    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree17Likes
Old 06-16-2014, 08:02 PM   #10501
Holmberg418's Avatar
Originally Posted by Jspires688 View Post
I'm running mid motor
Pink or white front. Gold or red rear.
Kyosho America, Hobbywing, Jconcepts, Lunsford, JTP
Full Throttle R/C Raceway www.ftrcr.com
Holmberg418 is offline   Reply With Quote
Old 06-16-2014, 08:32 PM   #10502
79kmc's Avatar
Default rims
Hey guys just wondering if the serpent srx2 buggy rims will work on the rb6
Kyosho rb6 Tekin Rs-17.5 tekin
Kyosho zx6 Tekin Gen2 Spec-17.5 tekin
www.Coast2Coastrc.com
79kmc is offline   Reply With Quote
Old 06-16-2014, 10:05 PM   #10503
the big rc's Avatar
Trader Rating: 39 (100%+)
does anyone make a slightly longer battery brace? I need one about a half inch longer.
the big rc is offline   Reply With Quote
Old 06-18-2014, 06:59 AM   #10504
That's currently what I'm running with no problems. They are slightly narrower than the kyosho wheels but they do work.
chad508 is offline   Reply With Quote
Old 06-18-2014, 01:35 PM   #10505
Suspended
Checkout this rb6 review video. I found on Kyosho Electric facebook page.
http://youtu.be/jpvn3ruZofw
rcaddict12 is offline   Reply With Quote
Old 06-21-2014, 10:18 AM   #10506
Trader Rating: 115 (100%+)
I have the kyosho v2 hubs, are there suppose to be crush tubes in between the bearings. What size of crush tube is it suppose to be
Breeze is offline   Reply With Quote
Old 06-21-2014, 12:13 PM   #10507
PhilDz's Avatar
Trader Rating: 20 (100%+)
yes, the stock crush tubes.
Phil Samonte *Team Balut*
PhilDz is offline   Reply With Quote
Old 06-21-2014, 01:01 PM   #10508
The exploded view doesn't show crush tubes
Old 06-21-2014, 05:45 PM   #10509
Trader Rating: 57 (100%+)
Yeah neither does the manual.
PROMODVETTE is offline   Reply With Quote
Old 06-21-2014, 10:37 PM   #10510
PhilDz's Avatar
it's called a brass collar in the manual
Old 06-22-2014, 07:36 AM   #10511
K_King's Avatar
Send a message via AIM to K_King
Hey guys, yesterday I was able to have a chance and finally spend a good part of the day testing things I rarely get time to do. Normally I make a change at home, go to the track after work during race day and run it. My base setup has been the King/Tebo setup from Reedy, and I feel that is a pretty good setup overall. I wanted to see if I could make it a little more balanced for me and my track and I feel like I did. I initially started with pink springs in the front and middle on the tower, but felt like I was a little too soft for our track and it dumped over on exit causing it to cut. I messed with Ackerman to see what it would do and I can use that 1mm shim to add exit cut if our track ever gets really grippy, but its so inconsistent it's safer to run at 0.
I usually make a setup that is overly aggressive on steering, and I've finally been able, I feel like, to make it steer while feeling planted on exit.
https://dl.dropboxusercontent.com/u/...une%202014.pdf
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 06-22-2014, 08:38 AM   #10512
Trader Rating: 50 (100%+)
Hi Kevin, thanks for sharing for a bumpy surface should I use the white rear springs or leave the gold on?
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 06-22-2014, 08:45 AM   #10513
K_King's Avatar
Depends on how bumpy I suppose. Really I would work on pack for that, and watch how your car reacts off jumps and through the sections. White is still a good choice, but I think sometimes if you go too soft, the rear end rolls over so much, especially on exit, that it eventually gives up and you get a snap loose feel. The gold was holding the rear in place for me a bit better through the corner. I didnt feel like I was losing anything compared to white spring. Its a good idea to have both though.
Old 06-24-2014, 04:46 AM   #10514
Zylux's Avatar
Had my first ever race on Sunday (well, aside from 2x5min runs against one other guy in novice class at an indoor carpet track which I'd never run on before). Great fun. I finished 4th in stock class (only 10 in the field) but I was really struggling with forward traction at the rear all day. The only time I could use more than 1/2 throttle was when I fed in power very gently down the long finish straight and if I fed it in too quickly the rear would be stepping out all over the place down the straight. Obviously corner exit was also terrible, but mid-corner through a fast sweeping bend grip was great. I tried a number of different tires, including AKA Impacts (soft & Super soft) AKA GridIron 2 (super soft) and Holeshot M3s and the Gridirons felt the best but still very minimal traction. Other guys I spoke with, running both mid-motor and rear motor cars using AKA impact (SS) tires indicated that they weren't having rear traction issues and could be much more aggressive with the throttle. Track was hard packed, dry and had a light dust layer all day despite efforts to blow-off the track. Running pink springs front, gold rear and 1.3x4 pistons in MM config.
I checked the car yesterday and realized I was only running 2 deg rear toe-in. I've changed it to 3.5 deg in the hope that it will lock-in the rear end a little. The last time I ran the car (before fitting the aluminium adjustable-toe suspension mounts) the toe would have been at stock setting (3 degrees?) and the car felt a lot better, but that could have been due to track conditions etc. Could the amount of toe-in make that much difference? How much rear toe-in are people running on this buggy in MM on off-road medium-grip tracks?
Next time out I'll also try going up in spring stiffness at the front (or down in the rear; of course the white rear spring is the only one I don't have lol!) and maybe a bit more anti-squat in the rear as well. I guess I could increase the front roll-center to take some transfer off the back as well without having to change spring-rate. Will also try putting more weight over the rear if I can. Any other suggestions?
Zylux is offline   Reply With Quote
Old 06-24-2014, 05:59 AM   #10515
mourinho's Avatar
Trader Rating: 42 (100%+)
Zylux - I experienced similar issues with the rear end spinning out on similar track conditions.
The thing that helped the most was loosening the diff, I had it far too tight from when I was running on carpet, then going to hardpack with dust it was all over the place.
mourinho is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22971 Yesterday 08:14 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
