    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 02-11-2014, 07:32 PM   #9781
gelshocker's Avatar
Originally Posted by mog ruith View Post
Are there any alternative shocks I can replace? My plastic shocks top cap came loose. First was the rear then the front. Kyosho big bores are damn expensive...
RB5 plastic or RB6 alum shock cap should not come loose. I would check the o-ring seating and maybe apply a little green slime.
If you're using Kyosho RTRs throw them out.
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 02-11-2014, 08:28 PM   #9782
mog ruith's Avatar
You guys are mean, be gentle I'm a noob. Lol. Yes I'm using the rtr shocks, not sure if the all metal caps would fit. Any idea guys?
mog ruith is offline   Reply With Quote
Old 02-11-2014, 08:31 PM   #9783
mog ruith's Avatar
And another thing is do I really have to go with kyosho? Other shock makes aren't good enough for the Rb?
Old 02-11-2014, 09:13 PM   #9784
E73
E73's Avatar
Soliciting opinions for stock 17.5 spur gear setup:
1) Use the slipper clutch
Pros: extended gearbox life, better traction, smoother feel
Cons: less responsive, car feels "slower"
2) Lock the slipper down/spur gear hub
Pros: less rotating mass (hub), responsive throttle
Cons: stresses gearbox components, abrupt throttle input
I've locked mine down for the last year but a local pro suggested I let the slipper do it's job (actually set it to slip). Buggy feels smoother but not quite as fast...probably due to the decreased throttle response. How do you have yours set up?
E73 is offline   Reply With Quote
Old 02-11-2014, 09:24 PM   #9785
VenturaDC's Avatar
Trader Rating: 32 (100%+)
It tells you something when I see quite a few other brands of buggies running kyosho shocks, make the investment its worth it, plus you can take them with you if you change buggies later. You can usually find a used set here and there
Dustin Colt45 Aguirre
Kyosho RB6--Futaba--HW--Shuurspeed 17.5
Kyosho SCR--Hitec--Lrp--Yeah 13.5
Durango Dex210--Futaba--Trakpower--Tacon 8.5
VenturaDC is offline   Reply With Quote
Old 02-12-2014, 12:05 AM   #9786
gelshocker's Avatar
Didn't meant to sound mean I have the ZX-5 RTR and throwing out the shocks was the best thing I did to it.
The RTR plastic shock bodies may be and subject to damage/deformation too.
Cheers,
Kyosho RT5 | RB6
Old 02-12-2014, 09:06 AM   #9787
carbons2k's Avatar
Trader Rating: 21 (92%+)
What does flipping the steering ackerman around and running it backwards do?
Tom Licata
*JConcepts*Devil Spit*
carbons2k is offline   Reply With Quote
Old 02-12-2014, 11:19 AM   #9788
Mxer59's Avatar
Trader Rating: 114 (100%+)
Tebo says it makes the steering less twitchy and takes some of the mid corner push out is what I read
5ive T (Bartoline 28.5cc, Bartoline Pipe, Team Chase)
Futaba 4pls
Team Chase 2015
Rd. 2 TQ-1st--Rd. 3 3rd
Mxer59 is offline   Reply With Quote
Old 02-12-2014, 02:27 PM   #9789
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
I see Kyosho has or will be releasing a 69 tooth 48 pitch spur gear, UM730-69. No idea if it will be imported here into the U.S.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 02-12-2014, 03:26 PM   #9790
Trader Rating: 91 (100%+)
Mog ruith- By far the best way to upgrade an RTR RB6 is to find a clean RB5 WC for cheap and use the shocks, diff and other trinkets. You'll also be stocked with spare hinge pins and hardware.
Just leave him alone, he knows what he's doing!
Eric Tomczyk is offline   Reply With Quote
Old 02-12-2014, 05:39 PM   #9791
mog ruith's Avatar
Eric I was thinking of doing that too. Guys if I want to change to mid motor configuration and still use a full size stick Lipo do I need to use a low profile servo or will the standard size servo be fine?
Old 02-12-2014, 05:52 PM   #9792
VenturaDC's Avatar
It fits with a full size servo but leaves zero room for the esc, if the esc your using is low profile it'll fit on the shelf, if not there isn't to many options
Old 02-12-2014, 08:03 PM   #9793
Jochim_18's Avatar
I start running Full size pack on my Mid motor... I cut a carbon Fiber to make a plate so the ESC sits on top..
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 02-12-2014, 10:16 PM   #9794
Alright guys tell me what I'm getting into, just bought an RB6, I've only driven AE cars. Is the steering as fast? What about traction? I know the shock package is out of this world. I was really excited about the B5 but the two chassis thing really turned me off so I decided to make the switch. Really excited to get some wheel time with my Kyosho.
CaseyD is offline   Reply With Quote
Old 02-13-2014, 03:46 AM   #9795
Yes, it will be imported.
Jason Dias
http://www.facebook.com/jasondiasrc
Team Kyosho - AKA - KO PROPO - Hobbywing - Schuur Speed - Schelle Racing - OCRC Raceway - Tuning Haus
Jason.Dias is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22981 Yesterday 04:29 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15026 11-02-2017 04:19 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
