    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 02-04-2014, 07:57 AM   #9691
1967rs's Avatar
Trader Rating: 55 (100%+)
Originally Posted by whitrzac View Post
The carbon parts are the same wight...
The carbon parts are not the same weight, front tower is 1-2 grams lighter, rear is 4-5 grams lighter(rear motor), arms are about 2 grams lighter each.
Thank you, Pemberton Raceworks, Team Tekin, Team Trinity and Sweep Racing USA for your outstanding support to the Military.
www.facebook.com/DoakWorksDesign
D-W-D@comcast.net
1967rs is offline   Reply With Quote
Old 02-04-2014, 08:14 AM   #9692
whitrzac's Avatar
Trader Rating: 94 (100%+)
Then you go and add alloy rear hubs, alloy toe blocks, alloy bellcranks, +misc alloy bling parts...
Best case, you save 1 sticky wight from the car....
whitrzac is offline   Reply With Quote
Old 02-04-2014, 08:30 AM   #9693
gelshocker's Avatar
Originally Posted by VenturaDC View Post
Not a KO radio but on my futaba I'm around 70-80 on the EPA and that gets me lock to lock without excessive servo pressure, I can see how running it that high would kill a servo.
If I can share with you guys on the one10 shaking servo: I changed in a spare one10 from my RB5, which hadn't experienced shaking. On the RB6 it would shake. I toned down the EPA to 95% and the shaking had gone.
This leads me to question, is the shaking possibly caused by the Kyosho alum steering cranks and arms? I don't recall shaking with the stock plastic arms at 100% EPA.
I'll also like to try a different KO model later too (RSx Response).
Thanks,
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 02-04-2014, 09:26 AM   #9694
1967rs's Avatar
Between carbon parts, ti screws and mip puck system I droped almost 50grams off the car. With the stock chassis I am right at 1500 grams. Shaving that weight made a big differance in how the car feels, for the better.
D-W-D@comcast.net
Old 02-04-2014, 10:31 AM   #9695
aloksatoor's Avatar
Trader Rating: 42 (100%+)
My stock rb6 is at 1415 grams right now, had to put a full pack to get upto minimum weight. Except the carbon parts all lightweight parts and titanium on her. Pucks do make a lot of difference and eliminating the slipper.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 02-04-2014, 10:33 AM   #9696
aloksatoor's Avatar
thanks I will order them for the summer season. Winter indoor I break too many stock plastic parts earlier in the mornings cos of the cold.
Old 02-04-2014, 11:18 AM   #9697
E73
E73's Avatar
How do you eliminate the slipper? I just lock mine down for 17.5 but taking it off would lower rotating mass. Pics if you have any.
E73 is offline   Reply With Quote
Old 02-04-2014, 11:25 AM   #9698
aloksatoor's Avatar
speedtech turbo hub I think, sold by Jeff at speedtech
Old 02-04-2014, 11:42 AM   #9699
1967rs's Avatar
Mine was also under weight, so I went with a full size servo and added a few other items to make weight.
I will look into the turbo hub, thanks for the tip.
D-W-D@comcast.net
Old 02-04-2014, 11:59 AM   #9700
MikeXray's Avatar
Trader Rating: 73 (100%+)
The avid setup is impressive, you have to buy the topshaft too, but mine weighed just under 10g for the whole slipper setup, vs 25g for the VTS I was using..
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 02-04-2014, 12:55 PM   #9701
Johnn27's Avatar
Trader Rating: 69 (100%+)
Questions??
I wonder if the custom works slipper eliminator would work???
Johnn27 is offline   Reply With Quote
Old 02-04-2014, 01:27 PM   #9702
Johnn27's Avatar
What spur are you using with that slipper eliminator
Old 02-04-2014, 01:44 PM   #9703
1967rs's Avatar
I have a custom works eliminator I will give it a try when I get the chance, the cw eliminator uses the b3/touring car style spur gear. I have them as small as 55 tooth for oval racing.
D-W-D@comcast.net
Old 02-04-2014, 02:43 PM   #9704
E73
E73's Avatar
I have an Avid Triad slipper with 69T spur that I simply tighten all the way down. Looking at a slipper eliminator but doesn't look like there are any "drop in" systems available for the RB6. Speedtech turbo hub says it's for the AE/Losi buggies. They're sold out on the site anyway.
Old 02-04-2014, 03:11 PM   #9705
aloksatoor's Avatar
Yep you need an avid top shaft for it to work. Custom works I got but its sloppy. Tower hobbies sells it. Both need the avid top shaft.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
JAE
