    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 02-16-2014, 04:27 AM   #9856
nickdawg18's Avatar
Trader Rating: 33 (100%+)
Originally Posted by wisconsinbasher View Post
decided to just go ahead and finish it up heres how my buggy turned out
started out by dremling out the side rails to fit the battery
it was kind of a tight fit for the motor wires a couple of zip ties cleaned it up
a few questions, how do you plan to keep the battery in place? and what rear axle's are those?
:::edit:::
nevermind, i see that its the mip puck system.
Nick Carroll
Mugen Mbx7-reds r5t team edition 2 [] Mugen Mbx7 Eco-Tekin rx8 gen 2 1900kv [] Losi 8ight T 2.0-fusion x7 [] Losi 8ight T E 2.0-Tekin 2000kv [] Kyosho RB6-Tekin RS gen 2 8.5t [] Losi 22sct
VP Pro USA [] Up-Grade RC
nickdawg18 is offline   Reply With Quote
Old 02-16-2014, 05:03 AM   #9857
stiltskin's Avatar
Trader Rating: 102 (100%+)
Originally Posted by Kuya_Kimo View Post
Speaking of wheel hex offsets (sorta surprised the front offset was closer than I thought)...
How far is the offset front and rear for the AKA Evo wheels compared to the Kyosho wheels?
I ran the typos yesterday for the first time. The front end is noticeably narrower. Probably 3 mm on each side with the wide front end. The rear appears to be pretty close visually. I didn't measure them. The tires worked very well for me. They seem to roll deeper without the feeling that you've stretched the tire to its limit and are now sitting on the bead. The traction was very consistent with gobs of forward bite and "smooth" side bite. Again, the tires never felt like they were trying to square up and get squirmy. I ran my fastest lap, my fastest qualifier, TQed and won the A with them. Definitely worth a try. We run on indoor clay with medium-high traction. My usual tire combination is suburb front/ rear or suburb front / sweep rear. The TYPOS were more consistent and better balanced.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 02-16-2014, 07:50 AM   #9858
wisconsinbasher's Avatar
Trader Rating: 29 (100%+)
:::edit:::
As far as the battery goes I have Velcro on the bottom and the esc shelf keeps it from popping up.
wisconsinbasher is offline   Reply With Quote
Old 02-16-2014, 11:27 AM   #9859
Kyosho Rudebits DB2
Kyosho Ultima RB6 & RB6.6 Car Thread-rsz_db2_028.jpg   Kyosho Ultima RB6 & RB6.6 Car Thread-rsz_db2_027.jpg   Kyosho Ultima RB6 & RB6.6 Car Thread-rsz_db2_023.jpg   Kyosho Ultima RB6 & RB6.6 Car Thread-rsz_1db2_021.jpg
delanobe is offline   Reply With Quote
Old 02-16-2014, 11:46 AM   #9860
Trader Rating: 310 (100%+)
Originally Posted by delanobe View Post
Kyosho Rudebits DB2
nice , show some video of it running
Jermaine Mitchell
I laugh at serious racers acting like B****
Free Agent racing team. No sponsors needed.
Mercenary Racer
jmoneym is offline   Reply With Quote
Old 02-16-2014, 07:12 PM   #9861
purple haze's Avatar
I am coming from 1/8 buggy to my first 2wd 1/10 buggy and have a few questions . does anyone have a good starting setup for rear motor , for an outdoor , bumpy hard pack 1/8 track ? would you recommend the wide , aluminum rear suspension hangers ? thanks .
www.karz.ca
www.carcar.ca
www.rcgears.net
purple haze is offline   Reply With Quote
Old 02-16-2014, 07:19 PM   #9862
Mxer59's Avatar
Trader Rating: 114 (100%+)
Had a good day at track today, besides my brand new Orion VST2 end ball blew apart then motor start clicking real bad. It's pretty much stock rm but I'm curious how to get more on power steering out of it
5ive T (Bartoline 28.5cc, Bartoline Pipe, Team Chase)
Futaba 4pls
Team Chase 2015
Rd. 2 TQ-1st--Rd. 3 3rd
Mxer59 is offline   Reply With Quote
Old 02-16-2014, 07:31 PM   #9863
Razathorn's Avatar
Absolutely not. I assume that the 1/8 scale track will be dramatically lower traction than an indoor track, so you do NOT want to widen the rear end up as that will remove a lot of traction.
Assuming the track is as I suspect it will be, I would stick with the gull wing arms, put this setup on:
http://www.petitrc.com/setup/kyosho/...CRC2013011213/
Then add 1mm of shock down travel and ride height and go from there. Don't forget to use the M shock eyelets when running the gull arms and short eyelets when running the flat arms.
You may consider going to the 5 hole pistons to address the bumps, but they will have far less pack incase you have big jumps.
AE B6D / AE B44.3 / AE RC10WC / AE RC8B3
Razathorn is offline   Reply With Quote
Old 02-16-2014, 07:39 PM   #9864
VenturaDC's Avatar
Trader Rating: 32 (100%+)
Running stick, shorty or saddles?
When i was running rm I started with stick and the car was good but needed more steering, switched to shorty moved all the way forward then placed the esc further forward and the car was dialed.
Dustin Colt45 Aguirre
Kyosho RB6--Futaba--HW--Shuurspeed 17.5
Kyosho SCR--Hitec--Lrp--Yeah 13.5
Durango Dex210--Futaba--Trakpower--Tacon 8.5
VenturaDC is offline   Reply With Quote
Old 02-16-2014, 08:58 PM   #9865
Mxer59's Avatar
Running shorty more towards back, and Esc in back
Futaba 4pls
Team Chase 2015
Old 02-16-2014, 09:00 PM   #9866
thanks !
www.karz.ca
www.carcar.ca
www.rcgears.net
Old 02-16-2014, 09:43 PM   #9867
Jcozz's Avatar
Trader Rating: 20 (95%+)
Your gonna want more then that and unless your running oval
Jared Cozzocrea
HobbyPro PRS1 / HobbyPro SB401 / Fusion Graphics / Mayor RC
Premier RC Raceway and Hobbies
Dave's RC Tracks
Jcozz is offline   Reply With Quote
Old 02-16-2014, 10:13 PM   #9868
Default help me understand Anti squat
Ok Im kind of lost here on the mid motor setups.
what is anti squat? how does it affect the car?
if i run 0 under the rear pivot what do I run on top of the rear pivot?
kit is .5 and .5 what happens when you change these shims?
tebo ocrc reedy race is .5 under pivot but does say what is above the pivot?
I'm lost here please help
AlwaysLOSI is offline   Reply With Quote
Old 02-16-2014, 11:07 PM   #9869
Move the battery forward one hole at a time until you get the steering you want. Battery holders have two holes for in-between adjustments
Old 02-16-2014, 11:08 PM   #9870
You must make sure that the total of the shims equals 1...kit is 0.5 plus 0.5 so if you decide to run no shim under the rear you have to add 1mm shim on top or otherwise your roll center will change.
nitroargi is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22957 09-22-2017 12:16 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
