    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 08-04-2014, 01:02 PM   #10666
MikaR's Avatar
Do you leave substantial pack on the shocks or close to zero?
MikaR is offline   Reply With Quote
Old 08-04-2014, 01:08 PM   #10667
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
You actually have to go softer. I'm going to try 25/white.
K_King is offline   Reply With Quote
Old 08-04-2014, 09:45 PM   #10668
jelly's Avatar
Originally Posted by K_King View Post
Check it out.
is it for weight or flex?
jelly is offline   Reply With Quote
Old 08-05-2014, 04:53 AM   #10669
Zylux's Avatar
Well, after throwing a bunch of titanium at my RB6 MM I realised that I needed to add 65 grams back in to meet ROAR minimum weight .
I figured I'd add the weight as low and rearward as possible (I run on a medium grip outdoor dirt/clay track)
I added a 20 gram brass weight to the rear bumper and a 45 gram copper sheet under the battery and motor. This also had the effect of marginally increasing the rear weight distribution; now at 35.8% front, 64.2% rear with an all-up weight of 1501 grams.
Drove it briefly after work tonight and preferred it without the extra weight but need more time to play with it.
Kyosho RB6, Kyosho ZX6, Mugen MBX7E
Zylux is offline   Reply With Quote
Old 08-05-2014, 07:34 AM   #10670
K_King's Avatar
Neither. It's to get the shock angle closer to 90 degrees upon compression.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
Old 08-05-2014, 08:00 AM   #10671
Default anyone selling rb6?
Please let me know. text me at 518-495-0703. thanks.
Previous username: MBUCK
noworries is offline   Reply With Quote
Old 08-05-2014, 10:13 AM   #10672
aloksatoor's Avatar
Trader Rating: 42 (100%+)
I was at the same point as you, was around 130 grams under weight with the 150gram shorty heheh, so I used a full weight pack for stock for more consistency, theres a step up which I can only clear the first few laps on my big 1/8 sized track. Where did you get the copper sheet? Been looking for something like that.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 08-05-2014, 01:51 PM   #10673
Zylux's Avatar
Yeah, with a 150g shorty I would be under 1370 grams lol!
I bought the copper sheets years ago for a totally unrelated project and don't recall exactly where I got it from, but it was an Australian website and they also sold small quantities of precious metals for jewelry etc. I'll let you know if I remember.
The only reason I wouldn't run a full size pack is because I want the CoG as far back as possible; I'd rather add weight low and rearward.
Old 08-05-2014, 02:07 PM   #10674
aloksatoor's Avatar
Oh did not see the country sorry. Yeah I buy metal stock from online metals.com here in the usa I will try to find those types of sheets. We got sugar tracks so car works best with weight as ahead as possible (jumps flat) with the stiffest (had lw chassis but moved back to stocker) settings. So with saddles it works those shocks better .
Old 08-05-2014, 03:40 PM   #10675
helocat's Avatar
Copper sheets these days are $$$. Just prepare $ if there is any thickness for weight to them.
Metal-tech 4x4 - www.metaltech4x4.com Building full size off road parts for Toyota 4x4's since 2000.
Ironman 4x4 America - www.ironman4x4america.com North America Distributor for Ironman 4x4 - Australian designed and proven off road and camping gear.
helocat is offline   Reply With Quote
Old 08-05-2014, 03:43 PM   #10676
aloksatoor's Avatar
Yeah I have some tungsten pine car weights, cheaper than copper I suppose but very hard to machine with the ghetto tools I got.
Old 08-05-2014, 04:31 PM   #10677
I just use the inside hole on the standard rb6 rear arms and that seems to be a really good shock angle. Anything too far inside will make a mid motor car too "point and shoot-ish" which they aren't really good at in the first place. And if that's what people want, then run rear motor.
castellano93 is offline   Reply With Quote
Old 08-05-2014, 04:49 PM   #10678
K_King's Avatar
That's not true at all. The B5M is at least 4MM narrower than our car at the D-in pivot. That gives them more roll and when you bring the shocks in you stiffen that back up.
Old 08-06-2014, 10:29 AM   #10679
aloksatoor's Avatar
Hmm I thought standing the shock up makes it less progressive and makes it roll more.
Old 08-06-2014, 10:56 AM   #10680
K_King's Avatar
More inclined is less progressive but you don't have the same lateral support. That doesn't mean more roll though, just less side bite. I've found it enters and exits better but doesn't corner with as much support.
It's a trade off and what I'm working on is to make a narrower rear pivot which will give it more roll and then using the shocks to give it forward bite
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
albertv78
