    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 03-13-2014, 09:35 PM   #10126
jamminx11's Avatar
Trader Rating: 24 (100%+)
hey guys new to the rb6 can someone help me with the springs im going to start with the tebo setup on it my issue is the rear springs the color mark has been worn off so idk what they are the coils measure 1.11 mm are these gold springs?
Serpent, Tekin, Jconcepts, Bfast, futaba, Smc, Hobby Express, Upgrade RC
Special thanks to my wallet and everyone that helps me!
Have fun its a hobby!!
jamminx11 is offline   Reply With Quote
Old 03-13-2014, 09:43 PM   #10127
wisconsinbasher's Avatar
Trader Rating: 29 (100%+)
I just counted my coils I have 11 coils with gold springs
wisconsinbasher is offline   Reply With Quote
Old 03-14-2014, 08:50 AM   #10128
Trader Rating: 26 (100%+)
Im going to be running on a outdoor track. Can be grippy or a bit slick depending on how dry it is. Tires will likely be m4 holeshots or bow ties. Ive chosen to run rear motor to start. Is the prefered setup a stick, shorty or saddle packs with rear motor. Also what position is the preffered speedo.
eddie10 is offline   Reply With Quote
Old 03-14-2014, 11:43 AM   #10129
Graham11's Avatar
Trader Rating: 21 (100%+)
Hey guys, building my kit and it looks like they didn't include the 2 small black ball studs for the rear suspension tower, anyone else encounter this?
Hot Bodies Racing - Team Pro-Line - Maxy's Fuel - LRP - Trinity
Hobby Hut - Trains N Lanes - Mushroom Bowl - LCRC
Graham11 is offline   Reply With Quote
Old 03-14-2014, 01:13 PM   #10130
Hey mate check this link
http://www.petitrc.com/setup/kyosho/...ace2013012427/
Best setup for rear motor before I changed to mid. Has pictures for your electronic layout (shortie). I've run this setup a lot with holeshots and suburbs on the rear depending on the grip, I would recommended proline scrub front m3 with white foam or holeshot with white foam on the front, never liked ribs.
Tom87 is offline   Reply With Quote
Old 03-14-2014, 06:06 PM   #10131
mog ruith's Avatar
Chasis slap.... How do you guys usually counter this problem?
mog ruith is offline   Reply With Quote
Old 03-14-2014, 07:59 PM   #10132
Yes I did, I think Kyosho put the silver ones instead, not sure why.
skhadka17 is offline   Reply With Quote
Old 03-14-2014, 10:50 PM   #10133
The silver ball studs have longer threads that don't pull out as easy as the original kit ones
Old 03-15-2014, 06:56 AM   #10134
Graham11's Avatar
My kit didn't come w the updates rear bulkhead w the sway bar mounts, is that normal?
Old 03-15-2014, 08:03 AM   #10135
ThePanda's Avatar
Trader Rating: 64 (100%+)
It should be fine unless you were going run a sway bar. But wait, i thunk onlu the mm bulkhead is swaybar mounts. Is that how you built it, mm?
Yep, dont want those pulling out.
ThePanda is offline   Reply With Quote
Old 03-15-2014, 08:38 AM   #10136
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
I use UM128 in the rear and front bulkhead. I secure the rear with a locknut as well, and I put in a set screw in the hole not used.
I never run the black studs anywhere, not long enough.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 03-15-2014, 04:15 PM   #10137
Trader Rating: 82 (100%+)
That sucks! The new boxes also have a different chassis and a Tebo's WC medal badge.
"Tinkering with Toy Cars that go around in circles"
OCRC | Club R/C | Mike's Gulf Coast | Kyosho RB6 ZX6 MP9E
Kuya_Kimo is offline   Reply With Quote
Old 03-16-2014, 07:50 AM   #10138
Graham11's Avatar
What's different about the chassis? I don't care about the badge but what parts are different other than bulkhead?
Old 03-16-2014, 08:08 AM   #10139
Pics of new chassis on page 668.....
Old 03-16-2014, 08:19 AM   #10140
Graham11's Avatar
K cool, is it normal that my skid plate that screws into the front bulkhead is not flush w the chassis?
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22955 Yesterday 12:08 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
