    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 10-03-2012, 09:17 AM   #961
CanyonCarverR1's Avatar
Default Starting setup
I'm getting ready to start building and am looking for a little advice. I see a few setups around, but they are all for mod. Starting with Tebo's Nats setup(which is for outdoor mod), what changes would you guys make for a starting setup for running 17.5 on a medium sized indoor clay track. I know this is speculation, but I don't really have much experience in 2WD buggy.
CanyonCarverR1 is offline   Reply With Quote
Old 10-03-2012, 09:21 AM   #962
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by fredswain View Post
Now this I find funny. You were an early critic of my balance tuning method going so far as to ask why I thought my method was possibly better than using the setups that the pros developed and here you are using it after all.
If anyone wants to know how to do it, look at the "Tuning with Camber Links" thread. It's not some top secret tuning method.
No, I wasn't.. and nobody said it was top secret, and I have been doing it for YEARS. Actually, I think I first read of the technique in RC car action magazine a decade ago or more ago... What I criticized you on, was your backwards theory on roll center's affect on weight transfer (which you are obviously still butt hurt about), and how far you need to go to corner balance a car (which you agreed with me on). Why don't you go troll somewhere else...damn troll. Next time send a PM if you have an issue with me, don't troll our thread.
Now.. back to discussion on the RB6.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 10-03-2012, 09:33 AM   #963
Moderator
Posvar's Avatar
Trader Rating: 462 (100%+)
I have looked for an outdoor mod base set up......is petit RC the best source.
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Old 10-03-2012, 09:39 AM   #964
Trader Rating: 138 (100%+)
Originally Posted by joecool View Post
Went all out to build the best kit possible. I'll post a pic when it's all done.
How do you like the new KO Radio as opposed to the Eurus?
TLR 22T 3.0, 2X Yokomo YZ-2 DTM, YZ-4 SF (please hurry), Mugen MBX7R Eco, Hobbywing, Futaba, LRH Hobbies, Amain Hobbies, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 10-03-2012, 09:48 AM   #965
For those running stock blinky mode, does the weight of the car worry you?
At 1620g this is the 2nd heaviest buggy in the big four-
Dex210- 1650g
RB6- 1620g
B4.1-1535g
22- 1500g
Having driven the car at wcrc I did feel the weight of the car, had a hard time clearing the triple. Whereas the b4.1 had a much easier time clearing it.
GuiltyByAssoc is offline   Reply With Quote
Old 10-03-2012, 09:48 AM   #966
Originally Posted by savageboy69 View Post
work on a wheel wiggle in the air, flattens your buggy right out, just a quick turn right and left, if you work on it pretty soon it becomes second nature and you just do it without thinking about it
Wont be whipping the RB6 anytime soon. Need to get used to it, so much smoother then the B4.1 was which could be whipped at will.... Mostly a show boating thing.
Old 10-03-2012, 10:01 AM   #967
t8rtot's Avatar
Trader Rating: 14 (94%+)
Dex210- 1650g
RB6- 1620g
B4.1-1535g
22- 1500g
I'd have to ask what electronics were in the car and if a shorty was used in the weighing of the 22..
Sfida
t8rtot is offline   Reply With Quote
Old 10-03-2012, 10:02 AM   #968
Super Moderator
The setup you will likely run between an outdoor track and an indoor clay track, will likely be pretty different.
I actually change less on my setup going back and forth from stock to mod buggy than most drivers, so I wouldn't worry about that too much. The only thing I normally recommend right off the bat, is running a little more rear wing when running mod, as you will be coming into the sweeper off the straight a bit hotter... But it kind of depends on the track. All the indoor tracks here are small enough where you are basically hitting and landing the jumps at the same pace. 90% of the time/speed difference between stock and mod, is done on the straight. (on my tracks).
- RCSpecialties -
Old 10-03-2012, 10:05 AM   #969
Send a message via Skype™ to hitman72
could you guys that have driven both the 22 and the b4.1worlds car please tell me what the main diff is and why i should buy this car over the other two thanks James
www.PMhobbycraft.ca
AKA Racing
hitman72 is offline   Reply With Quote
Old 10-03-2012, 10:06 AM   #970
Super Moderator
Dex210- 1650g
RB6- 1620g
B4.1-1535g
22- 1500g
What are the weights of the 4 rolling chassis?
- RCSpecialties -
Old 10-03-2012, 10:12 AM   #971
SoCalMitch's Avatar
Dex210- 1650g
RB6- 1620g
B4.1-1535g
22- 1500g
My RB6 came in at 1538g with a shorty pack and shorty servo.
SoCalMitch is offline   Reply With Quote
Old 10-03-2012, 10:13 AM   #972
Trader Rating: 22 (100%+)
my rb6 was 758g no electronics, body or tires
my 22 was 755g with the same configuration
noproblems209 is offline   Reply With Quote
Old 10-03-2012, 10:15 AM   #973
t8rtot's Avatar
I like it.
Thanks guys
Sfida
Old 10-03-2012, 10:18 AM   #974
Super Moderator
Doesn't get much closer than that, yeah?
- RCSpecialties -
Old 10-03-2012, 10:27 AM   #975
nope...
i'll weigh my rb6 with the electronics this evening
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22984 Today 10:14 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15026 11-02-2017 04:19 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
