Kyosho Ultima RB6 & RB6.6 Car Thread
To much flex is a bad thing. The chassis will snap back violently. And you can make minimum weight with the stock chassis in mm with out doing anything crazy with upgrades.
Correct, I had a buddy with a Tamiya that was fighting that. He ended up making a CF brace for the entire chassis.
Does anyone have a bearing size and quantity for the rb6? Looking to maybe go with all ceramic bearings....
either of you guys try running the standard chassis without the chassis brace? not just removing the screws but completely taken the brace off? I tried it and I had a ton of side bite but then the car became a diving board. sometimes awesome and sometimes not. I'm curious if this is the same sort of result.
Just built up an RB6 and my rear shock springs are rubbing against the camber linkage. Manual calls for a total of 5mm of spacers on the top shock mount before you put the shock and nut on. If i swap 2mm to the other side of the shock eyelet, it clears it fine. I'm using the 0 deg alum hubs.
Is this ok? Did I build something wrong or is this normal when you set up the rear camber links certain ways w the alum V2 hubs?
Just space it so it doesnt rub.
Awesome! I love my car as much as I tend to tinker on it and get it way off wack. Every change is noticeable.
ok guys have anyone here tried converting the RB6 to RT6? I basically have 4 Kyosho RB6 and my 5 year old son don't want to race buggy class anymore he wants a truck so that made me think if its possible to convert the RB6 buggy to RT6 stadium truck?
Yes but you'll need a lot more than you're keeping. Shocks. Turnbuckles. Towers. Arms. Quick change. CVDs. Body. Spur. Battery strap. Chassis. It may not seem like a lot but it will be expensive with the shocks and chassis alone.
Ok never mind I was hoping the chassis would be the same. I know you need long shock body, Arms and CVD and everything else is the same.
