    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 05-24-2014, 05:28 AM   #10441
Trader Rating: 48 (100%+)
Originally Posted by mourinho View Post
i finished building my rb6 recently coming from nitro and i swear 2wd's take longer to build and are more complicated than anything 8 scale...
i had the slipper set as per the manual with the nut flush with shaft end and found it to be slipping very badly, i tightened the slipper incrementally and could only eliminate slip with the spring completely compressed.
is this normal?
also i am now doubting the ball diff set up as there seems to be a strange whinning noise when on throttle.
ive never had problems running multiple nitro's and electric 8th scales, but this thing has me scratching my head.
Tighten the ball diff until u stop hearing that noise. Once u do that loosen the slipper.
Watch this
"How To Properly Build And Break In a Ball Differential and Slipper Clutch"
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 05-26-2014, 08:05 PM   #10442
Ultraspeed84's Avatar
Trader Rating: 45 (100%+)
anyone have part number for this arm? also explain why use this are vs gullwing arm?
yokomo yz-2
Ultraspeed84 is offline   Reply With Quote
Old 05-26-2014, 09:03 PM   #10443
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 05-30-2014, 05:18 PM   #10444
I'm looking for some input on piston and oil weight suggestion for low traction bumpy surface? I'm running rear motor.
My Credit Card
Old 05-30-2014, 09:21 PM   #10445
If you still have the stock pistons start with 37.5 front 32.5 rear and you may want to try the gold spring in the rear.
I prefer to run 4 hole pistons with 1.3mm holes with 35 front and 30 rear, it makes the car better and can handle bumps way better
nitroargi is offline   Reply With Quote
Old 05-31-2014, 04:30 AM   #10446
The local fast guy told me to use 25f and 20 rear losi, that seems low to me.
My Credit Card
Old 05-31-2014, 05:27 AM   #10447
Johno's Avatar
Yeah that's super low
www.sydneyrc.com
Johno is offline   Reply With Quote
Old 05-31-2014, 05:29 AM   #10448
Johno's Avatar
I run 35 front 30 rear on a very Broken and bumpy surface I just raise the ride height and seems ok
www.sydneyrc.com
Old 05-31-2014, 06:32 AM   #10449
KalEl63's Avatar
Just quick one, I decide to look at my weight %'s on my RM tonight and with a shorty all the way back my percentages are F=36% and R=64% is that about right on average?
Team Associated RC10 B6D
Team Associated RC10 B64D
Team Associated RC10 T5M
1.21 GIGAWATTS!!!
KalEl63 is offline   Reply With Quote
Old 05-31-2014, 06:46 AM   #10450
K_King's Avatar
I run 27.5/22.5 with 2x1.5 pistons
Old 05-31-2014, 07:14 AM   #10451
Zylux's Avatar
Interesting. I'd have thought maybe more % rear than that. My mid motor is about 62.x % at the rear.
Zylux is offline   Reply With Quote
Old 05-31-2014, 07:15 AM   #10452
Kevin that's what I was running in mm car. I switched to rear motor, u think I should leave the 1.5 pistons in or switch to the 4x1.3
My Credit Card
Old 05-31-2014, 10:31 AM   #10453
I was told my setup was way off when I posted it awhile back with the same shock package go figure.
Schuurspeed / Aero-model / Gear One / LG1
www.OHRCR.com
Gitsum is offline   Reply With Quote
Old 05-31-2014, 10:37 AM   #10454
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Same here from cody king setup.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 05-31-2014, 10:38 AM   #10455
aloksatoor's Avatar
lolz yeah a year back the 1.3x4 pistons were the hot ticket.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
