    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 02-06-2014, 07:40 PM   #9721
RCBuddha's Avatar
Trader Rating: 35 (100%+)
Originally Posted by glenng View Post
Can you or someone please post pic of how to get exotek eliminator to work with avid topshaft. Because i have both pieces and cant get it to fit. The exotek shaft that sticks out with the oval cutout is far too wide and sloppy to sit stable on the avid. I may be missing something, so not sure. Many thanks
Glenn
I believe that as long as you tighten the nut so that the adapter is centered, it should be no issue. You could also try putting some small diameter fuel tubing to help center it. I did notice what your describing on a spare MIP AE top shaft that I have on hand.
I tried the Speedtech hub, and it requires a bit of filing.
RCBuddha is offline   Reply With Quote
Old 02-06-2014, 11:09 PM   #9722
Jcozz's Avatar
Trader Rating: 20 (95%+)
Picking up my rb6 tomorrow from
A buddy at the track. Any set up tips or things to try that I may really like? I'm coming from my c4.2. This is mid motor also. High bite indoor clay track running 17.5. Gonna try shorty and saddles. I like a planted and "sluggish" car.
Jared Cozzocrea
HobbyPro PRS1 / HobbyPro SB401 / Fusion Graphics / Mayor RC
Premier RC Raceway and Hobbies
Dave's RC Tracks
Jcozz is offline   Reply With Quote
Old 02-07-2014, 02:00 AM   #9723
lore's Avatar
Send a message via MSN to lore Send a message via Skype™ to lore
Originally Posted by gelshocker View Post
http://www.amainhobbies.com/product_...xle-Conversion
'In order to use the stock RB6 rear wheels, you will need drill them out to fit over the larger axle. Avid recommends a body reamer from the inside and it will do the job nicely. AVID HD Long Axles can only be used with AVID HD Rear Hex Adapters.'
Hi, I did ream them out from the inside, and the hex (Avid Adapter) sit nicely inside the rims. Problem is when i tightened the wheel nut i do believe that the Kyosho rims parts that hold the Avid hex touch the bearing.
ciao,
RB6 / RT6 / ZX6 / SC6
AE12 R5.1 / F104 Exotek / Tamiya Mini 500 Abarth
Orion R10 Pro all the way
lore is offline   Reply With Quote
Old 02-07-2014, 06:25 AM   #9724
VenturaDC's Avatar
Trader Rating: 32 (100%+)
ciao,
I had the same issue on my rb5, nothing I did helped, tried shims everywhere. Eventually I filed the stock hexes hole out just enough to fit over the avid axle and that worked, its like the pin recess on the avid hex was too deep and the axle was as far out as it could go.
Dustin Colt45 Aguirre
Kyosho RB6--Futaba--HW--Shuurspeed 17.5
Kyosho SCR--Hitec--Lrp--Yeah 13.5
Durango Dex210--Futaba--Trakpower--Tacon 8.5
VenturaDC is offline   Reply With Quote
Old 02-07-2014, 07:45 AM   #9725
MCSEDanny's Avatar
After running a used RB6 I got from the world famous Big Wave Dave I decided to order a new kit. The kit I got from Dave was far better than detailed however it came as roller with parts to convert between mid and rear motor I was missing stock pistons, small med and large shock bottoms aside from what was installed so it left me feeling like I wanted a lot of stock kit parts I wanted but did not have.
I have really enjoyed the buggy so I am going to buy a new one and have all the parts . I am looking to get it from here http://siteground235.com/~winners4/a...e43c5c&x=0&y=0 but was wanting to see if you guys know of a cheaper place? I have dealt with Lee before in buying my MP9 and at the time could not find another for the price.
Make sure you call him to get price on rear hubs, ti screws and other accessories as they are not posted on his site.
Not trying to make this sound like an ad just making sure I am getting the best deal as I make the best use of my tax return
Team Turtle Trax / Loganville RC Raceway
Mugen MBX6TR / Bonito
Kyosho MP9 TKI3 / Plus 4
Kyosho MP9 TKI3 / Electric / WTF
AE B44.3 / ORCA VXX / D4 7.5
MCSEDanny is offline   Reply With Quote
Old 02-07-2014, 07:55 AM   #9726
whitrzac's Avatar
Trader Rating: 95 (100%+)
Work blocks that site as spam/virus... Good luck...
whitrzac is offline   Reply With Quote
Old 02-07-2014, 08:00 AM   #9727
MCSEDanny's Avatar
They have it price at $400.
