    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 07-13-2014, 06:48 PM   #10591
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Originally Posted by Jspires688 View Post
No I did not try running the diff tighter but I did loosen it some and it didn't seem any worse being loosened but I always seem to have to much steering so moving the battery back may help that also
Hmm try it a smidge tighter. With more weight in the back, you will get a pendulum effect as well which is not so good. I would start with the cody kind mid motor ocrc sheet and go from there if I were you (white springs all around pistons might be a bit hard to get locally, the 1.5x2, avid sells a set of 4 on amain).
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 07-13-2014, 07:01 PM   #10592
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
I would really suggest people try this car with the battery all the way back using this
http://www.petitrc.com/setup/kyosho/...20131122/1.jpg
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 07-13-2014, 07:07 PM   #10593
That pic looks like what I was thinking of trying what's your experience with this setup?
Jspires688 is offline   Reply With Quote
Old 07-13-2014, 07:32 PM   #10594
tef
Thats close to what I run. Works good
Thanks to my sponsors Kyosho America*O.S. Engines*TrakPower*Pro-Line Racing*Futaba*O'Donnell fuel*Team Scream Racing
tef is offline   Reply With Quote
Old 07-13-2014, 10:11 PM   #10595
did similar with the rt6 backstop, rb5 posts (re-drill and countersink new hole locations) and battery strap with a thin piece of foam servo- taped to the esc, then receiver then low pro servo:
glenng is offline   Reply With Quote
Old 07-13-2014, 10:27 PM   #10596
Trader Rating: 23 (100%+)
You liking this better then esc in front of the motor? I run my setup like this too but I just jam a battery pad between motor and battery. The stopper would be better maybe i'll pick one up.
chevmaro is offline   Reply With Quote
Old 07-13-2014, 10:32 PM   #10597
I'm running mid motor was running pink springs front gold rear 30wt front and rear with 1.6 2 hole in the front 1.7 2 hole rear with the esc right in front of the motor and shorty battery I'm having trouble with the rear of the car getting loose and jumping sideways mid out of corners and on hard acceleration be for jumps thinking of putting esc in front of battery and moving battery all the way back against motor thoughts anyone?
I'm running 4x1.3 all the way around with 27.5 pink front/22.5 white rear with 10 grams on the rear bulkhead. I like it better than the battery on the motor setup. Also running 0 and 0 on the anti squat
AlwaysLOSI is offline   Reply With Quote
Old 07-13-2014, 11:11 PM   #10598
K_King's Avatar
Yes so far I am a lot more consistent with it. The car is a lot more planted. My Rear weight went from 61 to 63% which is huge. My buddy usually hates my cars because his push like a dump truck, but with what I'm working on it's real nice and Im still breaking in tires. I actually went back to middle/pink springs and may try golds now. May be too soft back there but right now it drives really nice.
Old 07-15-2014, 03:05 AM   #10599
FallenAllDay's Avatar
Is there a setup i can use just using the stock kit stuff for a mm setup on a rough/loose track!? Just wanting to give it a go, my rm is working well just interested in the mm side of things. Thanks.
TLR 8IGHT 4.0, OS Speed, Sanwa M12s/Ko servos
KYOSHO RB6, Orion, Sanwa M12s/Ko servo
Powered by my wallet.
FallenAllDay is offline   Reply With Quote
Old 07-15-2014, 06:09 AM   #10600
KalEl63's Avatar
I've given my MM a go at our track and personally I felt it has potential but to get it there I think it needs those few extra bits that has been talked about or in the set ups posted
Team Associated RC10 B6D
Team Associated RC10 B64D
Team Associated RC10 T5M
1.21 GIGAWATTS!!!
KalEl63 is offline   Reply With Quote
Old 07-15-2014, 07:17 AM   #10601
MM doesn't really need anything special. Get some extra springs for tuning. I don't have any hopups on my car just the alum hinge pin holders for strength.
Old 07-15-2014, 08:33 AM   #10602
Jinggoy's Avatar
For this Kit this is a must have hopup UMW705, UMW706 & UMW707
Jinggoy is offline   Reply With Quote
Old 07-15-2014, 08:42 AM   #10603
the big rc's Avatar
Trader Rating: 39 (100%+)
We just had our Roar regionals and had a podium sweep with all RB6's. There were 6 of the 10 in the A!
All rear motor as the track was loamy and loose.
Here's the article with pics of the winning ride click here
the big rc is offline   Reply With Quote
Old 07-15-2014, 02:44 PM   #10604
What's everyone's opinion on the speed passion revention pro 1.1 I am thinking of replacing my tekin stuff with them?
Old 07-15-2014, 03:01 PM   #10605
There was some complaining initially when the 1.1 first came out that it would cog. I don't know if that was fixed or not. I have a couple Rev Pro 1.0's and they work awesome. I would maybe just get the 1.0 but confirm first in the SP thread.
My recent builds including my RB6 have been with Viper VTX10 ESC's. I really like this ESC so far. Maybe check those out while your at it.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22957 09-22-2017 12:16 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
