochim_18's Avatar
since your from Bako ask Zach Rogers his a team driver from Kyosho.
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 08-22-2014, 08:24 PM   #10723
Jochim_18's Avatar
Just for Bling
Where should I send my payment I want one of this badboy..
Old 08-24-2014, 12:54 AM   #10724
I always build stock then go from there.
LC Racing EMB-1
Losi Mini 8 Truggy x2
No Idea!! is offline   Reply With Quote
Old 08-24-2014, 04:55 AM   #10725
eper's Avatar
Trader Rating: 14 (100%+)
Hey guys I haven't been on here in like a year. I lost my job and had to sell my entire line of k cars. Was really sad. But since I scored a new job and yesterday found my scr and rb6 still complete and sitting on the shelf in the very store that bought them. So I bought them back and couldn't be happier. Thing is I got rid ofall my spares and want to go mm does anyone have those parts laying around and not in use. I would like to buy them. Pm me if anyone has them. Thanks.
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22970 Yesterday 05:10 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
