    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree17Likes
Old 03-29-2014, 10:12 AM   #10231
Well I ran the rb6mm last night for the first time and all I can say is wow it steers like no other and has lots of traction out of the corners . the set up I have on it is Fr:stock pistons and springs w/32.5 and the c/l in #3 w/1mm spacer . RR: stock pistons and springsand standard locations with the arm spaced forward and hubs in the middle and c/l w/1mm on hub and tower . I ran the ride height at 24 mm and a saddle pack against the motor waterfall and the speed control between the servo and battery . awesome car
Mike Richardson
At the track having fun with my friends
blingy is offline   Reply With Quote
Old 03-29-2014, 08:08 PM   #10232
hacker's Avatar
Trader Rating: 140 (100%+)
Default Non cab forward body?
Not a big fan of cab forward bodies.
Does anyone make a normal body for the rb6?
hacker is offline   Reply With Quote
Old 03-29-2014, 10:48 PM   #10233
ThePanda's Avatar
Trader Rating: 64 (100%+)
anyone need a brand new built RB6 never run? PM Me
ThePanda is offline   Reply With Quote
Old 03-30-2014, 03:41 AM   #10234
FallenAllDay's Avatar
First race with my rb6 today, running rm on a big loose outdoor track, never ran 2wd buggy before and won the race by over a lap!! Cars so smooth, jumps like a dream and has all the steering i wanted. Best freaking car cant wait to drive more
TLR 8IGHT 4.0, OS Speed, Sanwa M12s/Ko servos
KYOSHO RB6, Orion, Sanwa M12s/Ko servo
Powered by my wallet.
FallenAllDay is offline   Reply With Quote
Old 03-30-2014, 09:59 AM   #10235
bigdaddy13's Avatar
Trader Rating: 84 (100%+)
Yeah buddy,this car is a beast in rear motor. I just haven't had a chance to try it in mid,just need a track around here with enough traction first.
Tony Purvis
"Life is hard,even harder if you're stupid." John Wayne
bigdaddy13 is offline   Reply With Quote
Old 03-30-2014, 11:09 AM   #10236
Mm still works fine on even low traction tracks don't hesitate to try it.
Schuurspeed / Aero-model / Gear One / LG1
www.OHRCR.com
Gitsum is offline   Reply With Quote
Old 03-30-2014, 02:56 PM   #10237
1967rs's Avatar
Trader Rating: 55 (100%+)
The TAMIYA 201XR/XM body fits the car perfect and is not cab forward.
Thank you, Pemberton Raceworks, Team Tekin, Team Trinity and Sweep Racing USA for your outstanding support to the Military.
www.facebook.com/DoakWorksDesign
D-W-D@comcast.net
1967rs is offline   Reply With Quote
Old 03-31-2014, 07:12 AM   #10238
Default First time RB6 build
Build went pretty good. I'm impressed with the quality and tolerances of parts. Can't wait to hit the track this weekend.
Need help with a couple of things.
After re-reading the manual after my build I noticed that I MAY not have set the rounded edge of the differential plates facing the balls. I did sand the diff plates as I always do with every diff build. If the rounded edge of the plates aren't facing each other will this degrade performance in any way?
The upper plastic ball / eyelets for the shock caps have a fair bit of slop in them. Is this normal? Bottom ones seem fine and fits well.
In MM Mid-motor configuration the bottom of the rear shocks only mount to 1 hole location. Shouldn't there be more locations? Are my arms backwards?
Vincent_Diesel is offline   Reply With Quote
Old 03-31-2014, 07:44 AM   #10239
Trader Rating: 82 (100%+)
Many people turn the Kyosho rings after some time. I've driven other diffs and love the Kyosho rings as it feels it last for months.
Upper shock caps always feel there's some slop, don't over tighten as you dint want it to bind.
Your rear arm is in the middle location per setup sheets. If you want to use inner or outer, you would have to reverse your a-arms.
"Tinkering with Toy Cars that go around in circles"
OCRC | Club R/C | Mike's Gulf Coast | Kyosho RB6 ZX6 MP9E
Kuya_Kimo is offline   Reply With Quote
Old 03-31-2014, 07:50 AM   #10240
Thanks for the reply Kuya. So it seems I didn't mess this build up : ) I wish the manual could've been on par with the car itself… I suppose it could be worse.
Old 03-31-2014, 04:24 PM   #10241
Trident69's Avatar
Totally agree, won 2 club meets on her with MM SETUP, No weights add on to her at all, all I did was to change piston and play around shock WTs to get the correct feel and land on receiving nicely.
But our racers here have to use sweep square amour Tyres for the rear as it's controlled, sweep Tyres are great but for mm setup, after about 50% usage, I will lose rear traction, still drivable but not great.
As for RM, we can drain down the Tyres more.
Cheers!
"Power is nothing without Control"
Yokomo - Yz-2/Yz-2 DT/ Yz-4 / Bmax2MR/Bmax 4/3
Xray - XB4'16
Awesomatix - Evo 2
Trident69 is offline   Reply With Quote
Old 03-31-2014, 04:30 PM   #10242
I hear that, It's as if the manual was made in Japan then translated later.
Have fun with your new ride.
Old 04-02-2014, 08:24 AM   #10243
Anyone have a good starting point for mm with a saddle on a med traction track . also I've heard that the lighter the better the car works can anyone elaborate on this plz . thnx
Mike Richardson
Old 04-02-2014, 09:28 AM   #10244
Default Chassis screws
Will the removal of chassis screws, especially in MM (2 bottom of motor guard) to gain more traction also increase the likelihood of the chassis bending?
Old 04-02-2014, 07:34 PM   #10245
Ran my rb6 tonight and picked up a second over my fastest lap ever..I am a novice tho, But this thing drives like butter and jumps so flat..My previous buggy was a MMsrx2 serpent.. Traded it for this when I broke the chassis in half from hitting a pole.. I think I got the better end of the deal..
Noslo50 is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22971 Today 08:14 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
