    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 01-29-2014, 10:43 AM   #9586
CanyonCarverR1's Avatar
Originally Posted by whitrzac View Post
Because it's black
I wish kyosho made the adjustable arm mounts in blue...
The new lite-weight chassis is pretty sweet!
CanyonCarverR1 is offline   Reply With Quote
Old 01-29-2014, 03:15 PM   #9587
mog ruith's Avatar
Originally Posted by VenturaDC View Post
Have fun with the shocks, kyosho is known for the best kit shocks and the worst ready set shocks, there gonna leak and blow the tops off, hopefully you can find a used set cause I think there about $160 for all 4 new
Yeah i hope so lol
The plastic big bore shocks look 1/2way decent. They go together like traxxas shocks...
Good thing is its still holding up...
I would pick up a cheap set of alloy caps for them.
Thanks for the advice i will keep that in mind, unless i can find a used velvet shocks
By the way i will give you guys an update on when this shocks will last.
I heard their kit shocks are the best out there, but will see how this ready set last
mog ruith is offline   Reply With Quote
Old 01-29-2014, 03:36 PM   #9588
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
Originally Posted by teeforb View Post
what rb6 upgrade made the most significant laptime improvements in the 17.5 blinky stock class?
Carbon fiber battery holder and a new antenna! Ha
ryanpatrickgore is offline   Reply With Quote
Old 01-29-2014, 04:24 PM   #9589
RiseRC's Avatar
Thumbs up My RB6
Just go my rb6 used a couple weeks ago, I am loving it
Kyosho Ultima RB6 & RB6.6 Car Thread-rb62.jpg   Kyosho Ultima RB6 & RB6.6 Car Thread-rb6mike.jpg
Mike H.
RiseRC is offline   Reply With Quote
Old 01-29-2014, 08:46 PM   #9590
Trader Rating: 110 (100%+)
Subscribed. Just picked one up.
*MIP/SCTE*
+FTM GRIP+
socal23 is offline   Reply With Quote
Old 01-29-2014, 08:52 PM   #9591
Trader Rating: 17 (95%+)
What's a good spur and pinion set for 17.5 short indoor clay track right now I'm running 76 29 doesn't seem to be working that well on the straight.
svillegas is offline   Reply With Quote
Old 01-29-2014, 08:58 PM   #9592
VenturaDC's Avatar
Trader Rating: 32 (100%+)
Originally Posted by mog ruith View Post
Yeah i hope so lol
Yes please do let us know, I had bad luck with my 5yo sons sct ready set shocks, which I've upgraded. Now he is really wanting a buggy so was thinking the ready set rb6 but absolutely did not want to have to buy another set of big bores right away.
Dustin Colt45 Aguirre
Kyosho RB6--Futaba--HW--Shuurspeed 17.5
Kyosho SCR--Hitec--Lrp--Yeah 13.5
Durango Dex210--Futaba--Trakpower--Tacon 8.5
VenturaDC is offline   Reply With Quote
Old 01-29-2014, 09:06 PM   #9593
tschenck's Avatar
For stock most go to a 69 tooth spur. For my local track 100x50 most end up running in the 33/69 range.
Pro-Line/MIP/Team Scream Racing/Dirt Skins
Wolcott Hobby/RCHR
Losi 22 4.0 hobbywing xr10 pro stock spec, tsr 17.5
tschenck is offline   Reply With Quote
Old 01-29-2014, 09:16 PM   #9594
What brand of spur gear Kyosho only goes down to 76
Old 01-29-2014, 09:20 PM   #9595
VenturaDC's Avatar
How much timing and what temps are you seeing, im running 30\76 with maxed endbell timing and have no problem keeping up with anyone on our straight and I'm pulling off at 145
Old 01-29-2014, 09:29 PM   #9596
Low temp around 110 and about 25 on endball. I was thinking of trying 30 on pinion.
Old 01-29-2014, 09:48 PM   #9597
VenturaDC's Avatar
In my personal experience most 17.5s in 2wd buggy need full timing to come alive. My d3.5 was geared 28/76 with full timing and I was out motoring most people down the straight on a medium sized outdoor track
Old 01-29-2014, 10:00 PM   #9598
Thanks for info I will try that tomorrow and see how it works
Old 01-30-2014, 04:47 AM   #9599
nickdawg18's Avatar
Trader Rating: 33 (100%+)
I ran a 17.5 in my 6. Didn't care for it. Put in an 8.5 with an avid slipper and topshaft, 22/76 gearing, and it seems to have made it more stable. It's almost like this buggy was designed to be easier to drive the faster it goes. I dunno, hard to explain.
Nick Carroll
Mugen Mbx7-reds r5t team edition 2 [] Mugen Mbx7 Eco-Tekin rx8 gen 2 1900kv [] Losi 8ight T 2.0-fusion x7 [] Losi 8ight T E 2.0-Tekin 2000kv [] Kyosho RB6-Tekin RS gen 2 8.5t [] Losi 22sct
VP Pro USA [] Up-Grade RC
nickdawg18 is offline   Reply With Quote
Old 01-30-2014, 06:42 AM   #9600
MikeXray's Avatar
Trader Rating: 73 (100%+)
That's still very high on gearing for a 17.5, most run 30-33/69.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22953 Today 12:29 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
