    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 07-02-2014, 05:38 AM   #10546
Originally Posted by Zylux View Post
So I've been trying to get more weight over the rear axle to increase forward traction but despite running a shorty servo and moving the battery as far back as possible the best I could get was 38%/62%. A local Pro running a mid-motor B5m on my track has had good success with and recommended a 36% / 64% split. I would have had to add 90g directly over the rear axle to achieve this on my RB6!
Naive as I was, I didn't realise that I could reduce the wheelbase by moving all rear suspension / hub shims to the rear! Reducing the wheelbase by 4mm and removing another 8g of mass from the front with Titanium Ball-studs, some drilling and more titanium screws / aluminium nuts got me to 36.7%/63.3%.
Then by putting 21g of brass onto the rear bumper I was able to get to 36% / 64%.
Now just need to add some mass under the battery (at the CoG) to get up to minimum weight! Can't wait to try it out at the track!
You are getting wayyyyy to technical. Lol
Schuurspeed / Aero-model / Gear One / LG1
www.OHRCR.com
Gitsum is offline   Reply With Quote
Old 07-02-2014, 06:12 AM   #10547
Lonestar's Avatar
indeed. just wheel it. practice will make up for slightly imperfect (as per the books at least) weight balance
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 07-02-2014, 07:06 AM   #10548
KalEl63's Avatar
The technical stuff is good to read though and does get the brain ticking
Team Associated RC10 B6D
Team Associated RC10 B64D
Team Associated RC10 T5M
1.21 GIGAWATTS!!!
KalEl63 is offline   Reply With Quote
Old 07-03-2014, 12:20 AM   #10549
gelshocker's Avatar
Hey guys, can someone post a pic of the revised (regular, not lightweight) alum chassis that has the extra battery post holes?
I'll like to order one and want to make sure to get the revised version.
Many Thanks!
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 07-03-2014, 03:54 AM   #10550
Zylux's Avatar
Many Thanks!
I think this would be the "revised" chassis. It's what I got in my "world championship" edition RB6 Kit a couple of months ago. Maybe someone else can confirm that this is the "revised" one?
Zylux is offline   Reply With Quote
Old 07-03-2014, 04:02 AM   #10551
Zylux's Avatar
Yeah, I think the fact I only get an opportunity once or maybe twice a fortnight to wheel the thing means I spend a lot of time thinking about it to get my "fix". I enjoy the thinking and tinkering almost as much as the driving.
I just finished putting in some ACER ceramic diff bearings and AVID ceramic thrust bearing and man WHAT A DIFFERENCE!
Before that I had the MIP steel bearings that come with the MIP Pucks kit and the diff felt very rough and grindy? I just assumed this was normal.
Before putting in the ceramic bearings I took the time to sand the diff rings nice and flat/smooth with progressively finer sand paper over some glass. Now the diff feels amazingly smooth! Very happy. Not sure if this will affect how it drives but who cares when it feels this good lol.
Old 07-03-2014, 07:54 AM   #10552
gelshocker's Avatar
Looks good. Cheers mate
Kyosho RT5 | RB6
Old 07-03-2014, 08:49 AM   #10553
cnelson3's Avatar
Trader Rating: 66 (100%+)
This still looks like it has more milling than the original one I have. I could be mistaken but now I have to check. Maybe new kit time.
cnelson3 is offline   Reply With Quote
Old 07-03-2014, 10:28 AM   #10554
joecool's Avatar
Trader Rating: 19 (100%+)
Default The original chassis
That one does look slightly revised. Here is the original chassis.
Joe Cool
Kyosho America, Team Orion, Ko Propo
joecool is offline   Reply With Quote
Old 07-03-2014, 10:55 AM   #10555
cnelson3's Avatar
Lite weight chassis doing well for you? I've been running my buggy at 1535 grams with the stock chassis. Almost scared to remove any more weight.
Old 07-03-2014, 12:53 PM   #10556
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
I've gone back to the std chassis. I want the newest std chassis though. I think the lightweight is best for stock, not sure about mod.
K_King is offline   Reply With Quote
Old 07-03-2014, 03:10 PM   #10557
cnelson3's Avatar
Care to elaborate? I'm running a 7.5 and have no plans on running stock but I was thinking about trying the lite weight chassis for more flex. I run on a medium grip black dirt track mostly but frequently run on a loose outdoor track as well.
Old 07-03-2014, 03:33 PM   #10558
joecool's Avatar
Yeah Chris my RB6 is on rails. My car is working great at Rockford. I'm gonna come race with you guys in Milwaukee soon to see if the work I'm putting in is paying off.
Joe Cool
Old 07-03-2014, 03:48 PM   #10559
cnelson3's Avatar
Very cool. Wait till you see my battery layout now. I gotta say, it's best feeling car I've had yet and lightest by about 65 grams!
Old 07-03-2014, 08:14 PM   #10560
K_King's Avatar
I feel as though the LW adds grip, but almost too much. I found, after awhile, that the car would soak up too much in the chassis and not let the suspension work its magic as well. Anytime I stiffened up the car, the chassis would just flex more and it would be a little inconsistent. In stock you may not have this issue, and the 30g weight is probably well worth the effort, but in mod where the forces are increased and faster, it just felt a bit weird sometimes.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15027 Today 09:29 AM
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22984 Yesterday 10:14 AM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
