    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 04-21-2014, 11:16 PM   #10306
Originally Posted by Gitsum View Post
Yes the springs are pricey but I have had the car since it released. All I ever use are front....pink or white. Rear....kit spring, gold or white. I have all the rest but for the springs I listed should cover anything from loose dirt to sugared.
Originally Posted by bigdaddy13 View Post
Agreed. White or pink front and white,red,or gold rears you should be covered. That's all I own.
agreed fellas but we're still talking $65+ for three sets of springs!
I have all the springs you guys mentioned.......but i still feel like it was money wasted........
Jason Snyder
Check out my "YouTube" channel
www.youtube.com/shortcourseworld
Jason Snyder is offline   Reply With Quote
Old 04-22-2014, 01:11 AM   #10307
That is sweet looking. What would the street price be?
Currently, I am getting it quoted. My estimation is around $40 +/- 10%. The price varies depending on quantity. That's why I am asking who's interested.
QIMB528 is offline   Reply With Quote
Old 04-22-2014, 09:36 AM   #10308
Ok getting ready for outdoor season and I have the 705 and 707 sus hangers coming , any suggestions for starting point with them ? Track is med bite . yes I'm going to try mm . thnx
Mike Richardson
At the track having fun with my friends
blingy is offline   Reply With Quote
Old 04-22-2014, 02:37 PM   #10309
Cool design but, though I know that's a killer epoxy, I'd think a two piece design with a 7075 aluminum pad could be nearly as light, cheaper to make and maybe even stronger especially if some of the bonds turned out to be less than perfect.
kineteks is offline   Reply With Quote
Old 04-22-2014, 04:38 PM   #10310
I am sorry, but I have to disagree. Weight wise, 7075 aluminum version weighs 33.5 grams (without screws holding together); CF version weighs 23.9 grams. Cost wise, I did quote for both versions and the CF version is actually less expensive than the aluminum version without anodizing. Strength wise, the epoxy is a overkill and is actually used for airplanes, a five-minute epoxy from Home Depot is sufficient for this application.
Here is a cross section of the proposed CF RM rear shock tower. I understand that its difficult to see, but the vertical piece is actually inserted into the horizontal piece when bonded. This structure with the two ribs on the side will be sufficient to withstand a lot of impact. Especially when the shock tower is connected to the rear gearbox.
If it were to distort upon an impact, the distortion point would be where the shock is mounting to the tower. CF have a tendency to bounce back as where once aluminum bends, it's bent.
Old 04-22-2014, 04:52 PM   #10311
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Plastic composite is as light (with glass fill), is just slightly weaker than cf, does not bend, does not delaminate like raw cf sheets and is cheaper and available from kyosho. Why upgrade the factory part except for bling?
I am however partial to cf chassis. It does allow a lot more tuning with the weave/thickness chosen. The onroad TC guys get all the good stuff. With aluminum its a lot more labour intensive with milling pockets out etc.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 04-22-2014, 05:39 PM   #10312
Trader Rating: 47 (100%+)
Send a message via AIM to smitty2802
I went with the LF springs from TLR. I think $50 and you get 4 pairs of fronts and 5 pairs of rears. Cheaper and the LF springs are similar to the kyosho springs.
~Jconcepts~EA Motorsports~
smitty2802 is offline   Reply With Quote
Old 04-22-2014, 06:09 PM   #10313
bigdaddy13's Avatar
Trader Rating: 84 (100%+)
Have you tried different pistons or oil weights? I don't think it's money wasted,bottom line,Kyosho parts are expensive. I think we all can agree on that.
Tony Purvis
"Life is hard,even harder if you're stupid." John Wayne
bigdaddy13 is offline   Reply With Quote
Old 04-22-2014, 06:18 PM   #10314
I've tried a lot of pistons for a looser track I like the kit pistons and I'm currently running 35 fr and 30 rr tl oil and kit springs it rocks just my .02
Mike Richardson
Old 04-23-2014, 11:01 AM   #10315
QIMB528, no disrespect meant and I assumed you'd keyed the tower to the base, the ribs too? I wasn't clear either in that I was referring to a CF tower w/7075 base. Not a criticism just an opinion. As I said before, cool part.
Old 04-23-2014, 12:41 PM   #10316
Trader Rating: 14 (100%+)
Send a message via Skype™ to Jamiez
Default New to Kyosho
I just picked up an MP9 and I am thinking about an RB6. Do you suggest buying a new kit or a used one on here? I have also heard that I should wait two months for the new Worlds kit coming out, and I have heard that the difference in cars is not much. Any advice is greatly appreciated.
Jamie Z
Kyosho
MP9e TKI3 / Tekin RX8 / Tekin 1900 / Savox / Airtronics
RB6 / Tekin RSpro / Tekin 7.5 / Savox / Airtronics
Support Your LHS: TriCounty Hobbies: (954) 721-5720
Jamiez is offline   Reply With Quote
Old 04-23-2014, 04:37 PM   #10317
NumberOnePilot's Avatar
Send a message via Skype™ to NumberOnePilot
I like it. Just acquired my RB6!! Subscribed
NumberOnePilot is offline   Reply With Quote
Old 04-23-2014, 06:20 PM   #10318
bigdaddy13's Avatar
If you find a good deal on a used car,snatch it up,they're out there. Either way,new or used,the car is bad ass.
And don't think I've heard anything on a Worlds car coming out in a couple months. Only thing I have heard is maybe a ZX6 around August.
Tony Purvis
Old 04-23-2014, 06:22 PM   #10319
bigdaddy13's Avatar
And while I'm on here,what does turning the steering rack around with the arrow back do? Saw it on Cody Kings worlds setup.
Tony Purvis
Old 04-23-2014, 06:36 PM   #10320
aloksatoor's Avatar
Yep always run it that way. Smoothens the steering all through the corner entry, mid and exit. Kinda like more toe out front without scrubbing straightline speed. The kit way makes it a bit darty so end up loosing some speed mid corner trying to correct.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22984 Yesterday 10:14 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15026 11-02-2017 04:19 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
