Kyosho Ultima RB6 & RB6.6 Car Thread
5 hole pistons
front
35 weight
pink spring
middle hole tower
outside arm
rear
27.5
gold spring
1 from inside tower
middle RB5 arms
0 degree hubs, .5 if you need more traction
0 shims inside
3m outside
outside front on camber link on hub
inside on chassis
short chassis length
WTS battery with on aluminum weight in the back
Thats about it
Basic set up.
5 hole pistons
front
35 weight
pink spring
middle hole tower
outside arm
rear
27.5
gold spring
1 from inside tower
middle RB5 arms
0 shims inside
3m outside
inside on chassis
Thats about it
5 hole pistons
front
35 weight
pink spring
middle hole tower
outside arm
rear
27.5
gold spring
1 from inside tower
middle RB5 arms
0 shims inside
3m outside
inside on chassis
Thats about it
By the way I love those stories u put on ur site from time to time. Its some of the funniest stuff I read. Keep it going.
the new Brass Front Sus Block (UMW722 Type B/24g/RB6/RT6/SC6) will be interesting
Moderator
Trader Rating: 470 (100%+)
I think the Ghea is 31 gram versus the K 24g
Trader Rating: 89 (100%+)
what would be the best things to try to eliminate traction rolling on a high bite carpet track?
would weight placement in certain areas help?
What diff oil and weight, are people using in there gear diff for carpet tracks?
I would love to have a brass suspension holder for the mm car in the rear. The one that is right by the motor. Having a little extra weight right by the motor would really help the handling one would think. I saw the TLR 22 has something like this and it makes total sense to me. I don't need weight out the back, I want it close to the motor.
You guys mean something like this??
