    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 08-06-2014, 12:29 PM   #10681
Originally Posted by aloksatoor View Post
I was at the same point as you, was around 130 grams under weight with the 150gram shorty heheh, so I used a full weight pack for stock for more consistency, theres a step up which I can only clear the first few laps on my big 1/8 sized track. Where did you get the copper sheet? Been looking for something like that.
What shorty pack is this that's that light?
Schuurspeed / Aero-model / Gear One / LG1
www.OHRCR.com
Gitsum is offline   Reply With Quote
Old 08-06-2014, 12:48 PM   #10682
Originally Posted by K_King View Post
Anyone tried drilling holes on the inside of the rear arms yet?
A couple of us are doing this at my track. The difference is ridiculous way more stable exiting turns, the rear end doesn't want to step out on you. The car just simply drives better every where. We haven't gone quite that narrow yet but it was definitely in the works in the next couple of weeks. We also used a B5m as our base for measuring. We were trying to keep it on the DL but some guy from San Diego just put the idea on blast. hahaha
CaseyD is offline   Reply With Quote
Old 08-06-2014, 01:25 PM   #10683
aloksatoor's Avatar
Trader Rating: 42 (100%+)
A bunch
http://www.amain.com/ProTek-R-C-2S-S...200mAh/p271097
http://www.promatchracing.com/prodde...prod=2S350090C
and trinity and smc also have some. Weight is around 150 grams. But it looses punch mid way cos of the voltage drop (we got a big 1/8 track for 17.5 stock), I might put that in for the winter back in where the size is a bit less.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 08-06-2014, 09:44 PM   #10684
i wonder where he got that idea…………….I think we both know who's idea it was
AlwaysLOSI is offline   Reply With Quote
Old 08-06-2014, 11:51 PM   #10685
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
Zachy Poos :P
I'm going to test both holes tomorrow along with the most inner on the tower. Hoping for good results.
Did you have to change your dampening at all?
K_King is offline   Reply With Quote
Old 08-07-2014, 05:12 AM   #10686
jelly's Avatar
what sort of track is it working on?
jelly is offline   Reply With Quote
Old 08-07-2014, 05:19 AM   #10687
Trader Rating: 48 (100%+)
Could this be applied to rear motor cars as well?
Thanks to my sponsors:
My Credit Card
Speedychris22 is online now   Reply With Quote
Old 08-07-2014, 07:10 AM   #10688
Zachy Poos :P
Zack and my son are running 1.6x2 30w gold springs
28mm of shock shaft showing
I'm running 1.4x3 tapered 30w white springs
Both seem to be working really good.
Old 08-07-2014, 07:18 AM   #10689
Not real sure if Zack kept the same set up when he switched from MM to RM on Saturday. You could always find some one with RM B5 and measure the width between the top shock mounts and the width between the bottom shock mounts and drill holes accordingly.
What type of track?
So far it's been used on a low/med bite track and at OCRC. Low/med bite track showed some good results, OCRC was ridiculous. My son went from fish tailing the straight to the rear end basically centering itself when he grabbed a handful of throttle. I drilled my sons holes kind of narrow, 17.5mm out from the sway bar mounting holes.
Old 08-07-2014, 09:34 AM   #10690
What type of track?
I run on a low traction track. This does sound very interesting
My Credit Card
Old 08-07-2014, 09:59 AM   #10691
K_King's Avatar
What type of track?
Yup. When I used the drill press on Saturday I noticed a nice difference. I was also on 1.6x2 and 30 with golds. My buddy also ran the arms in his main so we could get more feed back and really liked the new hole.
Have you tried the new hole plus inside on the tower?
I'm also D-in on both.
Old 08-07-2014, 10:26 AM   #10692
aloksatoor's Avatar
Nice mod. Please keep us updated. Anyone thinking of making the inner pivot narrower as well? I got a exotek MM narrow pair which I use not sure if its narrower than the d in setup.
Old 08-07-2014, 10:37 AM   #10693
K_King's Avatar
Already done in solidworks
Old 08-07-2014, 10:44 AM   #10694
aloksatoor's Avatar
Awesome!
Old 08-07-2014, 04:06 PM   #10695
AZRC4Me's Avatar
I'm working with Kevin on the narrower rear blocks. Should have designs done shortly. We'll do a small run initially to test then get into production depending on demand. To give you an idea, the blocks will be designed to use the existing RB6 rear pills and when using A/A with the new blocks it will be about 2mm narrower than Din/Din.
Sean Gaffney
...where some sponsors used to be...
AZRC4Me is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
