Kyosho Ultima RB6 & RB6.6 Car Thread
#9766
My local track just moved to a new location and the new track has a ton of grip. So I was thinking of switching over to mid motor. I know this has been discussed before, but whats a good starting point for a mid motor setup on a smaller/med indoor clay track. I checked the front page but all I got was rear motor setup. Any help would be great. I attached a link to the track on youtube.
http://www.youtube.com/watch?v=02FGtuAMD6g
#9767
Interesting. Was it just the behind the backplate part that fit? Or u even got a snug fit on front shaft part? If its the backplate part, maybe i need to try again and squeeze it on harder. I dont like putting too much pressure on the shaft out of fear of bending it. Also, did u have to remove the kyosho brass spacer? And if so did u shim the gap? And was the behind backplate fitment really snug/tight requiring force? Thanks Mike!
#9769
#9773
#9774
#9775
I have found a setup that's really good for me with the 521 arms but I have been wanting to try the gull wing arms so I ripped into it last night to make some changes. I'm going with the gull wing arms d inside in the front, c inside in the rear, 4x1.3 pistons,15g on the bulk head to get to min weight and some other little things. I will report back with how the arms compare to each other.
#9777
Let's see how your wired up! I'm running my rb6 mid motor with lrp SXX speedo, reedy 17.5 Mach 2, spektrum s6040 servo, and futaba r2104gf. I want the option of running saddles and shorties. Let's see what you got!
