    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 02-20-2014, 08:46 AM   #9916
whitrzac's Avatar
Trader Rating: 94 (100%+)
7mm driver for wheel nuts
whitrzac is offline   Reply With Quote
Old 02-20-2014, 10:03 AM   #9917
mog ruith's Avatar
Need some help here to clear my doubts. Spoke to a dude just now driving a rb5 and asked him weather the arms, cvd and ball diffs would fit into my rtr rb6 and was told no, it can't and won't fit. Now, how true is that? I read that somewhere that it does...
Another issue, my 6 likes to slide after coming out of a bend. Doesn't like to be planted to the ground. Another issue, after taking jumps it's always chasis slapping to the ground. Now do i change to a slightly heavier wt shock oil to overcome this?
mog ruith is offline   Reply With Quote
Old 02-20-2014, 10:18 AM   #9918
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Originally Posted by mog ruith View Post
Need some help here to clear my doubts. Spoke to a dude just now driving a rb5 and asked him weather the arms, cvd and ball diffs would fit into my rtr rb5 and was told no, it can't and won't fit. Now, how true is that? I read that somewhere that it does...
Front arms from rb5 are no go, everythings different. Rears and diff and cvd will work.
RM or MM, for RM most try with the japanese setup on kyoshos site. Most run the 1.3x4 pistons for more pack. Not sure about the slide, maybe posting your setup/track here would help.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 02-20-2014, 12:17 PM   #9919
Trader Rating: 23 (100%+)
Wow, my buggy weighs a wopping 1630 grams. This is with body on ready to race. This is with a shorty pack in mid motor config. How much are you guys weighing in at?
chevmaro is offline   Reply With Quote
Old 02-20-2014, 01:03 PM   #9920
whitrzac's Avatar
You can run the RB5 front arms with the correct bulkhead. There is 3 different lengths of arms/bulkheads.
RB5 is A
RB6 is B
RB5 WC is C
The front casters/hubs are diffrent, but fit on the RB5 arms.
Old 02-20-2014, 01:23 PM   #9921
aloksatoor's Avatar
RB5 is A
RB6 is B
RB5 WC is C
No the shocks mount in front of the tower in the 5 and the holes line up on the arms that way. In the 6 its behind the towers, so even if it works the geometry will be off. Probably have to flip the arms as well.
Old 02-20-2014, 01:39 PM   #9922
whitrzac's Avatar
I run the 5 front arms and bulkhead on my 6. No issues.
I have a friend that's using the 6 arms/bulkhead on a 5. No issues.
Look at the bulkhead lettering
Old 02-20-2014, 02:06 PM   #9923
aloksatoor's Avatar
Do you use the 5 towers as well? Can you post a pic. Might be good because you can increase front droop with the lower tower.
Old 02-20-2014, 03:20 PM   #9924
whitrzac's Avatar
Old 02-20-2014, 04:24 PM   #9925
mog ruith's Avatar
Front arms from rb5 are no go, everythings different. Rears and diff and cvd will work. RM or MM, for RM most try with the japanese setup on kyoshos site. Most run the 1.3x4 pistons for more pack. Not sure about the slide, maybe posting your setup/track here would help.
Thanks bro, appreciate the help. That's a relief. Now I'm debating either to get me the mip pucks or get me a used rb5. If I get the rb5 it comes with those kyosho shocks but the plain vanilla rb5 kit doesn't comes with those big bore shock if I'm not wrong.
Another thing, what are the advantage of running the Rb5 arms?
Old 02-20-2014, 04:37 PM   #9926
aloksatoor's Avatar
Thanks nice to know they work in a pinch! . @Mog I have the pucks system on mine, does feel a bit faster for stock but those darned #1 pucks are always out of stock and they do wear fast on high bite! My backorders are coming in next week from amain.
Old 02-20-2014, 04:49 PM   #9927
mog ruith's Avatar
Since you are running the mip, u think you're back to the kit cvd any time? Or once you have a puck in there you don't want to go back.
Old 02-20-2014, 04:54 PM   #9928
aloksatoor's Avatar
For stock 17.5 never going back to stocker parts. For mod, the stock diff outdrives/pins specially wore too fast. So I was running the mIP super diff prior to the pucks release!
Old 02-20-2014, 05:24 PM   #9929
gelshocker's Avatar
Originally Posted by Speedychris22 View Post
that and a 5.5 nut driver. That little cross nut tool that they give u. Save that
Ditto, you need the cross tool to get into the front shock nylon nuts.
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 02-20-2014, 06:32 PM   #9930
Teufel Racing's Avatar
Trader Rating: 26 (100%+)
Just weighed mine out last night for the cactus,
Came in at 1592
All Ti screws (except front and rear arm mounts on the chassis, servo screws, and Battery post screws), Ti camber links, and 14g of rear weight added
Running gear,
X2 Scrubs/Suburbs with stock foams
Stock Kyosho wheels
Orion ESC (not as light as a Tekin would be)
Savox 1257
Shotry pack (Protek 4300)
Upgrade wrapped RB6 body (adds some weight for sure)
Upgrade rear wing
Stock slipper w/Losi 70t spur and pads and alum pinion
All elec. componets are mounted up front in front of the shorty pack.
With out the extra 14g rear weight, I'd be at
1588
with a set of AKA Typo's/Evo wheels, I'd be at
1548
With the new light weight chassis, I'd be at
1523
With a lighter shorty pack and all of the above, I'd be under weight in MM
With a lighter Shorty (something around 150g) and the stock chassis and X2 tires, I'd be at (ish)
1538-15442 (depending on if the rear weight (14g) was kept)
add in the LW chassis and it's
1513-1517
There's room for better weight loss in my setup if my body wasn't wrapped, switched out the ESC wires to 13ga, and ran an Avid slipper set up. But I usually run mod, so I don't really worry about the weight too much. Stock class, and I'd be more on top of it. LOL
J.Mikoliczyk
ZX6 - RB6 - MP9e
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
