Kyosho Ultima RB6 & RB6.6 Car Thread
dont really want to go through 680 pages, so quick question.
what is 'really' required for this buggy?
I heard early on it was to put the rb5 steering rack. Whats wrong with the rb6 rack?
Will the exotek setup be just as good?
I think the idea was an aluminum steering rack. I have the Kyosho steering rack which I recommend as it's has been perfect since day one with almost no slop. The stock plastic rack works just fine but if you hit pipes often, the rack will break.
Our local track here is very loose and not much traction.. I am running 21 ride height.
Ok thanks trident
Super Moderator
Plus the kyosho rack matches all the other gunmetal washers, hubs, blocks, etc that you will probably end up putting on the car (for bling, if that's your thing) anyways!
A couple quick questions:
- In Cody King's Reed Race setups sheet he states he uses 5x13 outer bearings in the rear hub. What is the part # for that? Is it 5x13x4?
- In Cody King's Reedy Race setup sheet for the Sus Holder Spacer F and R it says none and none and a 2 degrees anti-squat. In position 130 on page 23 of the manual does that mean I should put 1.5mm shim and nothing in A?
I really appreciate the 411. Thanks.
As for the rear suspension hangers he's using the new umw705 and umw707 hangers. That info is just to the right of the other rear hanger info on the setup sheet. The new hangers use inserts rather than buying a bunch of different hangers. According to the sheet he's running D in on both.
With Tebo's set-up sheets. Anyone know if shock oil weights that are noted, correlate to Losi, or to AE?
