    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 05-15-2014, 03:43 PM   #10396
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Originally Posted by CanyonCarverR1 View Post
Why not ceramic?
I have never been a fan of ceramic. I tried a set in my oval car way back in the day and I just didn't like them. I can't be more specific as I don't remember why I didn't like them, sorry.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 05-15-2014, 05:46 PM   #10397
Trader Rating: 57 (100%+)
I get chrome steel balls at mcmaster carr. 100 for 4.36. http://www.mcmaster.com/#standard-steel-balls/=rzdlzl The soft part is the diff ring, so if its broke in properly any ball will work fine.
PROMODVETTE is offline   Reply With Quote
Old 05-15-2014, 06:18 PM   #10398
ThePanda's Avatar
Trader Rating: 64 (100%+)
this store is just full of wonderful little items that work great for rc!
ThePanda is offline   Reply With Quote
Old 05-16-2014, 01:17 AM   #10399
Gayosaka's Avatar
Default Lightweight chassis
Now that the lightweight chassis has been out for a while, I'd like to know your feeling about it. Is it only useful for low grip and you suffer on high grip, or is it versatile enough using the sideguards that you can use it successfully on high grip too?
I run on high grip astro tracks, so I need the stiffness, but I also happen to run on really slippery tracks (unprepared dirt or gym floor) where I could do with a softer chassis.
Thx
RedWorkShop RZ6R / Kyosho RB6.6 / Kyosho ZX6.6 / Nosram power / Some MiniZ
www.rustidesign.com - Awesome custom stickers and cool stuff
Gayosaka is offline   Reply With Quote
Old 05-16-2014, 05:31 AM   #10400
Zylux's Avatar
Thx
Sorry I can't help, but funnily enough I just received all of the Kyosho alloy and carbon parts a few hours ago and just finished fitting the lightweight chassis. Will try it out tomorrow but I'm not experienced enough to give constructive feedback on it's effect on handling at this stage.
One thing I can say is that the LW chassis actually weighed 29.8g less than the standard one though - more than advertised!
On another note, I tried the car today on our local dirt/clay circuit where apparently everyone else runs rear motor because of lack of traction for MM. It was very dusty (track not swept) I was lapping faster and more consistently than a guy with a rear motor B5 and my car actually felt a lot worse with a 30g weight added to the rear; maybe more forward weight bias isn't a bad thing after all. The RB6 was jumping extremely nicely and much better without the weight added to the rear.
So far the only rear tires that are working on this track for me are the AKA Impact Evos in SS compound. Rebars and Deja-Vu rears have no traction and Rebar fronts are also very poor. The pinstripe evo fronts aren't too bad but the 3 rib fronts are the best so far for me. Based on this are there any other tyres I should try on the front? Proline M4 Hole Shots worth a shot?
On another note; man do tires wear out quick!!!
Zylux is offline   Reply With Quote
Old 05-16-2014, 05:58 AM   #10401
Trader Rating: 49 (100%+)
Anyone have a good rear motor low traction setup they want to share?
Thanks to my sponsors:
My Credit Card
Speedychris22 is online now   Reply With Quote
Old 05-16-2014, 09:30 AM   #10402
Holmberg418's Avatar
Thx
I run on astro sometimes also. You don't need a stiff chassis for it to work good. For astro my mm car is at 1499 . With no side guard screws in and no motor guard (with the stock chassis). It's really easy to drive and very nible and quick in the corners.
Kyosho America, Hobbywing, Jconcepts, Lunsford, JTP
Full Throttle R/C Raceway www.ftrcr.com
Holmberg418 is offline   Reply With Quote
Old 05-16-2014, 09:50 AM   #10403
Thats for sure. Like 90% of the hardware you would need you can get at mcmaster! I'm lucky (or unlucky to my wallet ) enough to live close to the Atlanta warehouse so get to go pick it up.
Old 05-16-2014, 03:41 PM   #10404
something close to mine but 25 and a white spring in the rear and maybe go up to 35 in front
Jason Snyder
Check out my "YouTube" channel
www.youtube.com/shortcourseworld
Jason Snyder is offline   Reply With Quote
Old 05-16-2014, 05:09 PM   #10405
How are ur hubs positioned? Forward, middle or rear? Also what about the arms?
My Credit Card
Old 05-16-2014, 08:25 PM   #10406
forward and stock arms
Jason Snyder
Old 05-17-2014, 06:32 AM   #10407
hacker's Avatar
Trader Rating: 140 (100%+)
Default lipo rear position
Hi, does anyone run the lipo all the way back, and place the esc in another position?
I've just started runniing the japan setup, and well.......it's crap haha, no forward traction.
Dont have any lighter springs to try yet, but another order-another 2 weeks wait. Yeh it's crap living the other side of the world......
hacker is offline   Reply With Quote
Old 05-17-2014, 03:24 PM   #10408
Teufel Racing's Avatar
Trader Rating: 28 (100%+)
RM or MM?
If in MM, I did run with the batt as far back as I could get it at the time, prior to the RT6 coming out and guys running the rear battery stop from the RT6 that moves the batt a little further back. I had both the ESC (R10) and RX in front of the batt, side by side, ESC on the right and Rx on the left. I got a little more steering that way (the R10 is a little heavier than other ESC's out there), but gave up just a little rear traction. Ended up adding 1/2oz (14g), right behind the batt and in front of the motor to try and rebalance the car a little better. Worked fairly well for the most part, though have since changed the layout to the ESC in the rear and batt in front of it.
Japan setup?
I ran the kit setup in RM for a bit, which I think is pretty close to the Japan setup or one of the Japan setups. It was ok if there were small jumps, but anything of decent size and it lacked the "pack" needed. If you got the stock 5 hole pistons in the shocks, ditch those puppies. Unless you want to try a heavier shock oil with them first.
Yes, living in Aus. doesn't make many things easy. Talked to a couple Aus. guys at the Cactus race this year and it doesn't sound like fun trying to get a lot of the RC items needed at a cheap or cheapish price or quickly.
J.Mikoliczyk
RB6 - MBX7R Eco
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is offline   Reply With Quote
Old 05-17-2014, 04:44 PM   #10409
KalEl63's Avatar
Yeah I didn't find that set up the best for me either.
There are two shops that I know of that are stocking K stuff at good prices so its getting easier for K part now here in Australia.
I run my shorty lipo all the way back with the ESC behind that (as in the manual) but I'm running white springs or gold with 4x1.3 pistons.
Mind you my set up is a lot different now than the Japan set up.
I am going to try the 2x1.6 pistons next.
Team Associated RC10 B6D
Team Associated RC10 B64D
Team Associated RC10 T5M
1.21 GIGAWATTS!!!
KalEl63 is offline   Reply With Quote
Old 05-17-2014, 06:33 PM   #10410
hacker's Avatar
yeh I'm after those white springs, but for now I have some x-gear(tamiya) springs and losi's to try.
and yes RM car.
I actually like the 5hole pistons, as my track is quite bumpy.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22957 09-22-2017 12:16 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