Old 02-07-2014, 08:34 AM   #9728
Csaari77's Avatar
Trader Rating: 34 (100%+)
Check Banzai Hobby. With EMS shipping their price is about $380.
Half-A$$ Racing - Problem solved, problem staying solved!
Awesomatix - Serpent - Tekin - Futaba - Cooper Motorsports.
Csaari77 is offline   Reply With Quote
Old 02-07-2014, 09:01 AM   #9729
1967rs's Avatar
Trader Rating: 55 (100%+)
will the LA272 rear arms work on this car?
Thank you, Pemberton Raceworks, Team Tekin, Team Trinity and Sweep Racing USA for your outstanding support to the Military.
www.facebook.com/DoakWorksDesign
[email protected]
1967rs is offline   Reply With Quote
Old 02-07-2014, 10:03 AM   #9730
Trader Rating: 91 (100%+)
Yes but only the rear. They are the same as the 521 arms, it is the two hole rear arm. If you need two hole rear arms and also have a ZX5 this is the way to buy them, because I only break front arms on my 4wd and rears on my 2wd. I have a pile of 521 front arms, anybody need them, lol?
Just leave him alone, he knows what he's doing!
Eric Tomczyk is offline   Reply With Quote
Old 02-07-2014, 10:09 AM   #9731
Teufel Racing's Avatar
Trader Rating: 28 (100%+)
Yes they will,
The shock mount hole(s) isn't like the 521-1, but close enough. I use those (272) on mine right now. Seems to be working. You'll need the outer hinge pin from the ZX5/RB5 or you can ream out the one side of the arm a little and use the RB6 outer pin. If you do that, you'll need to add a 2mm shim to both sides of the RB6 pin as the 272/521/521-1 arms are a little narrower than the RB6 arm.
J.Mikoliczyk
RB6 - MBX7R Eco
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is offline   Reply With Quote
Old 02-07-2014, 10:18 AM   #9732
Yea i was imagining exotek hub may be able to get pinned down nicely to the avid via the diameter in the back of the plate. I took off the kyosho brass spacer and thought i could push the hub up onto that thicker part of shaft (and then figure out how much to shim remainder of where brass spacer once was), however the hubs inside diameter in back of the plate was too small to get on the shaft and would require it to be bored out to 5mm (i think). And without getting it dead center would result in wobbly spur. So im gonna wait till march for the rb6 specific hub.
glenng is offline   Reply With Quote
Old 02-07-2014, 10:44 AM   #9733
MikeXray's Avatar
Trader Rating: 73 (100%+)
Mine fit on fine, it sticks out too far so the gear cover doesn't fit, I practiced with it anyway, worked fine. I am going to file down the back part so it sits closer to the back plate like it should, this will also give more threads on the lock nut.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 02-07-2014, 12:42 PM   #9734
mog ruith's Avatar
I had a few laps today and the stock plastic shocks are still holding up, and that's good. A question, i have a turnigy nanotech 5800 mah full size hard pack and its really tight fit in the battery tray. How do you guys fit the battery with the battery strap on? It just too damn tight and i can barely put in the clip to the post.
mog ruith is offline   Reply With Quote
Old 02-07-2014, 01:24 PM   #9735
[QUOTE=MikeXray;12985917]Mine fit on fine, it sticks out too far so the gear cover doesn't fit, I practiced with it anyway, worked fine. I am going to file down the back part so it sits closer to the back plate like it should, this will also give more threads on the lock nut.[/QUOTE
Interesting. Was it just the behind the backplate part that fit? Or u even got a snug fit on front shaft part? If its the backplate part, maybe i need to try again and squeeze it on harder. I dont like putting too much pressure on the shaft out of fear of bending it. Also, did u have to remove the kyosho brass spacer? And if so did u shim the gap? And was the behind backplate fitment really snug/tight requiring force? Thanks Mike!
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22957 09-22-2017 12:16 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
