    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 02-14-2014, 07:23 AM   #9826
Jcozz's Avatar
Trader Rating: 20 (95%+)
I had the problem of my nylon nut on my c4.2 back off so I've just been locking down all my slippers on my stock 2wd's. Am I loosing on power traction from this?
Jared Cozzocrea
HobbyPro PRS1 / HobbyPro SB401 / Fusion Graphics / Mayor RC
Premier RC Raceway and Hobbies
Dave's RC Tracks
Jcozz is offline   Reply With Quote
Old 02-14-2014, 07:33 AM   #9827
Trader Rating: 23 (100%+)
I don't lock the slipper in my stock buggy. It takes two seconds trackside to tune the slipper. Play with it, run a couple laps and adjust.
chevmaro is offline   Reply With Quote
Old 02-14-2014, 07:51 AM   #9828
Razathorn's Avatar
I just do the thing where I hold my rear wheels down and roll onto full throttle to ensure I can do wheelies on the bench and my diff doesn't bark. That's what most of the pros do--just gauge how aggressive / long it takes for the front to come up when doing that and that's your adjustment range.
You can't even get the car to do that without something south of a 10.5 though. In stock, I always just cranked the slipper down locked, then backed it off so it would at least start to slip on the bench, and that was it.
AE B6D / AE B44.3 / AE RC10WC / AE RC8B3
Razathorn is offline   Reply With Quote
Old 02-14-2014, 08:57 AM   #9829
CanyonCarverR1's Avatar
Raz, can you explain what mod you did to the motor guard? Thanks
CanyonCarverR1 is offline   Reply With Quote
Old 02-14-2014, 09:21 AM   #9830
Razathorn's Avatar
Originally Posted by CanyonCarverR1 View Post
Tax, can you explain what mod you did to the motor guard? Thanks
Direct copy from Jared's car:
I must stress that our track is NOT high traction. Jared ran this setup and told me he liked it at cactus, but on higher bite tracks, such as when he went to chico, the car felt too heavy and he went to a shorty with the ESC behind the battery. He said that out of all the layouts, he liked the shorty with the ESC behind it the best.
Old 02-14-2014, 09:24 AM   #9831
Trader Rating: 91 (100%+)
I think he meant that he ground the nubs for the speedo shelf off of the mm motor guard, the purpose is to move the battery back more.
And for what its worth while adjusting the slipper I can wheelie with a 17.5 when the pack is fully charged.
Edit- beat me to it while typing, lol
Just leave him alone, he knows what he's doing!
Eric Tomczyk is offline   Reply With Quote
Old 02-14-2014, 10:04 AM   #9832
cnelson3's Avatar
Trader Rating: 65 (100%+)
Saddle packs? Plastic hubs?
cnelson3 is offline   Reply With Quote
Old 02-14-2014, 04:30 PM   #9833
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Originally Posted by Lonestar View Post
I knew someone was going to say this the center diff in 4wd (mostly 8th scale OR indeed) does mostly one thing, it "wastes" power to the front wheels on-power, and it "soaks" the ruts by allowing the all 4 wheels to rotate at completely different speeds (with only 2 diffs L rpm + R rpm = cst).
Net - although not completely similar, 8th scale center diff fills in a lot of similar duties to those of the 10th slipper... so your comparison is a very good one, although we're comparing 2wd with 4wd. 4wd stock without slipper, yes, I can imagine it. 2wd, no way
Paul
PS: the D413 is (will be) a 3 diff car too. No slipper. but 4wd
Yep your right on the power dump on fronts wheels. Always my front tires are way more worn than rears on the ebuggy (wear goes down with 10K plus oil in center but cars too twitchy). I however find the ball diffs last the same time with/without slipper for 2wd stock buggy so will run slipperless for now at least .
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 02-14-2014, 05:21 PM   #9834
gelshocker's Avatar
Originally Posted by gelshocker View Post
Hey guys, first time I glued up some AKA Hexlites.
Same tire, insert cut down the same width, and the tire comes out smaller both overall wheel diameter and wheel track width. And this it before attaching to the front axle (which turns out even narrower track).
Is this expected? Thanks,
Anyone please? Thanks,
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 02-14-2014, 07:40 PM   #9835
Quick question, is it roar legal to run a shorty pack sideways infront of the motor on a mid motor set up? It's not like I run any roar races but the JBRL is supposed to be following roar a little more closely this year so I want to make sure I'm following the rules.
CaseyD is offline   Reply With Quote
Old 02-14-2014, 08:23 PM   #9836
Cameron Kellogg's Avatar
Trader Rating: 45 (100%+)
Right now the rules state the you must have the car set up so you can remove a shorty pack and place a saddle or full pack in its place with no other changes besides foam spacers. BUT I see that rule changing with the new HB 4w and team c buggies coming out that are shorty pack specific.
Cameron Kellogg is offline   Reply With Quote
Old 02-14-2014, 08:39 PM   #9837
Not argueing just trying to get a good understanding, but even the RB6 you have to move the battery holders around to switch between a shorty and sattle packs correct?
Old 02-14-2014, 08:48 PM   #9838
Not mine but some yes. It's a old rule that I am sure will be changed soon.
Old 02-14-2014, 08:51 PM   #9839
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
I am having a hard time trying to visualize what you are saying. Any chance you can take a picture?
From what I understand the chassis needs to be able to accept a saddle pack. Hopefully, we will get clarification on the rule but I just don't know when. Maybe if IFMAR changed their rule first ROAR would follow suit.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 02-14-2014, 08:57 PM   #9840
Well it says all the chassis has to do is "accept" either of the two not where they can be right.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22937 Today 06:57 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
