    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 05-31-2014, 10:40 AM   #10456
Trader Rating: 49 (100%+)
Does it matter if the car is rear motor or mid motor when it comes to the piston selection and oil weight?
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 05-31-2014, 11:28 AM   #10457
ThePanda's Avatar
Trader Rating: 64 (100%+)
yeah. with the weight in a different part of the car you need different suspension settings (springs as well) to get the car to drive like you would want in each setting.
ThePanda is offline   Reply With Quote
Old 05-31-2014, 05:47 PM   #10458
KalEl63's Avatar
Originally Posted by Zylux View Post
Interesting. I'd have thought maybe more % rear than that. My mid motor is about 62.x % at the rear.
I decide to do my MM too with saddles all the way back and I got similar numbers in F=36.5% and R=63.5%.
I may have to look at how I am doing this with one scale
Team Associated RC10 B6D
Team Associated RC10 B64D
Team Associated RC10 T5M
1.21 GIGAWATTS!!!
KalEl63 is offline   Reply With Quote
Old 06-01-2014, 01:44 AM   #10459
Zylux's Avatar
Wow. That's a lot of rear bias for mm. I have my shorty pushed right back against the motor and can't get near 63.5%. Are you running a full size servo? I guess I did take a lot of weight out of the rear (avid slipper, MIP pucks CVD kit, lightweight chassis etc) but still. What is the total weight of the car?
I use four individual 0.1g scales to do my front/rear left/right measurements. I guess if you are using only one scale you would need to at least place something the same height as the scale under the front wheels. Are both rear wheels able to get onto the scale?
Zylux is offline   Reply With Quote
Old 06-01-2014, 06:16 AM   #10460
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
Went to 1.5 front 1.6 rear piston with 30/25 losi oil. I liked that pretty good, it allowed the car to be a little more precise.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is online now   Reply With Quote
Old 06-01-2014, 12:11 PM   #10461
Can someone explain to me why we use different size shock ends. I know it has something to do with droop. Example if I want 27mm in the rear and could achieve this with md or lg ends which should I choose?
My Credit Card
Old 06-01-2014, 12:29 PM   #10462
Teufel Racing's Avatar
Trader Rating: 28 (100%+)
It's mostly about the droop, but also the overall shock length.
If you can get 27mm between the bottom of the shock and top of the shock end for both med. and long shock ends, the over all shock length will be a little different. Which would mean that the droop would be different between the two, even though you have 27mm set on either configuration.
J.Mikoliczyk
RB6 - MBX7R Eco
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is offline   Reply With Quote
Old 06-01-2014, 12:36 PM   #10463
So for low traction which would u recommend?
My Credit Card
Old 06-01-2014, 01:01 PM   #10464
K_King's Avatar
The difference is drive plunge. The taller the shock end the less CVD plunge on compression which frees up the car.
Old 06-01-2014, 05:24 PM   #10465
Trader Rating: 57 (100%+)
Can someone tell me the overall length of the medium shock end?
Got my car used and only found 2 sizes, not sure what is what.
PROMODVETTE is offline   Reply With Quote
Old 06-02-2014, 07:41 AM   #10466
Has anyone tried the brass bulkhead from ghea?
My Credit Card
Old 06-02-2014, 09:50 AM   #10467
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Have you guys tried using spacers to get rid of the extra droop say for sugar tracks? The excessive droop causes too much roll, I do love the longer ends on rear though.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 06-02-2014, 04:18 PM   #10468
eper's Avatar
Trader Rating: 14 (100%+)
Are u guys using this thread for both mm and rm discussions?
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 06-02-2014, 04:42 PM   #10469
Holmberg418's Avatar
No just run different shock ends and different droop. No need to put spacers on the inside of the shock. I normally around 20 front 28 rear with shock length "B" medium front long rear shock ends.
My shock set up right now for rm is front 30w 1.3x4 pink spring 20.5 length with med end. Rear 25w 1.3x4 red rear spring 28 length with long end.
Kyosho America, Hobbywing, Jconcepts, Lunsford, JTP
Full Throttle R/C Raceway www.ftrcr.com
Holmberg418 is offline   Reply With Quote
Old 06-03-2014, 01:11 PM   #10470
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Yes.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22957 09-22-2017 12:16 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
