    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 03-11-2014, 08:03 AM   #10111
Trader Rating: 23 (100%+)
Originally Posted by Graham11 View Post
it does not come w aluminum rack? do u recommend the JC over the exotek or another brand or all the same?
I agree get the rack. Mine did not come with an aluminum rack but I heard some of the earlier kits did. I have the exotek rack and the slider's. I started using the plastic rack and it was the first thing I broke first time to the track. Since replacing both of them with aluminum it's been pretty durable.
chevmaro is offline   Reply With Quote
Old 03-11-2014, 09:31 AM   #10112
mog ruith's Avatar
Exotek or yaiba
mog ruith is offline   Reply With Quote
Old 03-11-2014, 10:28 AM   #10113
ThePanda's Avatar
Trader Rating: 64 (100%+)
get the kyosho one.
ThePanda is offline   Reply With Quote
Old 03-11-2014, 12:21 PM   #10114
I am using a Spektrum 6070 servo. It seems very far off center. I have to run 80 sub trim on my m11x. The servo horn is pointing just 1 tooth in from center. I installed it the same as I have on my B4. I am using 1mm of shim and the servo link has a 1mm gap. If I move the horn the other way it is pointing past centered and angled toward the outside. Am I missing something or is it ok to be using this much sub trim?
Old 03-11-2014, 01:23 PM   #10115
1967rs's Avatar
Trader Rating: 55 (100%+)
I adjusted the link until I was close with the trim set to 0, then fine tuned with trim.
Thank you, Pemberton Raceworks, Team Tekin, Team Trinity and Sweep Racing USA for your outstanding support to the Military.
www.facebook.com/DoakWorksDesign
D-W-D@comcast.net
1967rs is offline   Reply With Quote
Old 03-11-2014, 04:25 PM   #10116
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Tip for the MIP pucks system. The hex always rubbed against the bearing shield for me in the rear hubs.
Tested by removing the camber link and spinning shaft by hand. Its fine for high grip but on low grip causes issues. I fixed it by removing the 5x10x4 bearing and replacing with 5x10x3 for the rear outer hub. Works like a charm. Also ruined an older MIP hex set by using impact driver for putting nuts on, never again .
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 03-11-2014, 04:26 PM   #10117
aloksatoor's Avatar
Originally Posted by ThePanda View Post
get the kyosho one.
+1 kyoshos the best. Exotek slopped out pretty fast, sold it in a hurry and got the kyosho
Old 03-11-2014, 07:06 PM   #10118
VenturaDC's Avatar
Trader Rating: 32 (100%+)
I've been happy with the revolution design rack so far about 4 months on it I believe
Dustin Colt45 Aguirre
Kyosho RB6--Futaba--HW--Shuurspeed 17.5
Kyosho SCR--Hitec--Lrp--Yeah 13.5
Durango Dex210--Futaba--Trakpower--Tacon 8.5
VenturaDC is offline   Reply With Quote
Old 03-11-2014, 08:21 PM   #10119
Originally Posted by socal23 View Post
I'm running 32.5/30 with avid 1.4x4 pistons. Kit springs and c out I'll try d out next then. I'm running Clay codes rear aka reds and suburbs open front. Riley set my diff last race. My only gripe with rm is I hardly have any off power steering going in the sweep is good just infield it corners wide unless I tap the brakes to get the rear loose otherwise it wants to push though the corners. I bumped up from b to a last Friday behind shay we were close but as long as he kept it together on the infield he could take the corners like a dart as we're I had to really work the car into the corners. This is why I was considering mm.
I will loan you some AKA foamed dirt webs to try on the front if you want. They have more steering IMO than codes. I thought codes were better than suburbs. If you still need more steering then lighten the oil in the front. If you go to D out in the front it will unlock the rear a bit by reducing the toe. You racing tomorrow?
AlwaysLOSI is offline   Reply With Quote
Old 03-11-2014, 08:45 PM   #10120
Trader Rating: 110 (100%+)
I only race Fridays. I work out of town during the week. What about ions? I have a brand new set frt/rear. Is the closed cell foams really nessacery?
*MIP/SCTE*
+FTM GRIP+
socal23 is offline   Reply With Quote
Old 03-12-2014, 04:12 PM   #10121
bigdaddy13's Avatar
Trader Rating: 84 (100%+)
Originally Posted by 1967rs View Post
For MM I am running D in on both. I am running the battery stop and esc shelf from the rt6 so I have the battery all the way back and the esc above the battery. I tried the shorty sideways I didn't like it, but it might work better for you. I also am running the light weight chassis with all the screws in, if you are a little loose you could remove some or all side rail screws and motor brace screws.
RM, RF B out RR C out for 3.5 deg toe.
Yeah I'm good to go on my mm setup,pretty much running Cody Kings Reedy setup with a few changes. Also going to try saddles all the way back with the esc behind the servo.
Just recently put the new susp. hangers on my rm car(I have 2 cars)and needed a little guidance on the inserts. Thank you for the help I'm going to try your recommendation. There aren't a whole lot of "current" rear motor setup sheets out there since it seems everyone is running mid motor. I'm trying both! Lol.
Tony Purvis
"Life is hard,even harder if you're stupid." John Wayne
bigdaddy13 is offline   Reply With Quote
Old 03-12-2014, 04:16 PM   #10122
bigdaddy13's Avatar
get the kyosho one.
+1,definately.
Tony Purvis
Old 03-13-2014, 08:35 AM   #10123
1967rs's Avatar
I am also running 2 cars one rear, one mid. I have a setup for rear that works good for me on med-high bit I will post it when I get a chance.
D-W-D@comcast.net
Old 03-13-2014, 09:44 AM   #10124
bigdaddy13's Avatar
Cool. I'd like to try it. Thanks.
Tony Purvis
Old 03-13-2014, 12:19 PM   #10125
Graham11's Avatar
Trader Rating: 21 (100%+)
hey guys, half way through building my new rb6 kit, doing MM set up. Does anyone have a good setup for carpet but not european style track. Its ozite with jumps etc... but no hard wood or other material for surface.
Hot Bodies Racing - Team Pro-Line - Maxy's Fuel - LRP - Trinity
Hobby Hut - Trains N Lanes - Mushroom Bowl - LCRC
Graham11 is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22941 Today 04:55 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
