    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 05-18-2014, 08:12 PM   #10426
KalEl63's Avatar
jwcobra03 maybe try 3.5 degree rear toe it may just give you what you need
Team Associated RC10 B6D
Team Associated RC10 B64D
Team Associated RC10 T5M
1.21 GIGAWATTS!!!
KalEl63 is offline   Reply With Quote
Old 05-19-2014, 02:32 AM   #10427
Zylux's Avatar
So I just finished fitting all of the upgrade bits to my MM RB6; can't believe how much difference in weight between the stock arms and the carbon-composite arms! I actually thought the kit must have come with the carbon ones because I couldn't tell a difference visually but each pair of arms saves over 5 grams (good reduction in unsprung mass) and with the shock towers adds up to a total saving of over 15grams. Car is now sitting at 1465grams with no bits removed or any drilling etc done to lighten anything; and that's with a standard servo & standard 220g shorty (not these super light 160g ones I keep reading about. Just have to figure out where to add weight back in now to meet the 1499 requirement...
Zylux is offline   Reply With Quote
Old 05-19-2014, 01:40 PM   #10428
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Nice to know buddy. I might put back my full shorty after I get my hands on those. Might have to stock up, my LHS only carries the softer stock parts.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 05-20-2014, 01:26 PM   #10429
hello,is you can put satellites differential?
Balls do not work well, I like more of satellites.
a greeting
electrojer is offline   Reply With Quote
Old 05-21-2014, 10:37 AM   #10430
a greeting
Yes. there is a gear differential available
Jason Snyder
Check out my "YouTube" channel
www.youtube.com/shortcourseworld
Jason Snyder is offline   Reply With Quote
Old 05-22-2014, 10:15 PM   #10431
aloksatoor's Avatar
http://www.schelleracing.com/kyosho-...g-rack-SCH1042
mines ordered . Remember when the buggy launched a couple years back, we all had a huge discussion on this topic lolz finally came to fruition.
Old 05-22-2014, 10:27 PM   #10432
Trader Rating: 44 (100%+)
Yaiba & Exotek make similar aftermarket alu racks too
YOKObori MOkei
wyl03 is offline   Reply With Quote
Old 05-22-2014, 10:45 PM   #10433
aloksatoor's Avatar
Those slop out like crazy. No bearings they got king pins so it worse metal on metal grinding. This should be precise. I put the car with the kyosho aluminum rack on the hudy station and it's got 3 4 degrees slop on servo centered. This is after 8 or so race days on the rack.
Old 05-23-2014, 02:40 AM   #10434
I was involved in the development of this product, and it eliminates the slop from the rack. It also provides some additional adjustments, you can move the ballstuds out shortening the steering link lengths.
RB6 Ball Bearing Steering Rack Features:
1. Precision CNC machined and black anodized with laser etched Schelle logo.
2. Inboard “kit” location allows shifts steering pivots back 1mm for more Ackermann.
3. Wide pivot option shortens steering link for different bump-steer geometry which is more predictable as the chassis leans in cornering.
4. Steering pivots slop-free on 4 pcs 3x6mm flanged ball bearings.
5. Rack ballstuds anchor into black M3 aluminum nylon locking nuts.
6. Includes Steering Rack, M3 nuts, Bearings, Shims, and Instructions and Schelle mini decal.
7. Fits Kyosho RB6, RT6, SC6.
http://youtu.be/iY0HJOLmKiE
Jason Dias
http://www.facebook.com/jasondiasrc
Team Kyosho - AKA - KO PROPO - Hobbywing - Schuur Speed - Schelle Racing - OCRC Raceway - Tuning Haus
Jason.Dias is offline   Reply With Quote
Old 05-23-2014, 04:24 AM   #10435
gelshocker's Avatar
Good stuff! Will AMain carry it? Where can one order? Cheers,
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 05-23-2014, 04:25 AM   #10436
Easy fix...stop using setup stations!
nitroargi is offline   Reply With Quote
Old 05-23-2014, 09:32 AM   #10437
aloksatoor's Avatar
Got mine from schelle racings site. They take cards and PP of course. http://www.schelleracing.com/
Old 05-23-2014, 09:32 AM   #10438
aloksatoor's Avatar
haha hold your servo arm and jiggle the front hex :P
Old 05-23-2014, 11:36 AM   #10439
kdub's Avatar
Yes, it will eventually be stocked at A-Main. Will ship with their next order.
Chief Engineer, Schelle Racing Innovations, SchelleRacing.com - Team Associated - Reedy - JConcepts - Sanwa - MIP - StickyKicksRC - UpGradeRC - Darkside Designs
kdub is offline   Reply With Quote
Old 05-24-2014, 12:38 AM   #10440
mourinho's Avatar
Trader Rating: 40 (100%+)
i finished building my rb6 recently coming from nitro and i swear 2wd's take longer to build and are more complicated than anything 8 scale...
i had the slipper set as per the manual with the nut flush with shaft end and found it to be slipping very badly, i tightened the slipper incrementally and could only eliminate slip with the spring completely compressed.
is this normal?
also i am now doubting the ball diff set up as there seems to be a strange whinning noise when on throttle.
ive never had problems running multiple nitro's and electric 8th scales, but this thing has me scratching my head.
mourinho is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22956 Today 04:13 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
