    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 02-07-2014, 06:39 PM   #9736
BSC
BSC's Avatar
Trader Rating: 51 (100%+)
What is the gearing to run stock 17.5?
Kyosho
Team Associated
Hobbywing /SMC/LFR/AKA
www.coast2coastrc.com.au
Logan Offroad - The Brickyard
BSC is offline   Reply With Quote
Old 02-07-2014, 07:51 PM   #9737
MikeXray's Avatar
Trader Rating: 73 (100%+)
[quote=glenng;12986379]
Originally Posted by MikeXray View Post
Mine fit on fine, it sticks out too far so the gear cover doesn't fit, I practiced with it anyway, worked fine. I am going to file down the back part so it sits closer to the back plate like it should, this will also give more threads on the lock nut.[/QUOTE
Interesting. Was it just the behind the backplate part that fit? Or u even got a snug fit on front shaft part? If its the backplate part, maybe i need to try again and squeeze it on harder. I dont like putting too much pressure on the shaft out of fear of bending it. Also, did u have to remove the kyosho brass spacer? And if so did u shim the gap? And was the behind backplate fitment really snug/tight requiring force? Thanks Mike!
I tightened it good, I did leave the brass shim in, as the elim doesn't fit to replace it.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 02-07-2014, 08:00 PM   #9738
32/69
zzztech is offline   Reply With Quote
Old 02-07-2014, 09:50 PM   #9739
Jcozz's Avatar
Trader Rating: 20 (95%+)
Is it possible to get a jcon finisher c4.2 body on a rb6 mid motor? I just got a fresh lid for my c4 and then decided to get a rb6. Hoping it will fit.
Jared Cozzocrea
HobbyPro PRS1 / HobbyPro SB401 / Fusion Graphics / Mayor RC
Premier RC Raceway and Hobbies
Dave's RC Tracks
Jcozz is offline   Reply With Quote
Old 02-07-2014, 11:15 PM   #9740
1967rs's Avatar
Trader Rating: 55 (100%+)
At a glance I would say it is likely. I know a rb6 body will fit a b5r (I tried it) and a lot of people are using centro bodies on the b5r.
Thank you, Pemberton Raceworks, Team Tekin, Team Trinity and Sweep Racing USA for your outstanding support to the Military.
www.facebook.com/DoakWorksDesign
[email protected]
1967rs is offline   Reply With Quote
Old 02-08-2014, 09:37 AM   #9741
Jcozz's Avatar
Man I sure hope so!
Jared Cozzocrea
Dave's RC Tracks
Old 02-08-2014, 02:57 PM   #9742
lore's Avatar
Send a message via MSN to lore Send a message via Skype™ to lore
Originally Posted by VenturaDC View Post
I had the same issue on my rb5, nothing I did helped, tried shims everywhere. Eventually I filed the stock hexes hole out just enough to fit over the avid axle and that worked, its like the pin recess on the avid hex was too deep and the axle was as far out as it could go.
Thanks for the feedback. I will probably put back the stock axel then.
Easier.
Ciao,
RB6 / RT6 / ZX6 / SC6
AE12 R5.1 / F104 Exotek / Tamiya Mini 500 Abarth
Orion R10 Pro all the way
lore is offline   Reply With Quote
Old 02-08-2014, 08:32 PM   #9743
Razathorn's Avatar
Hey guys, I was seriously having some traction issues with my mid motor rb6 with our recent track rebuild. It wasn't horrible, but it wasn't good. I didn't want to go to a lighter spring in the rear (running golds) so I opted to go with 1mm more front droop. This got me the on power traction I was missing, and a significant amount of low speed steering as well. Since I am running the 5 hole pistons in the front, I went up in oil to 37.5 from 35 to calm the front down on corner entry. I then lowered the rear roll center (no washers on the hubs) for a bit more off power traction in slow sections.
Been really happy with these changes. Definitely a good move for our slow low speed and slippery layout that would probably deal better with a rear motor car.
Wayne
AE B6D / AE B44.3 / AE RC10WC / AE RC8B3
Razathorn is offline   Reply With Quote
Old 02-09-2014, 02:14 PM   #9744
Jcozz's Avatar
Can somebody measure the wing mounts for me? Center to center? Thanks in advance!
Jared Cozzocrea
Dave's RC Tracks
Old 02-09-2014, 03:56 PM   #9745
Mxer59's Avatar
Trader Rating: 114 (100%+)
What are most of you guys preferring with 17.5 mm or rm
5ive T (Bartoline 28.5cc, Bartoline Pipe, Team Chase)
Futaba 4pls
Team Chase 2015
Rd. 2 TQ-1st--Rd. 3 3rd
Mxer59 is offline   Reply With Quote
Old 02-09-2014, 05:43 PM   #9746
teeforb's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to teeforb
Originally Posted by aloksatoor View Post
My stock rb6 is at 1415 grams right now, had to put a full pack to get upto minimum weight. Except the carbon parts all lightweight parts and titanium on her. Pucks do make a lot of difference and eliminating the slipper.
Want all did u do to get it to 1415?
$$ Team High Budget $$
17.5 stock buggy fb page
https://www.facebook.com/groups/17.5stockbuggy/
teeforb is offline   Reply With Quote
Old 02-09-2014, 05:58 PM   #9747
Moderator
Posvar's Avatar
Trader Rating: 462 (100%+)
I think he said what he did to it in his post but wasn't 100% clear....
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Old 02-09-2014, 06:28 PM   #9748
teeforb's Avatar
I'm still not clear on how to replace the slipper.
Also, does anyone know how much weight in grams the puck system eliminates?
Old 02-09-2014, 07:04 PM   #9749
gelshocker's Avatar
Easier.
Ciao,
If you're breaking axles maybe these might work?
http://www.fastlanemachine.net/products.php?cat=Kyosho
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 02-09-2014, 09:06 PM   #9750
VenturaDC's Avatar
Trader Rating: 32 (100%+)
Personally I think it depends more on track type, layout and driving style more then anything else. See how the fast guys at your track are running it. If you have a heavy trigger finger and enter the corners very aggressively then Rm will be more forgiving, if your a smooth fluid driver then I think MM will be advantageous to use.
Dustin Colt45 Aguirre
Kyosho RB6--Futaba--HW--Shuurspeed 17.5
Kyosho SCR--Hitec--Lrp--Yeah 13.5
Durango Dex210--Futaba--Trakpower--Tacon 8.5
VenturaDC is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22957 09-22-2017 12:16 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
