    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 03-18-2014, 02:06 AM   #10156
Trident69's Avatar
Good afternoon Gents,
for the rb6 mid mount, if you look from the side view at the rear shocks, do they lean at an angle coming down to the eyelet when you mount it on the rear arms?, meaning it is not perpendicular down straight. i have now used 3mm spacer just to just it almost straight down, will there be any adverse effect on the handling or should i just leave it ?
any comments?
"Power is nothing without Control"
Yokomo - Yz-2/Yz-2 DT/ Yz-4 / Bmax2MR/Bmax 4/3
Xray - XB4'16
Awesomatix - Evo 2
Trident69 is offline   Reply With Quote
Old 03-18-2014, 07:53 AM   #10157
Trader Rating: 24 (100%+)
any comments?
I think you are saying straight as in front to back? I built mine per the kit didnt use any extra spacers and it works fine. I know on my other cars like the B4.2 the shocks lean quite a bit. As long as there is no binding it is fine.
chevmaro is offline   Reply With Quote
Old 03-18-2014, 08:23 AM   #10158
Trident69's Avatar
Leaning should be the correct word here, as mine leans quite abit, I have tried taking out the spacers from the shock towers and adding 3mm spacer at the eyelet and now it looks quite straight.. Guess it would not affect the buggy too much if I do that.
Xray - XB4'16
Awesomatix - Evo 2
Old 03-18-2014, 12:57 PM   #10159
Gopher15's Avatar
Trader Rating: 18 (100%+)
Has anyone gad any luck with running the gear diff in there RB6 either rear or mid motor?
Scott Hurley
Boys Makin Noise Hobbies/Kustom RC Graphics
Gopher15 is offline   Reply With Quote
Old 03-18-2014, 01:20 PM   #10160
1967rs's Avatar
Trader Rating: 55 (100%+)
any comments?
I spaced mine out at the arms, still not straight but closer. I don't know if it has any effect on handling but it looks better to me with the spacer.
Thank you, Pemberton Raceworks, Team Tekin, Team Trinity and Sweep Racing USA for your outstanding support to the Military.
www.facebook.com/DoakWorksDesign
[email protected]
1967rs is offline   Reply With Quote
Old 03-18-2014, 01:40 PM   #10161
E73
E73's Avatar
Noticed on petitrc.com setups that drivers are putting 1.5mm axle height spacer under the front axle vs. 1mm under and 0.5mm over (stock setup). Ideas what this does to handling?
E73 is offline   Reply With Quote
Old 03-18-2014, 11:35 PM   #10162
Default cvd rebuild/repair
Using stock shafts with, avid axles. cvd pin/coupler or barrel whatever it's called. Kyosho does not sell the parts separately, why they don't is beyond me Is there any other brands that fit? m.i.p, losi, ae, etc or do I have to swap over to the whole mip system? and use there shafts etc. What option are out there? I know this can't be the first time this has come up.
Kyosho MP-9 TKI3, Tekno SCT-410, AE B5M, AKA racing, Mel's Shells, Family Hobbies in Vineland NJ, Sjrc
purple rides is offline   Reply With Quote
Old 03-18-2014, 11:36 PM   #10163
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
It takes any bumpsteer out of the car when running 25/0 caster.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 03-18-2014, 11:45 PM   #10164
Trident69's Avatar
totally agree with you bro..i am on 3mm spacers just to make them look better at least it doesnt look like the leaning tower..hahah
cheers
Xray - XB4'16
Awesomatix - Evo 2
Old 03-19-2014, 01:42 PM   #10165
Graham11's Avatar
Trader Rating: 21 (100%+)
Just a heads up, may need to sell my brand new RB6. I just built it to factory spec but its never been wired up or run. All extra parts included and body is uncut.
PM me if interested.
Hot Bodies Racing - Team Pro-Line - Maxy's Fuel - LRP - Trinity
Hobby Hut - Trains N Lanes - Mushroom Bowl - LCRC
Graham11 is offline   Reply With Quote
Old 03-19-2014, 07:49 PM   #10166
jmc5313's Avatar
Default New Guy.......
Hello, I've been racing a B4.1 for a while now, but recently got a screaming good deal on a new RB6. I'm very anxious to see first hand the quality I've heard so much about! Any quick links to a setup for a large low traction track would be great. I have no experience with Kyosho so any other sites other than RC tech that provide info would be very much appreciated!! Thanks in advance-.......that new guy
AE SC10.2 -REEDY SONIC MACH 2 17.5 LRP FLOW
TLR 22 SCT LRP X20 7.5 LRP SXX TC
Kyosho RB6 LRP X12 8.5 LRP SXX TC
TLR SCTE 2.0 REEDY SONIC 550 4.0 LRP FLOW
3MTA3
jmc5313 is offline   Reply With Quote
Old 03-19-2014, 09:57 PM   #10167
CanyonCarverR1's Avatar
http://www.petitrc.com/setup/kyosho/...UltimaRB6.html
CanyonCarverR1 is offline   Reply With Quote
Old 03-19-2014, 10:01 PM   #10168
Mxpdx's Avatar
I've had some great luck with it. Running mid motor on high traction indoor clay track. The on power steering is off the charts. The first day running it a qualified 2nd in the A-main and I'm usually a B-main rock star.
Kyosho RB6~Orion
Yokomo B-MAX2 Ver3
Mxpdx is offline   Reply With Quote
Old 03-19-2014, 10:10 PM   #10169
ThePanda's Avatar
Trader Rating: 64 (100%+)
is that running with the stock gears in the diff, or the pricy upgrade steel ones?
ThePanda is offline   Reply With Quote
Old 03-19-2014, 11:14 PM   #10170
i ran the stock gears in the gear diff in 17.5 w 2k kyosho oil and it was tits
glenng is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22977 11-13-2017 05:09 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15026 11-02-2017 04:19 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
