Kyosho Ultima RB6 & RB6.6 Car Thread >
Like Tree172Likes
    Hide Wikipost
R/C Tech ForumsThread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Old 03-27-2014, 08:57 AM
  #10216
Trader Rating: 96 (100%+)
Answer here about piston hole-
http://www.rctech.net/forum/13075699-post10036.html
Eric Tomczyk is offline
Old 03-27-2014, 09:30 AM
  #10217
Thank you Eric
blingy is offline
Old 03-27-2014, 10:31 AM
  #10218
Trader Rating: 25 (100%+)
I wouldn't so eagerly throw out the stock pistons. I use them in my setup and the car runs great. Give them a try at least and change if necessary.
chevmaro is offline
Old 03-27-2014, 10:34 AM
  #10219
I have no plans on throwing them out . what is a good oil to start with on a small indoor mm with a sadde and med traction?
blingy is offline
Old 03-27-2014, 09:11 PM
  #10220
I just recently installed both the aluminum steering crank set and aluminum steering plate on my rb6 and I feel like I have a lot more play (wiggle) now then when it was all plastic. Am I suppose to install washers with them or something to help with the play? If so metal or plastic and where? On the bottom or where the screw is? Or is play good? :-(
P.S. I've already installed the 1mm plastic collar on the bottom as the manual suggests. Just wondering if I should at anything else?
Kopanas is offline
Old 03-28-2014, 04:10 AM
  #10221
gelshocker's Avatar
Did you buy some new bushings?
http://www.amain.com/product_info.ph...King-Pin-Set-4
gelshocker is offline
Old 03-28-2014, 08:08 AM
  #10222
offroad dude's Avatar
Trader Rating: 31 (100%+)
What are you guys useing to keep your battery in place when running MM with the battery pushed all the way back against the motor? If anybody have a clean Pic whould they please post it.
offroad dude is offline
Old 03-28-2014, 08:29 AM
  #10223
the big rc's Avatar
Trader Rating: 40 (100%+)
Servo tape is what I am using per Kyosho team managers advice
the big rc is offline
Old 03-28-2014, 09:10 AM
  #10224
mblgjr's Avatar
Trader Rating: 86 (100%+)
Anyone know if the JC Finnisher can be trimmed to fit the car in MM configuration? And look ok in the rear
mblgjr is offline
Old 03-28-2014, 09:56 AM
  #10225
Gayosaka's Avatar
It fits fine but you still have a gap at the back.
Attached Thumbnails Kyosho Ultima RB6 & RB6.6 Car Thread-img_3345.jpg   Kyosho Ultima RB6 & RB6.6 Car Thread-img_3582.jpg
Gayosaka is offline
Old 03-28-2014, 10:33 AM
  #10226
The guys running gear diffs what are you running for oil in it and does it just drop in the mm case?
Gitsum is offline
Old 03-28-2014, 10:40 AM
  #10227
So, you pretty much run the same battery all day.
Old 03-28-2014, 12:30 PM
  #10228
Mxpdx's Avatar
3k and yes it fits great.
Mxpdx is offline
Old 03-28-2014, 02:06 PM
  #10229
Originally Posted by gelshocker
Ahhh... no... are these not the bushings that come with the RB6 already?
Kopanas is offline
Old 03-29-2014, 01:33 AM
  #10230
gelshocker's Avatar
I don't know if they're the same material as the kit but I changed out fresh bushings when I installed the new alum steering.
Also, blue thread lock the screws as they'll come loose after runs.
Cheers,
