    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 03-07-2014, 01:32 PM   #10036
cnelson3's Avatar
Trader Rating: 65 (100%+)
Originally Posted by chevmaro View Post
Still new to Kyosho. Can you tell me what size the stock pistons are? I know they are 5 hole for kit pistons. What are they equivalent to in a 2 and 3 hole piston?
The hole size is 1.35mm. For comparisons sake, "55's" are supposed to be 4 hole 1.3mm. Probably why gluing one hole shut only "kind of" worked.
cnelson3 is offline   Reply With Quote
Old 03-07-2014, 01:40 PM   #10037
cnelson3's Avatar
Old 03-07-2014, 01:41 PM   #10038
Trader Rating: 23 (100%+)
In my B4 I always ran 2x1.6 or 3x1.4. In this car it seems like the 5 holes are working. Car is driving great but it a little soft on pack. I don't think I will change anything because it is driving great. Curious though what you are all running for oil with the kit 5 hole piston? I am using associated oil 32.5 Front / 27.5 Rear. Thanks.
chevmaro is offline   Reply With Quote
Old 03-07-2014, 01:45 PM   #10039
Originally Posted by purple rides View Post
So what is the consensus on the new light weight chassis? Is it better for mm? or no real difference?
I hear it has more flex? Everytime I play with flex by removing screws I don't like it as much. It gets jumpy. I am running all screws in the chassis with kit chassis and it is running great.
Old 03-07-2014, 02:20 PM   #10040
aloksatoor's Avatar
Trader Rating: 42 (100%+)
LW is awesome for stock buggy. Helps the lighter car grip better (the stock with 1400~1500 gram weight felt loose and twitchy). I would not change it for a 1600 gram plus mod buggy. Stock is good enough.
I also did not like the car much without screws so back they go this weekend.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 03-07-2014, 03:26 PM   #10041
1967rs's Avatar
Trader Rating: 55 (100%+)
I just put together a mid motor car with the light weight chassis to run in stock class, I never ran the car with the stock chassis so I cant compare. I went with King's set-up from the reedy race (similar traction to my home track), all bulkhead and side screws were installed. The car pushed very bad in all the high speed turns, I cut the wing down and reduced the angle, then removed the rear weight. Now the car is awesome, I might still tune in a little more steering but the car is great fun to drive.
Thank you, Pemberton Raceworks, Team Tekin, Team Trinity and Sweep Racing USA for your outstanding support to the Military.
www.facebook.com/DoakWorksDesign
D-W-D@comcast.net
1967rs is offline   Reply With Quote
Old 03-07-2014, 04:24 PM   #10042
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
Changing those screws affects the torsional flex of the car (twisting) vs the lateral grip. With torsional flex you will always be at the mercy of the material and it's resiliency to flex and it's threshold. The more you twist the faster it wants to snap back. Some buddies of mine had that issue with their Tamiyas.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 03-07-2014, 07:24 PM   #10043
ThePanda's Avatar
Trader Rating: 64 (100%+)
what does everybody run besides the stock wheels? mine feel a little flimsy, and seem to be a little son the small side diameter wise.
ThePanda is offline   Reply With Quote
Old 03-07-2014, 07:49 PM   #10044
I use the same oils front and rear with 1.3x4 on all fours. and i felt like i needed more pack. was thinking of going 2x1.6 and 3x1.4, actually
glenng is offline   Reply With Quote
Old 03-07-2014, 07:53 PM   #10045
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Do you have big jumps on your track or are they on the smaller side?
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 03-07-2014, 07:54 PM   #10046
Super Moderator
Kraig's Avatar
I run the aka's but you need a low profile serrated wheel nut if you are running the stock rear axles for the rear wheels. You also have to make sure that the front wheels do not rub on the steering knuckle too.
Old 03-07-2014, 08:07 PM   #10047
One big jump i kept slapping hard if i aired it out. Felt nice other then that jump
Old 03-07-2014, 08:21 PM   #10048
ThePanda's Avatar
ok, thanks!
Old 03-07-2014, 08:51 PM   #10049
VenturaDC's Avatar
Trader Rating: 32 (100%+)
ok, thanks!
DE Speedline rims fit awesome as well, plus they come in multiple colors.
Dustin Colt45 Aguirre
Kyosho RB6--Futaba--HW--Shuurspeed 17.5
Kyosho SCR--Hitec--Lrp--Yeah 13.5
Durango Dex210--Futaba--Trakpower--Tacon 8.5
VenturaDC is offline   Reply With Quote
Old 03-08-2014, 02:00 PM   #10050
bigdaddy13's Avatar
Trader Rating: 84 (100%+)
Originally Posted by K_King View Post
I really like the LW chassis. I have all the steering I need but with more rear grip.
Rear or mid? And are you running all the screws?
Tony Purvis
"Life is hard,even harder if you're stupid." John Wayne
bigdaddy13 is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
