    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 03-19-2014, 10:41 PM   #10171
Mxpdx's Avatar
Originally Posted by ThePanda View Post
is that running with the stock gears in the diff, or the pricy upgrade steel ones?
Stock gears 3k. It's money.
Kyosho RB6~Orion
Yokomo B-MAX2 Ver3
Mxpdx is offline   Reply With Quote
Old 03-20-2014, 03:29 AM   #10172
FallenAllDay's Avatar
You guys running stock, do youse all just run your slippers tight? Ive got no idea how to set it otherwise. I figured the wheel lifting technique where you pin it down would work, but found out only mod motors have enough power to lift the wheels. Thanks for any help.
TLR 8IGHT 4.0, OS Speed, Sanwa M12s/Ko servos
KYOSHO RB6, Orion, Sanwa M12s/Ko servo
Powered by my wallet.
FallenAllDay is offline   Reply With Quote
Old 03-20-2014, 04:11 AM   #10173
ThePanda's Avatar
Trader Rating: 64 (100%+)
Loose as you feel comfortable, without burning off excess power. Even in a slower class like stock, the drivetrain is still subjected to large impacts, and the slipper should still be able to slip when these occur, rather than the diff slipping or out drives wearing excessively.
ThePanda is offline   Reply With Quote
Old 03-20-2014, 07:45 AM   #10174
Trader Rating: 23 (100%+)
My trinity D3.5 will lift the wheels but it really depends on gearing.
Set the slipper so it doesn't slip, that clicking cogging noise. Then loosen a teeny bit at a time until it slips. This give you minimal slip and good to go. Make sure your diff is tight and won't slip when you do this.
chevmaro is offline   Reply With Quote
Old 03-20-2014, 07:13 PM   #10175
Anyone try using associated big bore springs or losi? My Lhs doesn't stock any kyosho stuff
Jspires688 is offline   Reply With Quote
Old 03-20-2014, 07:48 PM   #10176
I'm looking to do some testing with Avid machined shock pistons. Has anyone done any testing with these pistons? I am looking for a starting point. I am currently running my RB6 in mid motor with stock pistons. 37.5 Losi oil front with pink springs. 30 Losi oil rear with gold springs. Thanks for any advice!
Hollywood_26 is offline   Reply With Quote
Old 03-20-2014, 07:52 PM   #10177
Holmberg418's Avatar
the ae springs seem to big. I have lost 3 shock retainers using them.
Kyosho America, Hobbywing, Jconcepts, Lunsford, JTP
Full Throttle R/C Raceway www.ftrcr.com
Holmberg418 is offline   Reply With Quote
Old 03-20-2014, 08:14 PM   #10178
Holmberg that sucks I was hoping to be able to use them. I am running rear motor and the b5s are hanldeling a little better for everyone on my home track
Old 03-20-2014, 08:55 PM   #10179
Trident69's Avatar
am running TLR springs front and rear, Front should be pink and rear white.
Pistons are Avid 1.1x1.6 holes front and rear, using TLR weight 32.5 and 30 rear
"Power is nothing without Control"
Yokomo - Yz-2/Yz-2 DT/ Yz-4 / Bmax2MR/Bmax 4/3
Xray - XB4'16
Awesomatix - Evo 2
Trident69 is offline   Reply With Quote
Old 03-21-2014, 04:56 PM   #10180
Trident are they 4 ole pistons?
Old 03-21-2014, 10:15 PM   #10181
kenny lutz's Avatar
Trader Rating: 36 (100%+)
Got my new orion r10 stock esc wired up. Very happy with how it turned out.
Kyosho Rb6.6- Maclan mmax - Fantom 17.5
Kyosho Zx6.6- Maclan mmax - Fantom 13.5
Airtronics M12 - Auer Ace Hardware - Schelle
kenny lutz is offline   Reply With Quote
Old 03-21-2014, 11:31 PM   #10182
Trident69's Avatar
Yes sir they are.. Avids 4 holes pistons 2 are 1x1 and the other 2 holes are 1x6
Xray - XB4'16
Awesomatix - Evo 2
Old 03-22-2014, 06:35 AM   #10183
Good deal trident my car has 4 hole pistons but I'm not sure what they are as I bought it used but I looked and have those losi springs in my box already so I will try them what's your ride height set at?
Old 03-22-2014, 04:54 PM   #10184
quick gearing question, i bought my RB6 used and it had a 78 pinion on there from associated along with the high friction pads(yellowish). The RB6 mod suggestion is 22/76. I like the way associated slippers are and was wondering what would give me the closest feel to 22/76, go 25/75 or 21/78 maybe 20/78? with 22/78 my car seems to lack the jumpiness that most mod cars have, to me my car feels a little lethargic, but has great top end, if our track had longer straight a way, i would have a lot more trigger that could be utilized so i feel im a little over geard.
CaseyD is offline   Reply With Quote
Old 03-22-2014, 07:48 PM   #10185
VenturaDC's Avatar
Trader Rating: 32 (100%+)
What turn motor?
Dustin Colt45 Aguirre
Kyosho RB6--Futaba--HW--Shuurspeed 17.5
Kyosho SCR--Hitec--Lrp--Yeah 13.5
Durango Dex210--Futaba--Trakpower--Tacon 8.5
VenturaDC is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22957 09-22-2017 12:16 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
