    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 02-24-2014, 10:26 AM   #9961
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
Been awhile since I've posted.
I've been trying a lot of different layouts. Short. Saddles. Short back. Short really back and finally the Tebo style layout. I have to say the Tebo layout feels the best balance wise. I was concerned that the extra weight up front would hurt, but it feels really good. I'm running the LW chassis as well which probably helps.
Fully loaded my car is 1556 with a 62.6% weight bias.
I'm also running a combination of Tebo and Cody's setup with a few changes. So far so good. Car is very planted right now.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 02-24-2014, 11:06 AM   #9962
Trader Rating: 23 (100%+)
I have been running mine shorty w/ esc in front of battery. Feels best with battery all the way forward. Wondering if it would feel better with esc behind and shorty even farther forward. might be giving it a try.
chevmaro is offline   Reply With Quote
Old 02-24-2014, 01:17 PM   #9963
+1 on this.
I'm running the worlds setup with narrow rear hangers and rear camber link from Cody king setup and it's money.
Tom87 is offline   Reply With Quote
Old 02-24-2014, 01:40 PM   #9964
K_King's Avatar
I've gone to a 1.6x2 rear shock since our track gets a little rough. Seemed better
I tried 2 anti squat but liked the extra side bite the 1 AS gave the car.
I'm going to try a gold rear spring though to see what that does. I lost a little pop off the jumps, which I expected.
Old 02-24-2014, 04:40 PM   #9965
Just curious, what makes Kyosho springs worth 20 bucks a pair? Avid springs are supposed to be pretty hard to beat and you can get 3- 4 pairs for 30?
CaseyD is offline   Reply With Quote
Old 02-24-2014, 04:45 PM   #9966
Trader Rating: 110 (100%+)
I have a question. I'm going for fora mid motor set up and I 0rderd some rf and rr blocks from exotek. I ordered a narrow rr block and a wide rf block. Unless I read that wrong on the set up sheet. Are the narrow and narrow and wide and wide supposed to go together? I'm switching to mm bc I am not getting enough steering and my track has med bite clay and and should be good for mm. Just trying to make sure I ordered the right blocks. Thanks in advance.
*MIP/SCTE*
+FTM GRIP+
socal23 is offline   Reply With Quote
Old 02-24-2014, 05:19 PM   #9967
gelshocker's Avatar
Originally Posted by nickdawg18 View Post
i bent the exotek front brace on the first race. got tangled with another car. Wonder if a plastic piece would stay true better then aluminum. or even carbon fiber
I am hoping the JC brace would be stronger as it extends taller? (where they stamped their logo).
We need a carbon fiber brace already, hammering and then eyeballing it is getting tired
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 02-24-2014, 09:29 PM   #9968
You want the new kyosho pivots. Umw705 and umw707 they are narrower than the exotek narrow and wider than the exotek wide. Depending on what pills you use. Yes narrow with narrow and wide with wide.
CaseyD I have no idea why springs are $20 when others are $8
AlwaysLOSI is offline   Reply With Quote
Old 02-24-2014, 09:49 PM   #9969
An alloy bulkhead from ghea or yaiba would also help. The rack will never bend if u have one
glenng is offline   Reply With Quote
Old 02-25-2014, 12:05 AM   #9970
gelshocker's Avatar
Sure but then I'll be breaking arms and bending hinge pins or even shock shafts. Just release a stronger brace. I'll give the JC a shot. Cheers,
Kyosho RT5 | RB6
Old 02-25-2014, 12:58 AM   #9971
Lonestar's Avatar
Same reason why a Breitling is $5000 while a Hamilton with the same 7750 movement $500... because peeps are willing to pay this price
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 02-25-2014, 01:53 AM   #9972
gelshocker's Avatar
Not all ETAs are finished the same. Have you looked inside an IWC?
Breitlings are rubbish I'll give you that. Cheers,
Kyosho RT5 | RB6
Old 02-25-2014, 03:04 PM   #9973
Hi guys I'm wanting some advice I have tried running the buggy class with a b4.1 worlds car and just can't seem to get it to hanle the way I like it. I have always raced a sc10 and like the way I am able to push it. So I guess what I'm asking is is the rb6 worth the money I have watched others run them and they always look so smooth. On the first page of this thread it says they may be hard for beginners to drive why is this?
Jspires688 is offline   Reply With Quote
Old 02-25-2014, 03:13 PM   #9974
VenturaDC's Avatar
Trader Rating: 32 (100%+)
Rear motor I found it quite easy to drive and push it hard, mid motor requires a bit more finesse but my lap times show its a good bit faster, at least running indoors. Big outdoor tracks I still prefer RM.
In my personal opinion it really was worth the money
Dustin Colt45 Aguirre
Kyosho RB6--Futaba--HW--Shuurspeed 17.5
Kyosho SCR--Hitec--Lrp--Yeah 13.5
Durango Dex210--Futaba--Trakpower--Tacon 8.5
VenturaDC is offline   Reply With Quote
Old 02-25-2014, 03:24 PM   #9975
Thanks for the reply
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22957 Yesterday 12:16 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
